I’m getting locked out of my account on my Thinkpad T560 every time I try to log in. It appears as if the fingerprint reader is failing to scan, although I am not trying to use it. I’m simply trying to log in with my password, but it fails three times very quickly before I can put the password in.
I’ve tried disabling the fingerprint reader in the UEFI as suggested in a previous post, but it makes no difference.
Actually, if you can disassemble the device unplugging the fingerprint reader from motherboard might be a solution (but also might be embedded, depends on manufacturer and models).
Faced the exact same issue. I solved it by removing the fprintd service with ❯ sudo pacman -R fprintd.
No fprintd → No way to use the fingerprint scanner → No errors.
This only works if you don’t use the fingerprint scanner though
