I did this, but found similar non-identical errors. It was recommended to use fsck, but it doesn’t work for me. When I type fsck /dev/sda2 I get the following output
fsck from util-linux 2.38
If you wish to check the consistency of a BTRFS filesystem or repair a damaged filesystem, see btrfs(8) subcommand ‘check’.
when I type fsck /dev/sda2
I get the output:
If you wish to check the consistency of a BTRFS filesystem or repair a damaged filesystem, see btrfs (8) subcommand ‘check’.
