After updating, one monitor displays only green, the other only yellow, see screenshot. The login screen was normal, but the desktop and all applications are affected.
I’d love to know if anyone has any advice about how to get R and B to join G.!
[edit]
Had to look at my screenshot on another computer to notice the screenshot came out fine - everything is green on my Manjaro machine!
$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.10.79-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=81e70821-c5a8-4c93-aa6a-77e05f91155d rw quiet splash apparmor=1
Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Desktop System: PC Specailist product: Tornado R5 v: N/A
serial: <filter>
Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1820 date: 09/12/2019
RAM: total: 23.48 GiB used: 2.04 GiB (8.7%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
L2: 3 MiB bogomips: 86268
Speed: 2524 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2524 2: 1944 3: 2191 4: 2191 5: 2129 6: 2196 7: 2196 8: 2197 9: 2414
10: 2022 11: 1893 12: 2195
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
always-on, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: ZOTAC driver: nouveau
v: kernel bus-ID: 05:00.0 chip-ID: 10de:2184 class-ID: 0300
Display: x11 server: X.org 1.21.1.1 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: NV168 v: 4.3 Mesa 21.2.5 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.10.79-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel port: e000 bus-ID: 04:00.0 chip-ID: 10ec:818b class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Local Storage: total: 1.93 TiB used: 592.16 GiB (30.0%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU650 size: 111.79 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 1c45 scheme: GPT
ID-1: / raw-size: 905.39 GiB size: 890.1 GiB (98.31%)
used: 134.97 GiB (15.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 81e70821-c5a8-4c93-aa6a-77e05f91155d
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: BB10-FC9F
ID-3: /mnt/archive raw-size: 837.14 GiB size: 823 GiB (98.31%)
used: 457.19 GiB (55.6%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
label: linux_storage uuid: 07cb8824-4d60-4cec-9b0a-3b3720820458
ID-1: swap-1 type: partition size: 25.83 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: a6def0b5-1dcb-4df5-b118-f83855931048
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 94.16 GiB fs: ntfs label: New Volume
uuid: D4AC546BAC5449DE
ID-3: /dev/sda3 maj-min: 8:3 size: 200 MiB fs: vfat label: N/A
uuid: 294B-D5D1
ID-4: /dev/sdb1 maj-min: 8:17 size: 260 MiB fs: vfat label: SYSTEM
uuid: C496-433A
ID-5: /dev/sdb2 maj-min: 8:18 size: 128 MiB fs: <superuser required>
ID-6: /dev/sdb3 maj-min: 8:19 size: 500 MiB fs: ntfs label: Recovery
uuid: EA9096D69096A899
ID-7: /dev/sdb4 maj-min: 8:20 size: 110.92 GiB fs: ntfs label: Windows
uuid: 503C99EB3C99CC7A
Device-1: 1-2:2 info: Logitech M-UAS144 [LS1 Laser Mouse] type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 046d:c062 class-ID: 0301
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-1:2 info: Holtek USB-HID Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:0192 class-ID: 0300
Hub-6: 5-2:3 info: Microchip (formerly SMSC) Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2744 class-ID: 0900
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-8: 6-2:2 info: Microchip (formerly SMSC) Hub ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 0424:5744 class-ID: 0900
System Temperatures: cpu: 33.8 C mobo: N/A gpu: nouveau temp: 21.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1141
Processes: 321 Uptime: 15m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1260 pacman: 1234 lib: 311 flatpak: 10
snap: 16 Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.08
