Hi!
First of all, yes, this question was asked already 100 times or so. However, I am not able to fix this problem.
My wifi download should be about 50 Mbit/s and upload 10 Mbit/s. Speedtest results show download 2 Mbit/s and upload 10 Mbit/s. So, the download is kinda problematic.
inxi -Fazy
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=2d0d015d-af78-49a8-9743-1e6e3b764716 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: Dell product: Inspiron 5406 2n1 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: Dell model: 0VMRNH v: A00 serial: <superuser required> UEFI: Dell
v: 1.16.0 date: 07/14/2022
ID-1: BAT0 charge: 30.3 Wh (100.0%) condition: 30.3/39.8 Wh (76.0%)
volts: 12.6 min: 11.2 model: SMP DELL C5KG60A type: Li-poly serial: <filter>
status: full
Device-1: hid-0018:04F3:2A82.0001-battery model: CUST0000:00 04F3:2A82
serial: N/A charge: N/A status: N/A
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 788 high: 1100 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 813 3: 735 4: 1009
5: 563 6: 1100 7: 741 8: 948 bogomips: 27040
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:671b class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d4 built: 2017 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 953.87 GiB used: 10.19 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM981a NVMe
1024GB size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 15305129
temp: 37.9 C scheme: GPT
ID-1: / raw-size: 128 GiB size: 124.93 GiB (97.60%) used: 10.14 GiB (8.1%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 56.9 MiB
(59.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 248 Uptime: 22m wakeups: 2910 Memory: 15.36 GiB used: 2.34 GiB
(15.3%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1213 libs: 317
tools: pamac,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.21
I already looked at this but found nothing helpful: forum.manjaro org/t/wifi-is-slower-than-my-windows-install/86988
Also tried everything mentioned here: forum.manjaro org/t/wifi-is-slower-than-my-windows-install/86988
File: /etc/modprobe.d/iwlwifi.conf
options iwlwifi swcrypto=1
options iwlwifi power_save=0
options iwlwifi 11n_disable=1
options iwlwifi disable_11ac=1
options iwlwifi disable_11ax=1
latest helped to get a download speed of 20 Mbit/s which are still less than it should be.
please help D:
