Hello, I was using manjaro and windows10 normally, but after updating manjaro grub has no showed up during the initialization. After executing the command: sudo nano /etc/default/grub sudo update-grub Grub has appeard but does not detect windows10
(sorry for the bad english)
echo GRUB_DISABLE_OS_PROBER=false|sudo tee -a /etc/default/grub && sudo update-grub
If you run into problems after update please visit beforehand Manjaro Forum Stable updates page
It worked! Thank you @plujesz !
