My computer’s cabinet’s (computer casing) HDD light, which should blink a red light while the HDD is in use, is now continually on since I installed Manjaro. Windows has never displayed this behaviour.
Hi @ssbin,
Since you’re posting in the KDE section, I’m presuming that’s your desktop environment, and it might because of Baloo indexing. To check, run the following:
top -b -n 1 | head -n 20
…in a terminal, and please provide the output.
Edit:
Please also run, and provide the output of:
sudo iotop -b -n 1 | head -n 20
If you don’t have iotop
installed, it’s in the community
repository, and can be installed using:
pamac install iotop
Edit #2:
Providing terminal output
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Alternatively, paste the text you wish to format as terminal output, select all pasted text, and click the </> button on the taskbar. This will indent the whole pasted section with one TAB, causing it to render the same way as descrribed above.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
top -b -n 1 | head -n 20 INT ✘
top - 20:51:37 up 29 min, 3 users, load average: 0.50, 0.59, 0.41
Tasks: 191 total, 1 running, 190 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 1.6 sy, 0.0 ni, 96.8 id, 1.6 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 15955.0 total, 12701.7 free, 1592.7 used, 1660.6 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 13986.7 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
41 root 20 0 0 0 0 S 6.7 0.0 0:00.06 ksoftirqd/3
587 rock 20 0 281972 45284 38244 S 6.7 0.3 0:01.44 kglobalaccel5
2681 rock 20 0 830676 94480 76616 S 6.7 0.6 0:00.60 konsole
1 root 20 0 166808 12084 9068 S 0.0 0.1 0:00.74 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_gp
4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_par_gp
5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 netns
7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-events_highpri
9 root 0 -20 0 0 0 I 0.0 0.0 0:00.09 kworker/0:1H-events_highpri
10 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mm_percpu_wq
11 root 20 0 0 0 0 I 0.0 0.0 0:00.58 kworker/u8:1-flush-8:0
12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_tasks_kthre
sudo iotop -b -n 1 | head -n 20 ✔ 14s
Total DISK READ : 0.00 B/s | Total DISK WRITE : 0.00 B/s
Actual DISK READ: 0.00 B/s | Actual DISK WRITE: 0.00 B/s
TID PRIO USER DISK READ DISK WRITE SWAPIN IO COMMAND
1 be/4 root 0.00 B/s 0.00 B/s ?unavailable? init
2 be/4 root 0.00 B/s 0.00 B/s ?unavailable? [kthreadd]
3 be/0 root 0.00 B/s 0.00 B/s ?unavailable? [rcu_gp]
4 be/0 root 0.00 B/s 0.00 B/s ?unavailable? [rcu_par_gp]
5 be/0 root 0.00 B/s 0.00 B/s ?unavailable? [netns]
7 be/0 root 0.00 B/s 0.00 B/s ?unavailable? [kworker/0:0H-events_highpri]
9 be/0 root 0.00 B/s 0.00 B/s ?unavailable? [kworker/0:1H-kblockd]
10 be/0 root 0.00 B/s 0.00 B/s ?unavailable? [mm_percpu_wq]
11 be/4 root 0.00 B/s 0.00 B/s ?unavailable? [kworker/u8:1-events_unbound]
12 be/4 root 0.00 B/s 0.00 B/s ?unavailable? [rcu_tasks_kthre]
13 be/4 root 0.00 B/s 0.00 B/s ?unavailable? [rcu_tasks_rude_]
14 be/4 root 0.00 B/s 0.00 B/s ?unavailable? [rcu_tasks_trace]
15 be/4 root 0.00 B/s 0.00 B/s ?unavailable? [ksoftirqd/0]
16 rt/4 root 0.00 B/s 0.00 B/s ?unavailable? [rcu_preempt]
17 rt/4 root 0.00 B/s 0.00 B/s ?unavailable? [rcub/0]
18 rt/4 root 0.00 B/s 0.00 B/s ?unavailable? [rcuc/0]
19 rt/4 root 0.00 B/s 0.00 B/s ?unavailable? [migration/0]
How to solve this ‘Baloo’?
- Open the Launcher.
- Open System Settings.
3.1. Go to Workspace → Search → File Search.
3.2. Configure as required. (Screenshot of my settings as attached below.)
3.3. Click on the Apply button in the bottom-right corner of the window.
To re-start the index, according to the new settings:
In a terminal, rum the following:
- Disable Baloo
balooctl disable
- Clean all current content:
balooctl purge
- Re-enable Baloo
balooctl enable
- Check that everything is OK:
balooctl check
Note:
It can only be Baloo if the Baloo file indexer is installed and operational, by default this makes it KDE-only. I have no idea if it can be used about/for other D.Es. or what their indexers are even called if they have it.
I’m using kde
