[Solved] Bios firmware not found in gnome-boxes
When I tried to install Debian or Slackware in gnome boxes, it showed an error message of "bios firmware not found" like this:
(gnome-boxes:8757): Boxes-WARNING **: 13:39:32.997: machine.vala:638: Failed to start slackware64-14: Unable to start domain: operation failed: Unable to find any firmware to satisfy 'bios'
More detailed log: https://pastebin.com/w2VgLj5n
This is the output when I execute "pacman -Q | grep qemu":
qemu 4.2.0-2
qemu-arch-extra 4.2.0-2
qemu-block-gluster 4.2.0-2
qemu-block-iscsi 4.2.0-2
qemu-block-rbd 4.2.0-2
qemu-guest-agent 4.2.0-2
Also I found that when I tried to install some distros like ubuntu, manjaro, fedora etc. it will use tianocore instead of seabios to boot the image.
I've looked it up in the web, but with no luck, I couldn't find any post about this issue.
Currently running on arch, with linux kernel 5.5.8.
If someone could offer me some assistance, I'll be much obliged.
Edit: sry I forgot upload the output of "gnome-boxes --ckecks"
• The CPU is capable of virtualization: yes
• The KVM module is loaded: yes
• Libvirt KVM guest available: yes
• Boxes storage pool available: yes
• The SELinux context is default: no
Can you post
inxi -Fzxxxa
Is there a Bios update available?
Have you checked with Gnome web
https://help.gnome.org/users/gnome-boxes/stable/
ofc, but the webpage is just useless
I don't think it's a bios-related issue but something wrong with qemu or kvm stuffs... whatever, here's the output:
  Host: arch Kernel: 5.5.8-arch1-1 x86_64 bits: 64 compiler: gcc v: 9.2.1
  parameters: BOOT_IMAGE=/boot/vmlinuz-linux
  root=UUID=20e92798-5092-4c51-baf8-f03c25a4220d rw loglevel=3 quiet
  Desktop: Gnome 3.36.0 wm: gnome-shell dm: GDM 3.34.1 Distro: Arch Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: HP model: 8478 v: 70.56 serial: <filter> UEFI: Insyde v: F.21
  date: 11/29/2019
  ID-1: BAT1 charge: 30.4 Wh condition: 41.0/52.8 Wh (78%) volts: 12.1/11.6
  model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
  status: Unknown
  Topology: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10)
  microcode: CA L2 cache: 8192 KiB
  bogomips: 36812
  Speed: 900 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 900 2: 900
  3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
  vendor: Hewlett-Packard driver: N/A bus ID: 01:00.0 chip ID: 10de:1c8c
  Display: wayland server: X.Org 1.20.7 driver: intel,nvidia
  unloaded: modesetting,vesa alternate: fbdev,nouveau,nv
  compositor: gnome-shell resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2)
  v: 4.6 Mesa 19.3.4 compat-v: 3.0 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
  Sound Server: ALSA v: k5.5.8-arch1-1
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
  v: kernel port: 5000 bus ID: 00:14.3 chip ID: 8086:a370
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 04:00.0
  chip ID: 10ec:8168
  Local Storage: total: 1.03 TiB used: 117.55 GiB (11.2%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 119.24 GiB block size:
  physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter>
  rev: ADHA0101 scheme: GPT
  ID-2: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B
  speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A3T0 scheme: GPT
  ID-1: / raw size: 35.00 GiB size: 34.20 GiB (97.71%)
  used: 20.40 GiB (59.6%) fs: ext4 dev: /dev/nvme0n1p5
  ID-2: /home raw size: 300.00 GiB size: 294.29 GiB (98.10%)
  used: 97.09 GiB (33.0%) fs: ext4 dev: /dev/sda2
  ID-3: swap-1 size: 8.00 GiB used: 2.4 MiB (0.0%) fs: swap
  swappiness: 60 (default) cache pressure: 100 (default) dev: /dev/sda5
  System Temperatures: cpu: 50.0 C mobo: 29.8 C
  Processes: 308 Uptime: 9h 31m Memory: 7.67 GiB used: 4.39 GiB (57.2%)
  Init: systemd v: 245 Compilers: gcc: 9.2.1 clang: 9.0.1 Shell: zsh v: 5.8
  running in: gnome-terminal inxi: 3.0.37
Can you tell us, what you have installed?
ok.
aalib 1.4rc5-13
accountsservice 0.6.55-1
acl 2.2.53-2
acpid 2.0.32-1
adobe-source-code-pro-fonts 2.030ro+1.050it-5
adobe-source-han-sans-otc-fonts 2.001-1
adobe-source-sans-pro-fonts 3.006-1
adwaita-icon-theme 3.36.0-1
adwaita-plus-git 5.0.r3.g38dc89c7-1
alsa-lib 1.2.2-1
alsa-plugins 1.2.2-1
alsa-topology-conf 1.2.2-2
alsa-ucm-conf 1.2.2-1
amtk 5.0.2-1
android-tools 29.0.6-1
aom 1.0.0.errata1+avif-1
apache 2.4.41-1
appstream-glib 0.7.17-1
apr 1.7.0-2
apr-util 1.6.1-6
archlinux-appstream-data 20200103-1
archlinux-keyring 20200108-1
argon2 20190702-2
aspell 0.60.8-1
at-spi2-atk 2.34.2-1
at-spi2-core 2.36.0-1
atk 2.34.1-1
atkmm 2.28.0-1
attr 2.4.48-2
audit 2.8.5-6
augeas 1.12.0-1
autoconf 2.69-7
automake 1.16.1-2
avahi 0.8+6+g751be80-1
babl 0.1.74-1
baobab 3.34.0-1
bash 5.0.016-1
beignet 1.3.2+12+gfc5f430c-3
bibata-cursor-theme 0.4.2-1
binutils 2.34-1
bison 3.5.2-1
blas 3.9.0-2
bluez 5.53-1
bluez-libs 5.53-1
bluez-utils 5.53-1
bolt 0.8-3
boost-libs 1.72.0-1
brltty 6.0-8
brotli 1.0.7-3
btrfs-progs 5.4-1
bubblewrap 0.4.0-1
bzip2 1.0.8-3
ca-certificates 20181109-3
ca-certificates-mozilla 3.51-1
ca-certificates-utils 20181109-3
cairo 1.17.2+17+g52a7c79fd-2
cairomm 1.12.2-3
cantarell-fonts 1:0.201-1
cblas 3.9.0-2
cdparanoia 10.2-7
cdrtools 3.02a09-2
celt 0.11.3-3
celt0.5.1 0.5.1.3-4
ceph 14.2.8-1
ceph-libs 14.2.8-1
cheese 3.34.0+23+gcac6d3a1-1
chromaprint 1.4.3-2
chrome-gnome-shell 10.1-3
chromium 80.0.3987.132-2
cifs-utils 6.10-1
clang 9.0.1-1
clucene 2.3.3.4-10
clutter 1.26.4-1
clutter-gst 3.0.27-2
clutter-gtk 1.8.4-1
cogl 1.22.6-1
colord 1.4.4+9+g1ce26da-1
colord-gtk 0.2.0-1
colord-sane 1.4.4+9+g1ce26da-1
compiler-rt 9.0.1-1
coreutils 8.31-3
cracklib 2.9.7-2
cronie 1.5.5-1
cryptsetup 2.3.0-1
cups-pk-helper 0.2.6-3
curl 7.69.0-5
dav1d 0.5.2-1
db 5.3.28-5
dbus 1.12.16-5
dbus-glib 0.110-1
dconf 0.34.0-1
dconf-editor 3.36.0-1
desktop-file-utils 0.24-2
device-mapper 2.02.186-5
dhcpcd 8.1.6-1
diffutils 3.7-3
djvulibre 3.5.27-5
dleyna-connector-dbus 0.3.0-2
dleyna-core 0.6.0+2+g1c6853f-1
dleyna-renderer 0.6.0-3
dleyna-server 0.6.0+2+geb895ae-1
dmidecode 3.2-1
dmraid 1.0.0.rc16.3-12
dnsmasq 2.80-4
dnssec-anchors 20190629-2
dosfstools 4.1-3
dotconf 1.3-5
double-conversion 3.1.5-1
drawing 0.4.13-1
e2fsprogs 1.45.5-1
ebtables 2.0.10_4-7
efibootmgr 16-2
efivar 37-3
egl-wayland 1.1.4-2
eglexternalplatform 1.1-1
electron-ssr-0.3.0 alpha.3-36
enchant 2.2.7-1
eog 3.36.0-1
epiphany 3.36.0-1
evince 3.36.0-1
evolution 3.36.0-1
evolution-data-server 3.36.0-1
exempi 2.5.1-1
exiv2 0.27.2-1
expat 2.2.9-3
faac 1.30-2
faad2 2.9.1-2
fakeroot 1.24-2
ffmpeg 1:4.2.2-3
fftw 3.3.8-2
file 5.38-3
file-roller 3.36.0-1
filesystem 2019.10-2
findutils 4.7.0-2
flac 1.3.3-1
flashplugin 32.0.0.344-1
flex 2.6.4-3
fluidsynth 2.1.1-1
folks 0.14-1
fontconfig 2:2.13.91+24+g75eadca-2
freeglut 3.2.1-1
freerdp 1:2.0.0_rc4-8
freetype2 2.10.1-2
frei0r-plugins 1.7.0-1
fribidi 1.0.9-1
fuse-common 3.9.0-1
fuse2 2.9.9-3
fuse3 3.9.0-1
gavl 1.4.0-3
gawk 5.0.1-2
gc 8.0.4-3
gcab 1.4-1
gcc 9.2.1+20200130-2
gcc-libs 9.2.1+20200130-2
gcr 3.36-1
gd 2.2.5-2
gdbm 1.18.1-3
gdk-pixbuf2 2.40.0-2
gdm 3.34.1-2
gedit 3.36.0-1
gegl 0.4.22-1
geoclue 2.5.6-1
geocode-glib 3.26.2-1
gettext 0.20.1-3
gfbgraph 0.2.3+23+g5925221-1
ghex 3.18.4-1
ghostscript 9.50-2
giflib 5.2.1-1
gimp 2.10.18-2
git 2.25.1-1
gjs 2:1.64.0-1
glew 2.1.0-1
glib-networking 2.64.0-1
glib2 2.64.0-1
glibc 2.31-1
glibmm 2.62.0-1
glu 9.0.1-1
glusterfs 1:7.3-1
gmime3 3.2.6-1
gmp 6.2.0-1
gnome-autoar 0.2.4-1
gnome-backgrounds 3.36.0-1
gnome-bluetooth 3.34.1-1
gnome-books 3.34.0+21+g4d34d109-1
gnome-boxes 3.36.0-1
gnome-calculator 3.36.0-1
gnome-calendar 3.36.0-1
gnome-characters 3.34.0-1
gnome-clocks 3.36.0-1
gnome-color-manager 3.35.90+1+g98904208-1
gnome-contacts 3.36-1
gnome-control-center 3.36.0-1
gnome-desktop 1:3.36.0-1
gnome-dictionary 3.26.1-1
gnome-disk-utility 3.36.0-1
gnome-documents 3.34.0+6+g966b04ec-1
gnome-epub-thumbnailer 1.6-1
gnome-font-viewer 3.34.0+27+g5ffd1ba-1
gnome-getting-started-docs 3.35.92+1+g635b61d-1
gnome-keyring 1:3.36.0-1
gnome-logs 3.34.0-1
gnome-maps 3.36.0-1
gnome-menus 3.36.0-1
gnome-music 1:3.36.0-1
gnome-notes 3.36.0-1
gnome-online-accounts 3.36.0-1
gnome-online-miners 3.34.0-1
gnome-photos 3.34.1-1
gnome-remote-desktop 0.1.7-2
gnome-screenshot 3.36.0-1
gnome-session 3.36.0-1
gnome-settings-daemon 3.36.0-1
gnome-shell 1:3.36.0-3
gnome-software 3.34.2-2
gnome-software-packagekit-plugin 3.34.2-2
gnome-sound-recorder 3.34.0-1
gnome-system-monitor 3.36.0-1
gnome-terminal 3.36.0.1-2
gnome-themes-extra 3.28-1
gnome-todo 3.28.1+22+gd56e14e-1
gnome-tweaks 3.34.0-2
gnome-user-docs 3.35.92+15+g682e41b2-1
gnome-user-share 3.34.0-1
gnome-video-effects 0.5.0+4+g9554041-1
gnome-weather 3.34.0-1
gnupg 2.2.19-1
gnutls 3.6.12-1
gobject-introspection-runtime 1.64.0-1
gom 0.4-1
gparted 1.1.0-1
gperftools 2.7-1
gpgme 1.13.1-3
gpm 1.20.7.r27.g1fd1941-2
gptfdisk 1.0.5-1
graphene 1.10.0-1
graphite 1:1.3.13-2
grep 3.4-1
grilo 0.3.12-1
grilo-plugins 0.3.11+4+g11cc1f8-1
groff 1.22.4-3
grub 2:2.04-5
gsettings-desktop-schemas 3.36.0-1
gsfonts 20180524-2
gsl 2.6-1
gsm 1.0.18-1
gsound 1.0.2-4
gspell 1.8.3-1
gssdp 1.2.2-1
gst-editing-services 1.16.2-1
gst-libav 1.16.2-1
gst-plugins-bad 1.16.2-3
gst-plugins-base 1.16.2-1
gst-plugins-base-libs 1.16.2-1
gst-plugins-good 1.16.2-2
gst-python 1.16.2-1
gst-transcoder 1.16.0-1
gstreamer 1.16.2-1
gtk-engine-murrine 0.98.2-3
gtk-update-icon-cache 1:3.24.14+9+g429a6287e0-1
gtk-vnc 1.0.0-1
gtk2 2.24.32-2
gtk3 1:3.24.14+9+g429a6287e0-1
gtkmm 1:2.24.5-3
gtkmm3 3.24.2-1
gtksourceview4 4.6.0-1
gtkspell 2.0.16-7
guile 2.2.6-1
gupnp 1.2.2-1
gupnp-av 0.12.11+2+gb5ca07c-1
gupnp-dlna 0.10.5+4+gc947eed-1
gupnp-igd 0.2.5+3+gedd78a6-2
gvfs 1.44.0-1
gvfs-afc 1.44.0-1
gvfs-goa 1.44.0-1
gvfs-google 1.44.0-1
gvfs-gphoto2 1.44.0-1
gvfs-mtp 1.44.0-1
gvfs-nfs 1.44.0-1
gvfs-smb 1.44.0-1
gzip 1.10-3
harfbuzz 2.6.4-2
harfbuzz-icu 2.6.4-2
hicolor-icon-theme 0.17-1
hspell 1.4-2
hunspell 1.7.0-2
hwids 20200204-1
hwloc 2.1.0-2
hyphen 2.8.8-2
iana-etc 20200224-1
ibus 1.5.22-1
ibus-libpinyin 1.11.1-3
icu 65.1-3
ijs 0.35-2
imagemagick 7.0.10.0-1
imlib2 1.6.1-1
inetutils 1.9.4-8
inkscape 0.92.4-14
intel-gmmlib 19.4.1-1
intel-media-driver 19.4.0.r-1
intel-media-sdk 19.4.0-4
intel-tbb 2020.1-1
iproute2 5.5.0-1
iptables 1:1.8.4-1
iputils 20190709-2
iso-codes 4.4-1
jack 0.125.0-8
jansson 2.12-1
jasper 2.0.16-1
java-runtime-common 3-2
jbig2dec 0.17-1
jemalloc 1:5.2.1-1
jfsutils 1.1.15-7
jre-openjdk 13.0.2.u8-1
jre-openjdk-headless 13.0.2.u8-1
js60 60.9.0-2
js68 68.5.0-2
json-c 0.13.1-3
json-glib 1.4.4-1
kbd 2.2.0-5
keyutils 1.6.1-3
kmod 27-1
komorebi 2.1-2
krb5 1.17.1-1
kyotocabinet 1.2.77-1
l-smash 2.14.5-1
ladspa 1.15-1
lame 3.100-2
lapack 3.9.0-2
lcms2 2.9-2
ldb 1:1.5.6-2
ldns 1.7.1-2
lensfun 0.3.95-1
less 551-3
leveldb 1.22-1
libabw 0.1.3-1
libaio 0.3.112-2
libao 1.2.2-2
libappindicator-gtk3 12.10.0-13
libarchive 3.4.2-1
libass 0.14.0-1
libassuan 2.5.3-2
libasyncns 0.8+3+g68cd5af-2
libatasmart 0.19-4
libatomic_ops 7.6.10-1
libavc1394 0.5.4-3
libblockdev 2.23-3
libbluray 1.1.2-1
libbs2b 3.1.0-6
libbsd 0.10.0-1
libbytesize 2.2-1
libcaca 0.99.beta19-2
libcacard 2.7.0-1
libcanberra 0.30+2+gc0620e4-2
libcanberra-pulse 0.30+2+gc0620e4-2
libcap 2.33-1
libcap-ng 0.7.10-1
libcddb 1.3.2-5
libcdio 2.1.0-1
libcdio-paranoia 10.2+2.0.1-1
libcdr 0.1.6-1
libchamplain 0.12.20-1
libcmis 0.5.2-4
libcroco 0.6.13-1
libcryptui 3.12.2+55+ged3b12af-1
libcue 2.2.1-1
libcups 2.3.1-1
libdaemon 0.14-4
libdatrie 0.2.12-1
libdazzle 3.36.0-1
libdbusmenu-glib 16.04.0-4
libdbusmenu-gtk3 16.04.0-4
libdc1394 2.2.6-1
libdca 0.0.6-1
libde265 1.0.5-1
libdmapsharing 2.9.39-2
libdrm 2.4.100-1
libdv 1.0.0-7
libdvdnav 6.0.1-1
libdvdread 6.0.2-1
libe-book 0.1.3-6
libedit 20191231_3.1-1
libelf 0.177-2
libepoxy 1.5.4-1
libepubgen 0.1.1-1
libetonyek 0.1.9-2
libevdev 1.9.0-1
libevent 2.1.11-5
libexif 0.6.21-3
libexttextcat 3.4.5-1
libfdk-aac 2.0.1-1
libffi 3.2.1-4
libfontenc 1.1.4-1
libfreehand 0.1.2-2
libgcrypt 1.8.5-2
libgdata 0.17.12-1
libgdm 3.34.1-2
libgee 0.20.3-2
libgepub 0.6.0-1
libgexiv2 0.12.0-4
libglade 2.6.4-6
libglvnd 1.3.1-1
libgme 0.6.2-1
libgnomekbd 3.26.1+2+g8d02ebd-1
libgpg-error 1.37-1
libgphoto2 2.5.24-1
libgrss 0.7.0+16+g971c421-2
libgsf 1.14.46+3+g7f927f0-1
libgssglue 0.4-4
libgtop 2.40.0+2+g31db82ef-1
libgudev 233-1
libgusb 0.3.4-1
libgweather 3.36.0-1
libgxps 0.3.1-1
libhandy 0.0.13-1
libheif 1.6.2-1
libibus 1.5.22-1
libical 3.0.7-1
libice 1.0.10-2
libid3tag 0.15.1b-9
libidn 1.35-2
libidn2 2.3.0-1
libiec61883 1.2.0-5
libieee1284 0.2.11-8
libimagequant 2.12.6-1
libimobiledevice 1.2.0+87+g92c5462-6
libindicator-gtk3 12.10.1-8
libinput 1.15.3-1
libinstpatch 1.1.3-1
libiptcdata 1.0.4-4
libiscsi 1.19.0-1
libixion 0.15.0-1
libjpeg-turbo 2.0.4-1
libkate 0.4.1-7
libksba 1.3.5-2
liblangtag 0.6.3-1
libldap 2.4.49-1
liblouis 3.13.0-1
liblqr 0.4.2-2
liblrdf 0.6.1-3
libmagick6 6.9.11.0-1
libmediaart 1.9.4+1+ga704d0b-1
libmfx 19.4.0-4
libmm-glib 1.12.6-1
libmms 0.6.4-2
libmng 2.0.3-2
libmnl 1.0.4-3
libmodplug 0.8.9.0-2
libmpc 1.1.0-2
libmpcdec 1:0.1+r475-2
libmpeg2 0.5.1-6
libmspub 0.1.4-6
libmtp 1.1.17-1
libmusicbrainz5 5.1.0-3
libmwaw 0.3.15-1
libmypaint 1.4.0-1
libnautilus-extension 3.36.0-1
libndp 1.7-1
libnet 1.1.6-3
libnetfilter_conntrack 1.0.7-1
libnewt 0.52.21-3
libnfnetlink 1.0.1-3
libnfs 4.0.0-3
libnftnl 1.1.5-1
libnghttp2 1.39.2-2
libnice 0.1.16-1
libnl 3.5.0-2
libnm 1.22.8-1
libnma 1.8.28-1
libnotify 0.7.9-1
libnsl 1.2.0-2
libnumbertext 1.0.5-1
liboauth 1.0.3+14+g186fb14-1
libodfgen 0.1.7-1
libofa 0.9.3-8
libogg 1.3.4-1
libomxil-bellagio 0.9.3-2
liborcus 0.15.3-1
libosinfo 1.7.1-1
libp11-kit 0.23.20-3
libpackagekit-glib 1.1.13-1
libpagemaker 0.0.4-2
libpaper 1.1.28-1
libpcap 1.9.1-2
libpciaccess 0.16-1
libpeas 1.26.0-1
libpgm 5.2.122-5
libphonenumber 8.11.5-1
libpinyin 2.3.0-1
libpipeline 1.5.2-1
libpipewire02 0.2.7-1
libplist 2.1.0-2
libpng 1.6.37-1
libproxy 0.4.15+33+g454a499-1
libpsl 0.21.0-2
libpst 0.6.74-2
libpulse 13.0-3
libpwquality 1.4.2-2
libquvi 0.9.4-5
libquvi-scripts 0.9.20131130-4
libqxp 0.0.2-3
libraqm 0.7.0-1
libraw 0.19.5-2
libraw1394 2.1.2-2
libreoffice-fresh 6.4.1-3
librevenge 0.0.4-2
librsvg 2:2.48.0-1
libsamplerate 0.1.9-3
libsasl 2.1.27-2
libseccomp 2.4.2-1
libsecret 0.20.1-1
libshout 1:2.4.3-2
libsigc++ 2.10.2-1
libslirp 4.1.0-1
libsm 1.2.3-1
libsndfile 1.0.28-3
libsodium 1.0.18-1
libsoup 2.70.0-1
libsoxr 0.1.3-1
libspectre 0.2.8-2
libspeechd 0.9.1-3
libspiro 1:20190731-1
libsrtp 1:2.3.0-1
libssh 0.9.3-1
libssh2 1.9.0-2
libstaroffice 0.0.6-1
libstemmer 0+713-1
libsynctex 2019.51075-7
libtasn1 4.16.0-1
libteam 1.30-1
libthai 0.1.28-1
libtheora 1.1.1-4
libtiff 4.1.0-1
libtiger 0.3.4-5
libtirpc 1.2.5-1
libtommath 1.2.0-1
libtool 2.4.6+42+gb88cebd5-10
libunistring 0.9.10-2
libunwind 1.3.1-1
liburcu 0.11.0-1
libusb 1.0.23-2
libusbmuxd 2.0.1-1
libutil-linux 2.35.1-1
libva 2.6.1-1
libvdpau 1.3-1
libvirt 5.10.0-2
libvirt-glib 3.0.0-1
libvirt-python 5.8.0-3
libvisio 0.1.7-2
libvisual 0.4.0-7
libvncserver 0.9.12-2
libvoikko 4.3-1
libvorbis 1.3.6-1
libvpx 1.8.2-1
libwacom 1.2-1
libwbclient 4.10.10-2
libwebp 1.1.0-1
libwmf 0.2.12-1
libwnck 2.31.0-3
libwpd 0.10.3-1
libwpe 1.4.0.1-1
libwpg 0.3.3-1
libwps 0.4.10-1
libx11 1.6.9-6
libxau 1.0.9-2
libxaw 1.0.13-2
libxcb 1.14-1
libxcomposite 0.4.5-2
libxcursor 1.2.0-1
libxdamage 1.1.5-2
libxdmcp 1.1.3-2
libxext 1.3.4-2
libxfixes 5.0.3-3
libxfont2 2.0.4-2
libxft 2.3.3-1
libxi 1.7.10-2
libxinerama 1.1.4-2
libxkbcommon 0.10.0-1
libxkbcommon-x11 0.10.0-1
libxkbfile 1.1.0-1
libxklavier 5.4-2
libxml2 2.9.10-1
libxmlb 0.1.14-1
libxmu 1.1.3-1
libxnvctrl 440.64-1
libxpm 3.5.13-1
libxrandr 1.5.2-2
libxrender 0.9.10-3
libxres 1.2.0-1
libxshmfence 1.3-1
libxslt 1.1.34-2
libxss 1.2.3-2
libxt 1.2.0-1
libxtst 1.2.3-3
libxv 1.0.11-3
libxvmc 1.0.12-2
libxxf86vm 1.1.4-3
libyaml 0.2.2-1
libytnef 1.9.3+7+g24fe30e-1
libzapojit 0.0.3+14+g2dace3f-1
libzmf 0.0.2-7
licenses 20191011-2
lilv 0.24.6-2
linux 5.5.8.arch1-1
linux-api-headers 5.4.17-1
linux-firmware 20200224.efcfa03-1
linux-headers 5.5.8.arch1-1
llvm-libs 9.0.1-1
lm_sensors 3.6.0-1
lmdb 0.9.24-1
logrotate 3.16.0-1
lollypop 1.2.24-1
lpsolve 5.5.2.5-3
lsb-release 1.4-15
lua 5.3.5-3
lua52 5.2.4-5
lua52-bitop 1.0.2-8
lua52-expat 1.3.0-4
lua52-lpeg 1.0.2-1
lua52-luajson 1.3.4-2
lua52-socket 20190219-1
luajit 2.0.5-2
lv2 1.16.0-3
lvm2 2.02.186-5
lz4 1:1.9.2-2
lzo 2.10-3
m4 1.4.18-3
make 4.3-1
man-db 2.9.1-1
man-pages 5.05-1
materia-gtk-theme 20191017-1
mbedtls 2.16.5-1
md4c 0.4.3-1
mdadm 4.1-2
mesa 19.3.4-2
mesa-demos 8.4.0-2
metis 5.1.0.p8-1
minizip 1:1.2.11-4
mjpegtools 2.1.0-4
mkinitcpio 27-3
mkinitcpio-busybox 1.31.1-1
mobile-broadband-provider-info 20190618-1
mod_dnssd 0.6-7
mousetweaks 3.32.0-1
mpfr 4.0.2-2
mpg123 1.25.13-1
mtdev 1.1.6-1
mtools 4.0.23-1
mutter 3.36.0-1
mypaint-brushes1 1.3.0-1
nano 4.8-1
nautilus 3.36.0-1
nautilus-sendto 3.8.6+14+ge8a3604-1
ncurses 6.2-1
ndctl 67-1
neofetch 7.0.0-1
neon 0.30.2-3
net-snmp 5.8-4
netcf 0.2.8-7
netctl 1.20-2
netease-cloud-music 1.2.1-1
netpbm 10.73.30-1
nettle 3.5.1-2
networkmanager 1.22.8-1
nm-connection-editor 1.16.0-1
noto-fonts 20190926-4
noto-fonts-cjk 20190409-1
noto-fonts-emoji 20191016-4
noto-fonts-extra 20190926-4
npth 1.6-2
nspr 4.25-1
nss 3.51-1
ntfs-3g 2017.3.23-4
numactl 2.0.13-2
nvidia 440.64-2
nvidia-prime 1.0-1
nvidia-settings 440.64-1
nvidia-utils 440.64-2
oath-toolkit 2.6.2-7
openal 1.20.1-2
opencl-headers 2:2.2.20170516-2
opencore-amr 0.1.5-3
openexr 2.4.1-2
openjpeg2 2.3.1-1
openmpi 4.0.3-1
openresolv 3.10.0-1
openssh 8.2p1-3
openssl 1.1.1.d-2
opus 1.3.1-1
orc 0.4.31-1
orca 3.36.1-1
os-prober 1.77-1
osinfo-db 20200214-1
p11-kit 0.23.20-3
packagekit 1.1.13-1
pacman 5.2.1-4
pacman-contrib 1.3.0-1
pacman-mirrorlist 20200207-1
pam 1.3.1-2
pambase 20190105.1-2
pango 1:1.44.7+11+g73b46b04-1
pangomm 2.42.0-1
papirus-icon-theme 20200301-1
parted 3.3-1
patch 2.7.6-8
pciutils 3.6.4-1
pcre 8.43-2
pcre2 10.34-3
pcsclite 1.8.26-1
pepper-flash 32.0.0.344-1
perl 5.30.1-1
perl-error 0.17029-1
perl-mailtools 2.21-2
perl-timedate 2.32-1
phodav 2.4-1
pinentry 1.1.0-5
pipewire 0.3.1-1
pitivi 0.999-3
pixman 0.38.4-1
pkgconf 1.6.3-3
polkit 0.116-5
poppler 0.86.1-1
poppler-data 0.4.9-1
poppler-glib 0.86.1-1
popt 1.16-12
portaudio 1:19.6.0-6
potrace 1.16-1
powerline 2.7-5
powerline-common 2.7-5
powerline-vim 2.7-5
prime-switcher 1.0.2-1
procps-ng 3.3.16-1
protobuf 3.11.4-1
psmisc 23.3-2
pulseaudio 13.0-3
pulseaudio-alsa 2-5
pulseaudio-bluetooth 13.0-3
pygobject-devel 3.36.0-1
pygtk 2.24.0-8
python 3.8.2-1
python-appdirs 1.4.3-5
python-atspi 2.36.0-1
python-attrs 19.3.0-4
python-bcrypt 3.1.7-3
python-beautifulsoup4 4.8.2-1
python-cairo 1.19.1-1
python-cffi 1.14.0-1
python-chardet 3.0.4-4
python-cmd2 0.10.1-1
python-colorama 0.4.3-1
python-cycler 0.10.0-6
python-dateutil 2.8.1-3
python-dbus 1.2.16-1
python-dbus-common 1.2.16-1
python-gobject 3.36.0-1
python-idna 2.9-1
python-kiwisolver 1.1.0-3
python-lxml 4.5.0-1
python-matplotlib 3.2.0-1
python-numpy 1.18.1-1
python-ordered-set 3.1.1-1
python-packaging 20.3-1
python-pillow 6.2.1-1
python-ply 3.11-4
python-powerline 2.7-5
python-pycparser 2.20-1
python-pygments 2.6.1-2
python-pyparsing 2.4.6-1
python-pyperclip 1.7.0-4
python-requests 2.23.0-1
python-setuptools 1:45.3.0-1
python-six 1.14.0-1
python-soupsieve 1.9.5-2
python-urllib3 1.25.8-2
python-wcwidth 0.1.8-1
python-xdg 0.26-4
python2 2.7.17-1
python2-cairo 1.18.2-4
python2-dbus 1.2.16-1
python2-gobject 3.36.0-1
python2-gobject2 2.28.7-4
qemu 4.2.0-2
qt5-base 5.14.1-3
qt5-declarative 5.14.1-1
qt5-wayland 5.14.1-1
qt5-x11extras 5.14.1-1
raptor 2.0.15-12
rasqal 1:0.9.33-2
re2 1:20200303-1
readline 8.0.004-1
redland 1:1.0.17-7
reiserfsprogs 3.6.27-3
rest 0.8.1-1
rpcbind 1.2.5-3
rsync 3.1.3-3
rtkit 0.12-1
rtmpdump 1:2.4.r96.fa8646d-5
run-parts 4.8.6.1-2
rygel 0.38.3-1
s-nail 14.9.17-1
sane 1.0.29-1
sbc 1.4-1
scrcpy 1.12.1-1
sdat2img-git r42.1b08432-1
sdl 1.2.15-13
sdl2 2.0.12-1
seabios 1.13.0-1
sed 4.8-1
serd 0.30.2-1
shadow 4.8.1-1
shared-color-targets 0.1.7-2
shared-mime-info 1.15-2
simple-scan 3.36.0-1
slang 2.3.2-1
smbclient 4.10.10-2
snappy 1.1.8-1
sord 0.16.4-1
sound-theme-freedesktop 0.8-3
soundtouch 2.1.2-1
spandsp 0.0.6-2
speech-dispatcher 0.9.1-3
speex 1.2.0-2
speexdsp 1.2.0-1
spice 0.14.2-1
spice-gtk 0.37-1
sqlite 3.31.1-1
sratom 0.6.4-1
srt 1.4.1-1
startup-notification 0.12-6
sudo 1.8.31-1
suitesparse 5.7.1-1
sushi 3.34.0-1
sysfsutils 2.1.0-11
systemd 245-2
systemd-libs 245-2
systemd-sysvcompat 245-2
t1lib 5.1.2-7
taglib 1.11.1-3
talloc 2.3.1-1
tar 1.32-3
tcl 8.6.10-1
tdb 1.3.18-4
telepathy-glib 0.24.1-2
tepl 4.4.0-1
tevent 1:0.9.39-4
texinfo 6.7-2
thin-provisioning-tools 0.8.5-3
timeshift 19.08.1-2
totem 3.34.1-2
totem-pl-parser 3.26.5-1
tracker 2.3.4-1
tracker-miners 2.3.3-1
transmission-gtk 2.94-2
tslib 1.21-1
ttf-dejavu 2.37-2
ttf-liberation 2.1.0-1
ttf-meslo 1.2.1-1
ttf-nerd-fonts-symbols 2.1.0-1
twolame 0.4.0-2
tzdata 2019c-3
uchardet 0.0.6-2
udisks2 2.8.4-2
uget 2.2.3-1
unzip 6.0-13
upower 0.99.11-1
usbmuxd 1.1.0+69+g8a69f1a-1
usbredir 0.8.0-1
usbutils 012-2
util-linux 2.35.1-1
v4l-utils 1.18.0-1
vde2 2.3.2-13
vi 1:070224-4
vid.stab 1.1-2
vim 8.2.0343-1
vim-runtime 8.2.0343-1
vino 3.22.0+60+gd29a4f2-1
virglrenderer 0.8.2-1
virt-install 2.2.1-2
virt-manager 2.2.1-2
volume_key 0.3.12-2
vte-common 0.60.0-1
vte3 0.60.0-1
vulkan-icd-loader 1.2.132-1
vulkan-intel 19.3.4-2
wavpack 5.2.0-1
wayland 1.18.0-1
wayland-protocols 1.20-1
webkit2gtk 2.28.0-1
webrtc-audio-processing 0.3.1-1
wget 1.20.3-2
which 2.21-5
wildmidi 0.4.3-1
woff2 1.0.2-1
wpa_supplicant 2:2.9-7
wpebackend-fdo 1.4.1-1
x264 3:0.159.r2991.1771b55-1
x265 3.2.1-1
xapps 1.6.10-1
xcb-proto 1.14-1
xcb-util 0.4.0-2
xcb-util-image 0.4.0-2
xcb-util-keysyms 0.4.0-2
xcb-util-renderutil 0.3.9-2
xcb-util-wm 0.4.1-2
xdg-dbus-proxy 0.1.2-1
xdg-user-dirs 0.17-2
xdg-user-dirs-gtk 0.10+9+g5b7efc6-2
xdg-utils 1.1.3+19+g9816ebb-1
xf86-input-libinput 0.29.0-1
xf86-video-intel 1:2.99.917+899+gf66d3954-1
xf86-video-vesa 2.4.0-2
xfsprogs 5.4.0-1
xkeyboard-config 2.29-1
xmlsec 1.2.29-1
xorg-bdftopcf 1.1-1
xorg-docs 1.7.1-2
xorg-font-util 1.3.2-1
xorg-font-utils 7.6-5
xorg-fonts-100dpi 1.0.3-4
xorg-fonts-75dpi 1.0.3-4
xorg-fonts-alias 1.0.3-2
xorg-fonts-encodings 1.0.5-1
xorg-iceauth 1.0.8-1
xorg-luit 1.1.1-3
xorg-mkfontscale 1.2.1-2
xorg-server 1.20.7-1
xorg-server-common 1.20.7-1
xorg-server-devel 1.20.7-1
xorg-server-xephyr 1.20.7-1
xorg-server-xnest 1.20.7-1
xorg-server-xvfb 1.20.7-1
xorg-server-xwayland 1.20.7-1
xorg-sessreg 1.1.2-1
xorg-setxkbmap 1.3.2-1
xorg-smproxy 1.0.6-2
xorg-util-macros 1.19.2-1
xorg-x11perf 1.6.1-1
xorg-xauth 1.1-1
xorg-xbacklight 1.2.3-1
xorg-xcmsdb 1.0.5-2
xorg-xcursorgen 1.0.7-1
xorg-xdpyinfo 1.3.2-3
xorg-xdriinfo 1.0.6-1
xorg-xev 1.2.3-1
xorg-xgamma 1.0.6-2
xorg-xhost 1.0.8-1
xorg-xinput 1.6.3-1
xorg-xkbcomp 1.4.3-1
xorg-xkbevd 1.1.4-2
xorg-xkbutils 1.0.4-3
xorg-xkill 1.0.5-1
xorg-xlsatoms 1.1.3-1
xorg-xlsclients 1.1.4-1
xorg-xmodmap 1.0.10-1
xorg-xpr 1.0.5-1
xorg-xprop 1.2.4-1
xorg-xrandr 1.5.1-1
xorg-xrdb 1.2.0-1
xorg-xrefresh 1.0.6-1
xorg-xset 1.2.4-1
xorg-xsetroot 1.1.2-1
xorg-xvinfo 1.1.4-1
xorg-xwd 1.0.7-1
xorg-xwininfo 1.1.5-1
xorg-xwud 1.0.5-1
xorgproto 2019.2-2
xvidcore 1.3.7-1
xz 5.2.4-2
yajl 2.1.0-2
yay 9.4.6-2
yelp 3.36.0-1
yelp-xsl 3.36.0-1
zbar 0.23-2
zenity 3.32.0+17+gfb0938f-1
zeromq 4.3.2-1
zip 3.0-8
zita-alsa-pcmi 0.3.2-2
zita-resampler 1.6.2-2
zlib 1:1.2.11-4
zsh 5.8-1
zsh-autosuggestions 0.6.4-1
zsh-completions 0.31.0-1
zsh-syntax-highlighting 0.6.0-1
zsh-theme-powerlevel9k 0.6.7-1
zstd 1.4.4-1
zvbi 0.2.35-3
Ok it seems to be a bug, which will be fixed when 3.36.1 releases.
More details
