Thank you all for helping me.
inxi -zv8 brings the following output:
Kernel: 6.12.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=8e2a8dec-9e73-4ded-9ebf-0e405248cc97 rw quiet splash
resume=UUID=b7fd580a-dd40-41ad-ba69-53c6f0893408 udev.log_priority=3
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
serial: part-nu: SKU uuid:
Firmware: UEFI vendor: American Megatrends v: 6042 date: 04/28/2022
System RAM: total: 16 GiB available: 15.53 GiB used: 3.02 GiB (19.5%)
Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Micron Technology
part-no: 8ATF1G64AZ-2G6E1 serial:
Device-2: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
smt: enabled cache: L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB
desc: 8x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2200 min/max: 2200/3400 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 108635
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nvidia v: 580.119.02
alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as of
2025-11; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 07:00.0 chip-ID: 10de:2182
class-ID: 0300
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: MITAC MTC26T42 serial: built: 2008
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 46 gamma: 1.2 chroma: red:
x: 0.655 y: 0.333 green: x: 0.275 y: 0.596 blue: x: 0.141 y: 0.063 white:
x: 0.286 y: 0.294 size: 708x398mm (27.87x15.67") diag: 801mm (31.5")
ratio: 16:9 modes: 1280x720, 1920x1080, 1024x768, 800x600, 720x576,
720x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.119.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 Ti driver: nvidia v: 580.119.02 device-ID: 10de:2182
surfaces: N/A
wl: wayland-info x11: xdpyinfo,xprop
Device-1: NVIDIA TU116 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK
bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.12.62-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
Info: services: NetworkManager, smbd, systemd-timesyncd
WAN IP:
Local Storage: total: 2.29 TiB used: 285.89 GiB (12.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: fw-rev: CC43 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD501LJ
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: fw-rev: 0-13 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 033 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Intenso model: TOP M.2 SATA
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 61.2 scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24D5MT rev: 2.00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 456.43 GiB size: 448.19 GiB (98.20%)
used: 285.89 GiB (63.8%) fs: ext4 dev: /dev/sdd3 maj-min: 8:51
label: Manjaro uuid: 8e2a8dec-9e73-4ded-9ebf-0e405248cc97
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 328 KiB (0.0%) fs: vfat dev: /dev/sdd1 maj-min: 8:49 label: BOOT
uuid: A445-4303
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdd2 maj-min: 8:50 label: Swap
uuid: b7fd580a-dd40-41ad-ba69-53c6f0893408
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: N/A
uuid: 56DBFCD73A308D2A
ID-2: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: ntfs label: N/A
uuid: 2B9EA4610727EC84
ID-3: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs:
label: N/A uuid: N/A
ID-4: /dev/sdc2 maj-min: 8:34 size: 499 MiB fs: ntfs label: N/A
uuid: 84D25EFDD25EF342
ID-5: /dev/sdc3 maj-min: 8:35 size: 100 MiB fs: vfat label: N/A
uuid: B43F-0D17
ID-6: /dev/sdc4 maj-min: 8:36 size: 465.05 GiB fs: ntfs label: N/A
uuid: 9138777A2FE11772
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-5:2 info: YICHIP Wireless Device type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3020 class-ID: 0301
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: SiGma Micro USB Keyboard type: keyboard,HID
driver: sigmamicro,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 98mA chip-ID: 1c4f:0059 class-ID: 0301
Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1706 libs: 398 tools: pamac pm: flatpak pkgs: 0
Processes:
CPU top: 5 of 354
1: cpu: 11.0% command: firefox pid: 5722 mem: 645.7 MiB (4.0%)
2: cpu: 9.7% command: firefox pid: 6138 mem: 375.6 MiB (2.3%)
3: cpu: 5.4% command: kwin_wayland pid: 959 mem: 301.3 MiB (1.8%)
4: cpu: 3.7% command: exe pid: 1652 mem: 540.8 MiB (3.4%)
5: cpu: 0.6% command: plasmashell pid: 1126 mem: 464.6 MiB (2.9%)
Memory top: 5 of 354
1: mem: 645.7 MiB (4.0%) command: firefox pid: 5722 cpu: 11.0%
2: mem: 540.8 MiB (3.4%) command: exe pid: 1652 cpu: 3.7%
3: mem: 464.6 MiB (2.9%) command: plasmashell pid: 1126 cpu: 0.6%
4: mem: 375.6 MiB (2.3%) command: firefox pid: 6138 cpu: 9.7%
5: mem: 301.3 MiB (1.8%) command: kwin_wayland pid: 959 cpu: 5.4%
Processes: 354 Power: uptime: 23m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.3.8 running-in: konsole inxi: 3.3.40
and running vivaldi in the terminal produces the following errors:
[1215/082327.579019:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
c_array_reader.h:64] tag not found
[7677:7677:1215/082328.116256:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:100
1] GPU process exited unexpectedly: exit_code=139
[1215/082328.343579:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[7677:7677:1215/082328.827602:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:100
[1215/082329.051635:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[7677:7677:1215/082329.753162:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:100
[1215/082329.916102:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[7677:7677:1215/082330.603644:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:100
[1215/082330.766661:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[7677:7677:1215/082331.448269:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:100
[1215/082331.608502:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[7677:7677:1215/082332.290852:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:100
[1215/082332.304715:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[7677:7677:1215/082332.702695:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:100
[1215/082332.714978:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[7677:7706:1215/082332.733304:ERROR:chromium/google_apis/gcm/engine/registration_request
.cc:292] Registration response error message: DEPRECATED_ENDPOINT
[7677:7677:1215/082333.072713:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:100
[1215/082333.081850:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[7677:7677:1215/082333.446906:ERROR:chromium/content/browser/gpu/gpu_process_host.cc:100
[7677:7677:1215/082333.446925:FATAL:chromium/content/browser/gpu/gpu_data_manager_impl_p
rivate.cc:415] GPU process isn’t usable. Goodbye.
[1215/082333.453586:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.461976:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.463450:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.463628:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.463756:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.469988:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.472208:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.472436:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.472507:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.472987:ERROR:chromium/third_party/crashpad/crashpad/snapshot/elf/elf_dynami
[1215/082333.473578:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_me
mory_range.cc:75] read out of range
[1215/082333.473591:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_me
[1215/082333.483124:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_me
[1215/082333.483141:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_me
[1215/082333.483158:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_me
[1215/082333.483166:ERROR:chromium/third_party/crashpad/crashpad/util/process/process_me
zsh: trace trap (core dumped) vivaldi
Mod edit:- Pre-formatted text display partially corrected.
Please re-read How to Post Command Output as Preformatted Text
