Hello,
I tried to install lxd using snap. (btw I did install and configure snap using the manjaro howto in this forum)
sudo snap install lxd
Start snap "lxd" (25945) services
and the command is hanging at the line Start snap lxd (25945) services.
when I tried to see which services are being used
sudo systemctl -a | grep lxd
run-snapd-ns-lxd.mnt.mount loaded active mounted /run/snapd/ns/lxd.mnt
var-lib-snapd-snap-lxd-25945.mount loaded active mounted Mount unit for lxd, revision 25945
snap.lxd.activate.service loaded activating start start Service for snap application lxd.activate
snap.lxd.daemon.service loaded inactive dead Service for snap application lxd.daemon
snap.lxd.user-daemon.service loaded inactive dead Service for snap application lxd.user-daemon
snap.lxd.daemon.unix.socket loaded active listening Socket unix for snap application lxd.daemon
snap.lxd.user-daemon.unix.socket loaded active listening Socket unix for snap application lxd.user-daemon
It seems to be the 3rd service which is blocking snap . I regain control in the shell when I stop this service. However, the installation of lxd fails every time
the corresponding entries in journalcntl:
Okt 23 21:56:38 clevo systemd[1]: Started snap.lxd.hook.install-988b7605-4006-4a15-b4cc-7fb062902ac5.scope.
Okt 23 21:56:38 clevo systemd[1]: snap.lxd.hook.install-988b7605-4006-4a15-b4cc-7fb062902ac5.scope: Deactivated successfully.
Okt 23 21:56:38 clevo systemd[1]: Listening on Socket unix for snap application lxd.daemon.
Okt 23 21:56:38 clevo systemd[1]: Listening on Socket unix for snap application lxd.user-daemon.
Okt 23 21:56:38 clevo systemd[1]: Starting Service for snap application lxd.activate...
What else can I do? Any Idea will be gladly welcome
Cheers Julia
