[SOLVED by MAGIC :-) ] Geany IDE missing icons in XFCE whisker menu
The issue is pretty much summarized in the title. In the whisker menu, Geany's icon is not visible:
Now, it works perfectly fine and has all its icons loaded properly when I actually run Geany, but the lack of icon in the whisker menu is infuriating. I think I'll be fine if I can't fix it, but I would much rather have it fixed than not. Do any of you have suggestions?
Try.
  1. Reboot your system first. Icon o.k.?
  2. Change Icon set.
  3. Put geany to taskbar. You see icon there?
I'm not sure what fixed it exactly but it seems to have fixed itself with time. Thanks anyway!
