Hi to you all.
I’ve been enjoying kde manjaro for a year now and never had any troubles. For fun I have been distro hopping but came back to manjaro. Now with the latest distro iso i get a very slow desktop. All programs take a while to start or glitches. I tried the Gnome version, this worked perfectly, but I don’t like Gnome. So I downloaded it again, but I got the same slow, slow desktop.
Does anyone can help me with this? It would be very much apreciated!
Hello,
Someone could help you once there is the technical information about your system added to your post.
See here [HowTo] Receive better support
Thank you. Here is what came up:
arja-vivobook% inxi -v7azy
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6e06c573-5f50-4817-ae23-e9a86d6f0edc rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X512FA_A512FA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X512FA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X512FA.304 date: 08/26/2019
ID-1: BAT0 charge: 27.2 Wh (100.0%) condition: 27.2/37.1 Wh (73.3%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 140
RAM: total: 7.62 GiB used: 4.55 GiB (59.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i3-8145U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 built: 2018
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xC (12)
microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3668 high: 3701 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 3700 2: 3575 3: 3699
4: 3701 bogomips: 18406
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: ASUSTeK
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 13d3:56d3 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Najing CEC Panda 0x0046 built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 134.41 GiB (28.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 53.9 C scheme: GPT
ID-1: / raw-size: 141.37 GiB size: 138.09 GiB (97.68%) used: 9.76 GiB (7.1%)
fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6e06c573-5f50-4817-ae23-e9a86d6f0edc
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 645A-8743
ID-3: /home raw-size: 323.56 GiB size: 317.41 GiB (98.10%) used: 122.98
GiB (38.7%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 36033551-65cc-4e26-a437-32b50c072043
ID-1: swap-1 type: partition size: 11.72 GiB used: 1.67 GiB (14.3%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: e3baad61-602e-438d-a2b7-cd08a7e6c2e5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Shenzhen Rapoo E9260 Wireless Multi-mode Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 24ae:1813 class-ID: 0301
Device-2: 1-6:4 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-3: 1-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 69.0 C pch: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2100
Processes: 212 Uptime: 38m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1217 libs: 317 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
arja-vivobook%
I hope this is what you need.
did it happened also in live usb of manjaro kde? or only in the installation?
try differen kernels - 5.10 and 5.19
Hi, thanks for your help. The problem only exists on installation. I have tried both 5.10 and 5.19. But the problem stays. I have search the internet and came with realtime kernels what could help. Only, the realtime kernel would be a downgrade. From 5.19.7-1 to 5.19.0_rt10_3. I have installed this kernel, but how do I get it activ?
*Edit: I have booted in the grub rescue and there I could choose the kernel. It is a little bit better, but not as snappy as it used to be for me
you get it active the same way as you did when you tried the 5.10 and the 5.19, you install them, and select them in the grub menu/advanced options during boot
Yes, I have the rtl kernel now running. But the problem exists anyway.
go to system settings/file search and uncheck all of the search option, click apply; if it didnt helped, provide logs:
journalctl -b0 -p4 --no-pager
uncheck the search option was the solution! It also made my cpu running much lower and the laptop less hot. Thank you very much for your help!
