Gnome tweak tool doesn't display properly when the titlebar controls are on the left
As soon as I click on Placement -> Left, the sidebar with categories disappear. Now, every time I open Tweak Tool, I have to make it horizontally larger by just a bit for the side bar to display.
Video here
Some kind of UI bug. Any way to report it upstream? I tried doing some general ducking around for that bug, but didn’t see anything.
It is a known issue. Have you tried making the window wider?
Edit: I read the OP again, the question was irrelevant.
Anyway, here is the relevant issue tracker:
Remember to check if there is already an issue for this before opening a new one.
I figured someone else must have noticed, I just didn’t have any luck finding a bug report for it.
Ok, I’ve found their bug tracker :slight_smile:
Ah, thanks. I found it on my own as well. Thanks again :slight_smile:
