Is it is a hdd and not an sdd it is possible with hdparm.
I don’t know the exact command from the top of my head, will come back to it in a moment (unless you find it sooner )
Ahh oke
Oke seems hdparm low level format cam be done on both SDD and HDD, but… it is completely at your own risk.
start with installing hdparm
making sure the disk is NOT mounted.
next
sudo hdparm -I /dev/sdX
to check if the disk is frozen or not. If so you need to unfreeze it.
next
sudo hdparm --security-set-pass NULL /dev/sdX
then
sudo time hdparm --user-master u --security-erase NULL /dev/sdX
Finally remove the password,
hdparm --security-unlock NULL /dev/sdX
check if all is good
done
Ahhh i remember reading those commands somewhere indeed, didn’t know they were for low-level format
I will try when the current offline test has ended…
In worst case that external HD will become useless, which won’t matter in current state
I seem to get some errors:
This one is from the erase command:
SG_IO: bad/missing sense data, sb[]: 70 00 05 00 00 00 00 0a 00 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
These are from the unlock command although it works successfully as can be seen in the output of the info command:
The running kernel lacks CONFIG_IDE_TASK_IOCTL support for this device.
SECURITY_UNLOCK: Invalid argument
I know which command gave what error because i saw them when using the commands on their own in terminal
#!/bin/env bash
# ~/.local/bin/low-level-format-drive
function help () {
printf "%b\n" \
"\nUsage: ${0##*/} <drive> [<u|m>] [<password>]" \
"Where:" \
"\t<drive>\t= drive name with or without '/dev/' prepended." \
"\t<u|m>\t= Selection of user (default) or master password." \
"\t<password> = Password to use, defaults to '0123456789'"
exit 1
if test $(id -u) -ne 0; then
printf "%s\n" "Need root !"
help
fi
drv="/dev/${1##*/}";
drvpass="${2:-u}"
pass="${3:-0123456789}"
# pass="${3:-NULL}"
# printf "%s\n" "$drv" "$drvpass" "$pass"
if test ! -b "$drv"; then
printf "%s\n" "You need to provide a valid drive path !"
help
elif test "$drvpass" != "u" -a "$drvpass" != "m"; then
printf "%s\n" "Invalid password type selected !"
help
fi
exec 2>&1
hdparm --user-master "$drvpass" --security-set-pass "$pass" "$drv"
time hdparm --user-master "$drvpass" --security-erase-enhanced "$pass" "$drv"
hdparm --user-master "$drvpass" --security-unlock "$pass" "$drv"
hdparm --user-master "$drvpass" --security-disable "$pass" "$drv"
hdparm -I "$drv"
security_password: "0123456789"
/dev/sde:
Issuing SECURITY_SET_PASS command, password="0123456789", user=user, mode=high
/dev/sde:
Issuing SECURITY_ERASE command, password="0123456789", user=user
real 0m30.087s
user 0m0.000s
sys 0m0.002s
/dev/sde:
Issuing SECURITY_UNLOCK command, password="0123456789", user=user
/dev/sde:
Issuing SECURITY_DISABLE command, password="0123456789", user=user
/dev/sde:
ATA device, with non-removable media
Model Number: TOSHIBA MQ01ABB200
Serial Number: <filtered out by me>
Firmware Revision: AY000U
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6
Standards:
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 3907029168
Logical Sector size: 512 bytes
Physical Sector size: 4096 bytes
Logical Sector-0 offset: 0 bytes
device size with M = 1024*1024: 1907729 MBytes
device size with M = 1000*1000: 2000398 MBytes (2000 GB)
cache/buffer size = 8192 KBytes
Form Factor: 2.5 inch
Nominal Media Rotation Rate: 5400
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Advanced power management level: 128
DMA: sdma0 sdma1 sdma2 mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
Security Mode feature set
* Power Management feature set
Write cache
* Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
SET_MAX security extension
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* WRITE_{DMA|MULTIPLE}_FUA_EXT
* 64-bit World wide name
* IDLE_IMMEDIATE with UNLOAD
* WRITE_UNCORRECTABLE_EXT command
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Host-initiated interface power management
* Phy event counters
* Idle-Unload when NCQ is active
DMA Setup Auto-Activate optimization
Device-initiated interface power management
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Write Same (AC2)
* SCT Error Recovery Control (AC3)
* SCT Features Control (AC4)
* SCT Data Tables (AC5)
Security:
Master password revision code = 4
supported
not enabled
not locked
not frozen
not expired: security count
supported: enhanced erase
434min for SECURITY ERASE UNIT. 434min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: <filtered out by me>
NAA : 5
IEEE OUI : 000039
Unique ID : <filtered out by me>
Checksum: correct
