I"am downlad now Ornara and now, VLC, Libre Office with Lyx is closed since a tint2 and file manager. II tried to revert the custom commands but without success. Does anybody to help, please ?
Sorry, i’am not Inxi because my command line is dead Guy
This is hard to understand.
Maybe post in your native language
with a more thorough description
and then run it through Google translate
to have a possibly better english version as well?
I downloaded the last version of Manjaro and now VLC, Ktimer, Libre Office with Lyx is closed. I have tried reverting to custom commands but no luck. Anyone to help, please?
Sorry I can’t provide Inxi because I not have the required command line
The applications is here but with not target: after the install, I added Lyx, Okular, viewnior, Ktimer, VLC and Kpatience. This two last software do not present in my system now and the other softwares is closed
Obviously you have edited some configuration and now you are stuck with no hints of what to do and it appears the same time as a system sync and then you put 1+1=3.
I have no idea what has happened on your system so I suggest you first make a copy
cp -R ~/.config ~/.config.bak
Then copy the default files from /etc/skel/ to your home - overwrite when asked
Ok, I see: the green is bad. I open a session with UXTerm and I find 127 command lines, I answer y for each line but nothing to change for the moment. When I click on the icon of Ktimer, I see the hourglass in short time but everything closed…
I have - again - no idea what you are talking about.
cp -i -R /etc/skel/.* ~
that is a command - don’t mind the colors it was printed in
perhaps it is better to post in your native language, where you can describe the issue better
and then have others use a translator software like google translate
I always wanted to learn french - but never did.
I learned english when I lived in the US of A for a few months.
I never lived in France nor have I been there for more than a few days.
… less than two in total, I think - I was only passing through and could get away with not knowing the language
ps:
one should not assume too much, so here is the reference:
