Snap plugin NOT working
I have inputted these commands into the terminal:
pamac install snapd libpamac-snap-plugin
sudo systemctl enable --now snapd.socket
sudo ln -s /var/lib/snapd/snap /snap
I also inputted these commands aswell:
sudo pacman -S snapd
Snap support appears in the preference menu an pamac BUT it does not show any snaps listed when input name of apps (apps that I know exist as snap packages)
I think you missed something from the same place you got the rest from. :wink:
Either log out and back in again, or restart your system, to ensure snap’s paths are updated correctly.
I have tried this but it still seems not to work.
