It seems that 470 series have several regressions connected with memory leaks. Is where an easy way to downgrade driver?
It would be nice for Manjaro to expand mhwd to choose video-driver version like it can be chosen with kernel
Thereâs a thread here somewhere where this was discussed, but I canât find it now.
Thereâs a topic on the NVIDIA forums about it. It happened to me with Horizon: Zero Dawn.
I have seen it. We canât fix nvidia drivers, but it would be nice to make simple tool in Manjaro to downgrade video-drivers in such cases.
I know. But what should we do with regressions?
I have tried to use downgrade util, but I have only linux510-nvidia 470⌠in the list to downgrade
You can use nvidia-all
and install the driver you want,very easy installation.
Just make sure to make a backup with Timeshift just in case.
File a bug upstream!
Therefore, Iâve marked this answer as the solution to your question as it is by far the best answer youâll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldnât have done this or or if you agree)
P.S. In the future, please donât forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
so that the next person that has the exact same problem you just had will benefit from your post as well as your question will now be in the âsolvedâ status.
What do you mean by âbug upsteamâ? Bug tracker of nvidia or bug tracker in Manjaro?
It is a bug in nvidia driver, so the only solution is a waiting for a bugfix. The only real solution for a user of Manjaro is a downgrading version, but it is not supporting officially and I canât do it because a package was removed from pacman cache.
Please read this:
Especially the section What is this âUpstreamâ and 'Downstream" business?
Before calling me a noob, you should fix this âhowtoâ. Linus has no registry, cause he is a man, main developer and mainteiner of Linux kernel.
There is no official possibility to choose video driver in Manjaro and this a downstream problem (may be feature request is needed).
My apologies, but I didnât call you anything: I just pointed you to a generic guide that takes a humorous approach to a lot of misconceptions about Linux in general and Manjaro in particular.
Thank you for pointing that out: Corrected!
There is! You can choose from any in:
mhwd --list
If you would feel that is not enough, please feel free to post a #site-feedback:feature-request that describes in detail what youâre looking for and if one of our developers deems it an added value to Manjaro, they will take it up in our next release!
Thank you for your answer. May be I am noob in Arch-based distros, cause all my previous distros were rpm-based or debian-based, including my current distro at my job
Thatâs why my questions may look a little bit nooby.
Finishing with the question, here is a sceenshot, there you can see, that results of âmhwdâ and âmhwd --listâ are the same
Edit* deleted screenshot
Please read this:
Especially this bit:
Then edit your previous reply and post that as text and this so I get a notification and then Iâll come back and have another look.
Thank you for your cooperation.
As a true oldfag, I have skipped reading all tutorials and FAQ
And yes - it was advice from one of Manjaro developers to ask here
And what about downstream solution to expand mhwd to make it possible to select video driver?
That would be a new post in the #site-feedback:feature-request categoryâŚ
Please note that:
- Great ideas are plentiful
- The Manjaro team is quite small
- Programming is hard
- The devs do read the feature-request category, but only pick up ideas that interest them.
Yeah, Iâm an fart too and why Iâm pointing you to the essential tutorials you should read!
