Hello,
After yesterdays full system update I was greeted with a black screen on boot. Manually running startplasma-x11 gives me: $DISPLAY is not set or cannot connect to the X server.
This is my Xorg.0.log:
[ 123.699]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
[ 123.699]
X.Org X Server 1.21.1.1
[ 123.699] Current Operating System: Linux ryzen3700 5.10.79-1-MANJARO #1 SMP PREEMPT Fri Nov 12 20:26:09 UTC 2021 x86_64
[ 123.699] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=d88cee7a-d594-459b-af44-3d807fb80f7a rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 123.699]
[ 123.699] Current version of pixman: 0.40.0
[ 123.699] Before reporting problems, check http://wiki.x.org
[ 123.699] Markers: (--) probed, (**) from config file, (==) default setting,
[ 123.699] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Nov 20 10:11:28 2021
[ 123.700] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 123.701] (==) ServerLayout "layout"
[ 123.701] (==) No screen section available. Using defaults.
[ 123.701] (**) |-->Screen "Default Screen Section" (0)
[ 123.701] (**) | |-->Monitor "<default monitor>"
[ 123.701] (==) No monitor specified for screen "Default Screen Section".
[ 123.701] (==) Automatically adding devices
[ 123.701] (==) Automatically enabling devices
[ 123.701] (==) Automatically adding GPU devices
[ 123.701] (==) Automatically binding GPU devices
[ 123.701] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 123.702] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 123.702] Entry deleted from font path.
[ 123.702] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 123.702] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 123.702] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 123.702] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 123.702] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 123.702] (II) The server relies on udev to provide the list of input devices.
[ 123.702] (II) Module ABI versions:
[ 123.702] X.Org ANSI C Emulation: 0.4
[ 123.702] X.Org Video Driver: 25.2
[ 123.702] X.Org XInput driver : 24.4
[ 123.702] X.Org Server Extension : 10.0
[ 123.703] (++) using VT number 2
[ 123.705] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 123.708] (--) PCI:*(41@0:0:0) 10de:1184:1462:2825 rev 161, Mem @ 0xfb000000/16777216, 0xe0000000/134217728, 0xe8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 123.708] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 123.708] (II) LoadModule: "glx"
[ 123.709] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 123.711] (II) Module glx: vendor="X.Org Foundation"
[ 123.711] compiled for 1.21.1.1, module version = 1.0.0
[ 123.711] ABI class: X.Org Server Extension, version 10.0
[ 123.712] (==) Matched nouveau as autoconfigured driver 0
[ 123.712] (==) Matched nv as autoconfigured driver 1
[ 123.712] (==) Matched modesetting as autoconfigured driver 2
[ 123.712] (==) Matched fbdev as autoconfigured driver 3
[ 123.712] (==) Matched vesa as autoconfigured driver 4
[ 123.712] (==) Assigned the driver to the xf86ConfigLayout
[ 123.712] (II) LoadModule: "nouveau"
[ 123.712] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 123.714] (II) Module nouveau: vendor="X.Org Foundation"
[ 123.714] compiled for 1.21.1.1, module version = 1.0.17
[ 123.714] Module class: X.Org Video Driver
[ 123.714] ABI class: X.Org Video Driver, version 25.2
[ 123.714] (II) LoadModule: "nv"
[ 123.714] (WW) Warning, couldn't open module nv
[ 123.714] (EE) Failed to load module "nv" (module does not exist, 0)
[ 123.714] (II) LoadModule: "modesetting"
[ 123.714] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 123.715] (II) Module modesetting: vendor="X.Org Foundation"
[ 123.715] compiled for 1.21.1.1, module version = 1.21.1
[ 123.715] Module class: X.Org Video Driver
[ 123.715] ABI class: X.Org Video Driver, version 25.2
[ 123.715] (II) LoadModule: "fbdev"
[ 123.716] (WW) Warning, couldn't open module fbdev
[ 123.716] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 123.716] (II) LoadModule: "vesa"
[ 123.716] (WW) Warning, couldn't open module vesa
[ 123.716] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 123.716] (II) NOUVEAU driver
[ 123.716] (II) NOUVEAU driver for NVIDIA chipset families :
[ 123.716] RIVA TNT (NV04)
[ 123.716] RIVA TNT2 (NV05)
[ 123.716] GeForce 256 (NV10)
[ 123.716] GeForce 2 (NV11, NV15)
[ 123.716] GeForce 4MX (NV17, NV18)
[ 123.716] GeForce 3 (NV20)
[ 123.716] GeForce 4Ti (NV25, NV28)
[ 123.716] GeForce FX (NV3x)
[ 123.716] GeForce 6 (NV4x)
[ 123.716] GeForce 7 (G7x)
[ 123.716] GeForce 8 (G8x)
[ 123.716] GeForce 9 (G9x)
[ 123.716] GeForce GTX 2xx/3xx (GT2xx)
[ 123.716] GeForce GTX 4xx/5xx (GFxxx)
[ 123.716] GeForce GTX 6xx/7xx (GKxxx)
[ 123.716] GeForce GTX 9xx (GMxxx)
[ 123.716] GeForce GTX 10xx (GPxxx)
[ 123.716] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 123.716] (EE) [drm] Failed to open DRM device for pci:0000:29:00.0: -19
[ 123.716] (EE) open /dev/dri/card0: No such file or directory
[ 123.716] (WW) Falling back to old probe method for modesetting
[ 123.716] (EE) Screen 0 deleted because of no matching config section.
[ 123.716] (II) UnloadModule: "modesetting"
[ 123.716] (EE) Device(s) detected, but none match those in the config file.
[ 123.716] (EE)
Fatal server error:
[ 123.716] (EE) no screens found(EE)
[ 123.716] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 123.716] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 123.716] (EE)
[ 123.718] (EE) Server terminated with error (1). Closing log file.
Also my system info:
Kernel: 5.10.79-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Console: pty pts/0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450I GAMING PLUS AC (MS-7A40) v: 2.0
serial: <filter> UEFI: American Megatrends LLC. v: A.F5 date: 09/29/2021
RAM: total: 31.34 GiB used: 883.9 MiB (2.8%)
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 4 MiB bogomips: 115250
Speed: 2799 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2799 2: 1864 3: 1859 4: 1861 5: 2199 6: 2193 7: 2200 8: 2194 9: 1863
10: 1865 11: 2201 12: 2200 13: 2202 14: 2198 15: 2792 16: 1861
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GK104 [GeForce GTX 770] vendor: Micro-Star MSI driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 29:00.0 chip-ID: 10de:1184
class-ID: 0300
Display: server: X.org 1.21.1.1 driver: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa tty: 188x47
Message: Advanced graphics data unavailable in console. Try -G --display
Device-1: NVIDIA GK104 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 29:00.1 chip-ID: 10de:0e0a
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2b:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.10.79-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 25:00.0
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 26:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp38s0 state: down mac: <filter>
IF-ID-1: br-233e893149e1 state: down mac: <filter>
IF-ID-2: br-852e0bf40f02 state: down mac: <filter>
IF-ID-3: br-e426f6e41ff8 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-4: docker0 state: down mac: <filter>
IF-ID-5: veth3712700 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-8:4 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 924.07 GiB used: 205.1 GiB (22.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: GOODRAM model: N/A size: 447.13 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 01.7 scheme: MBR
ID-1: / raw-size: 238.47 GiB size: 233.73 GiB (98.01%)
used: 205.08 GiB (87.7%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: d88cee7a-d594-459b-af44-3d807fb80f7a
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 25.3 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 8E82-7224
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: 2A7E82137E81D7C9
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 237.84 GiB fs: ntfs label: N/A
uuid: E4AC8D4FAC8D1CE4
ID-4: /dev/sda1 maj-min: 8:1 size: 447.13 GiB fs: ntfs label: N/A
uuid: 4373057300625BAA
Device-1: 1-5:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-6:3 info: Gaming KB Gaming KB type: Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 300mA chip-ID: 258a:001a class-ID: 0301
Device-3: 1-8:4 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 40.1 C mobo: 39.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 778 fan-3: 0 fan-4: 0 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.39 vbat: 3.23
Processes: 267 Uptime: 25m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1835 note: see --pkg
pacman: 1827 lib: 481 flatpak: 0 snap: 8 Shell: Bash v: 5.1.8
running-in: pty pts/0 (SSH) inxi: 3.3.08
Thanks for any help.
