Smooth touchpad zoom in with xfce (super/meta + not worked)
I read several posts related to 2-finger pinch for zoom in and out, but it seems to work in KDE but not xfce, so I am wondering what I can do for that? The comands below works well for Ctrl+plus/minus, but it’s very choppy, and using super/meta instead of Ctrl had no effect. The zoom desktop effect is also working, by Alt with mouse scrolling, but it seems not for an application window zoom in/out. Any help here?
gesture: pinch out xdotool key Ctrl+plus
gesture: pinch in xdotool key Ctrl+minus
Machine info
  Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
    root=UUID=17a57bc5-4569-4d1b-8454-2c7d491f058c rw quiet apparmor=1
    security=apparmor udev.log_priority=3 snd_hda_intel.power_save=0
    button.lid_init_state=open
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29
    info: xfce4-panel, plank, vala-panel wm: xfwm v: 4.16.1 vt: 7 dm: LightDM
    v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Razer product: Blade 15 (2022) - RZ09-0421 v: 8.04
  Mobo: Razer model: CH580 v: 4 serial: <superuser required> UEFI: Razer
    v: 1.09 date: 02/22/2022
  ID-1: BAT0 charge: 81.8 Wh (100.0%) condition: 81.8/80.2 Wh (102.0%)
    volts: 17.4 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
    status: full
  ID-2: hidpp_battery_0 charge: 20% condition: N/A volts: 3.7 min: N/A
    model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
    serial: <filter> status: discharging
  Info: model: 12th Gen Intel Core i7-12800H bits: 64 type: MST AMCP
    arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x41C
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1111 high: 2238 min/max: 400/2400:1800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1084 2: 843 3: 579
    4: 1938 5: 2238 6: 1765 7: 473 8: 842 9: 437 10: 660 11: 1419 12: 986
    13: 629 14: 1548 15: 1800 16: 1283 17: 1481 18: 529 19: 835 20: 853
    bogomips: 112160
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Razer USA
    driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
    chip-ID: 8086:46a6 class-ID: 0300
  Device-2: NVIDIA GA103M [GeForce RTX 3080 Ti Laptop GPU] vendor: Razer USA
    driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-05) arch: Ampere pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:2460 class-ID: 0300
  Device-3: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo
    bus-ID: 1-2:2 chip-ID: 13d3:5279 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
    compositor: xfwm v: 4.16.1 driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 4608x1985 s-dpi: 96 s-size: 1219x525mm (47.99x20.67")
    s-diag: 1327mm (52.25")
  Monitor-1: HDMI-1-0 pos: primary,top-right res: 2560x1440 hz: 60 dpi: 108
    size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
  Monitor-2: eDP-1 pos: bottom-l res: 2048x1152 hz: 60 dpi: 151
    size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Razer USA
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  Device-2: NVIDIA vendor: Razer USA driver: N/A alternate: snd_hda_intel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2288 class-ID: 0403
  Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.51 running: yes
  Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:6
    chip-ID: 8087:0033 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 953.87 GiB used: 164.37 GiB (17.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVMe CA6-8D1024 size: 953.87 GiB
    block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
    type: SSD serial: <filter> rev: ERA0902 temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 672.78 GiB size: 661.15 GiB (98.27%)
    used: 164.32 GiB (24.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 50.7 MiB (52.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 27.8 C mobo: N/A
  Processes: 431 Uptime: 1h 30m wakeups: 16 Memory: 31.04 GiB
  used: 4.54 GiB (14.6%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 12.1.0 clang: 13.0.1 Packages: 1457 pacman: 1438 lib: 333 flatpak: 10
  snap: 9 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.16
