[SOLVED] Error in KDE System Settings.
Welp, after I updated, I didn't notice right away but I have an issue with systemsettings5 in KDE Plasma on Frank. I'm getting massive errors.
When I open System Settings I can go to any category except Application Style-> GNOME/GTK Application style. When I click it it hangs for about 40 -50 seconds then crashes with this error.
When I open system settings, I get this error.
I've tried reinstalling glibc, but no luck. I wanted to post this before I did anything drastic (Downgrade glibc sounds like a bad move).
Current theme is Arc Dark. I tried other themes but it exhibits the same behavior.
Update
  • I've done all the tips & tricks on the archwiki
  • I've done the tips in the thread @saedlar93 with Petsams advice.
  • Tried kernels 419,52,53,414. Just for fun. :crazy_face:
  • Restore from backup. Updating brings the problem back.
  • sudo pacman -S plasma kf5 qt5 No joy.
And now I'll give @xircon's idea a try.
Wooho! Are we having fun yet?
Thanks for the reply. :grin:
I read that. I have tried Petsams suggestions with no change.
Also, that person seems to have hacked at thier configs for having GTK themes in root some something. I haven't done that so at least that's a good thing.
Try (I haven't read petsams's post):
Can I use a very, very rude word?
NSFW
BACKUP?
:rofl:
Also worth a pop:
cd /home/<your-username>/.config
mkdir plasma-old
mv *rc plasma-old/
I do. And I did go back. However when I update it problem comes back.
Eh, forgot to add that to the list of tried stuff.
Summary
At least I know why the lights blink on my computer. :stuck_out_tongue:
But you don't know why my lights blink, do you? :smiley:
I'm sure the NSA does. :stuck_out_tongue:
Using your command. /sigh Bloody Discover-snap errored. I hate that program. I really do.
https://www.nationalsheep.org.uk/
:sheep: :sheep: :sheep: :sheep: :sheep: :sheep: :sheep: :sheep: :sheep: :sheep:
I asked them they said "Baaaah"
Still crashes.
NEXT!
Does the install work or does that crash, if so:
sudo pacman -S plasma kf5 qt5  --overwrite="*"
Oh, I just left discover-snap out and it was fine.
:wink:
Try a new user, rest plasma to defaults as I stated above or place a bucket over your head and rock gently.
Running out of ideas and there is very little info on the net.
Oh, forgot about a new user. Good thinking. :wink:
I'll get stuck into that after my coffee. :coffee: All out of buckets though.
Tell me about it.
New Profile has zero problems. So I guess it's a theme somewhere or setting?
I wonder if taking the Trolltech settings from the new user and replacing mine would work?
Meh, about to find out. :rofl:
Are spotty fourteen year olds (with a bad attitude) allowed caffeinated drinks?
Did you try to reset your plasma as I stated above?
Yep. I've done it several times. Several ways. At this point it's getting to where it's easier to reinstall.
HEY! Not 14! Sheesh.
Just harking back to an older thread :smiley:
You could stay with the new user and copy your stuff across, then delete the broken user.
Weighing my options at the moment.
  • Reinstall
  • Use the new user
  • Go back to Windows since i never had these problems there!!!!!!
  • Go on as if nothing is wrong. Who cares about GTK settings anyhow? It's all skinned properly. I only noticed the crashing when I want to change the cursor for Firefox.
  • All of the above (Not the Windows one)
I blame KDE.
