[SOLVED] Airport Express not detected by Pulseaudio v12.0-1.1
gnome
network
pulseaudio
#1
I recently did a clean install of Manjaro Gnome v17.1.10. Now I’m trying to stream audio to my Airport Express device. Before the reinstall this worked without issues using Pulseaudio and the Pulseaudio RAOP-module.
According to the Pulseaudio release notes, the current version of the RAOP-module has been merged upstream as from Pulseaudio v11.0 (see here: https://www.freedesktop.org/wiki/Software/PulseAudio/Notes/11.0/ und http://hfujita.github.io/pulseaudio-raop2/). I have Pulseaudio v. 12.0-1.1 installed.
In the pulseaudio prefs I have activated detection of Airtunes devices. However, the Airport Express device is not detected, and thus there is no respective sink available to play audio to.
Any ideas?
EDIT: Similar issue here: https://bbs.archlinux.org/viewtopic.php?id=230382 - the solution was to install pulseaudio-zeroconf. However, I have already installed this package and it still doesn’t work
#2
You also have avahi enabled?
Did you reboot after installing zeroconf?
#3
Request was also made here Airport Express wird nicht von Pulseaudio v12.0-1.1 erkannt
Suggested solution was made
#4
Hi Strit,
yes, I did reboot after installing zeroconf.
I was looking into avahi too right now, and it looks like avahi might be the problem indeed. avahi-daemon does not seem to be running. I already have reinstalled avahi and rebooted, but still it doesn’t show up in the list of running processes in the system monitor. How can I set avahi to start up at boot?
#5
Then take a look at the German forum
#6
My bet would be something like:
sudo systemctl enable avahi-daemon or what ever the service is called. :slight_smile:
To start it now without reboot do:
sudo systemctl start avahi-daemon
#7
Thanks, that did the trick!!! now working like a charm
closed #8
