Slow Wi-Fi on Manjaro Linux 26.1.3 with rtl8821ae
Hello, everyone! This is MichaelTechLinux.
For example, Laptop B is located 5 - 6 meters away from Laptop A. Laptop B with Manjaro XFCE has rtl8821ae driver. I noticed internet speed via Wi-Fi with rtl8821ae is slow despite it can run at speeds 150 Mb/s. Sometimes pages can’t load properly even if Wi-Fi is on. Restarting NetworkManager solves the problem for 30 - 60 seconds approximately, and then the problem repeats.
Here is the output of inxi -N
❯ inxi -N
  Device-1: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
    driver: rtl8821ae
    driver: r8169
I did the following command and added two lines (on iwlwifi it is easier, but with rtl driver I think it is harder, but I tried):
sudo nano /etc/NetworkManager/conf.d/powersave.conf
❯ cat /etc/NetworkManager/conf.d/powersave.conf
[connection]
wifi.powersave = 2
But on Laptop A after pinging Laptop B’s IP address there is still unstable latency (34, 4, 4, 6, 4, 110, long pause, unreachable, 4, 4, 5, 6, 112, 101, unreachable and etc.).
Could you please tell me how to solve this problem? I have been trying to fix it for two hours.
Have you restarted the NetworkManager service afterward?
$ sudo systemctl restart NetworkManager
Yes, I have restarted the NetworkManager afterward. There are some improvements with speed, but they’re not enough. After restarting NetworkManager rtl8821ae Wi-Fi is still unstable. On iwiwifi it works correctly. What can be wrong with rtl8821ae?
You could try to disable IPv6 and to focus on 5 GHz, too.
That output may be lacking some relevant information.
Please provide the output of either inxi -zv8 (preferred) or inxi -Nxxxz (which provides more detailed information about your network devices).
Here is the output of inxi -zv8
❯ inxi -zv8
  Kernel: 7.2.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.2-x86_64
    root=UUID=131b9b58-ea7a-4688-b829-30b5816dd047 rw rootflags=subvol=@
    quiet apparmor=1 security=apparmor loglevel=3 rd.udev.log_level=3
  Desktop: Xfce v: 4.20.2 tk: Gtk v: 3.24.52 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.33.1
  Type: Laptop System: LENOVO product: 80XS v: Lenovo ideapad 320-15ABR
    serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 320-15ABR
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40679WIN
    part-nu: LENOVO_MT_80XS_BU_idea_FM_ideapad 320-15ABR
    uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: 5QCN16WW
    date: 05/22/2017
  System RAM: total: 6 GiB available: 5.3 GiB used: 1.42 GiB (26.8%)
  Array-1: capacity: 64 GiB note: check slots: 2 modules: 2 EC: None
    (unregistered) size: 2 GiB speed: spec: 1866 MT/s actual: 933 MT/s volts:
    note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471A5644EB0-CRC serial: <filter>
    (unregistered) size: 4 GiB speed: spec: 1866 MT/s actual: 933 MT/s volts:
    manufacturer: Samsung part-no: M471A5244CB0-CRC serial: N/A
  Info: model: AMD A10-9620P RADEON R5 10 COMPUTE CORES 4C+6G bits: 64
    type: MCP arch: Excavator level: v3 note: check built: 2015 process: GF 28nm
    family: 0x15 (21) model-id: 0x65 (101) stepping: 1 microcode: 0x6006118
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
    L1: 320 KiB desc: d-4x32 KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 1293 min/max: 1300/2500 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1293 2: 1293 3: 1293
    4: 1293 bogomips: 19960
  Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
    bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
    cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4
    fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm lwp mca mce
    misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
    pse36 ptsc rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xop xsave xsaveopt
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Type: vmscape status: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Wani [Radeon R5/R6/R7 Graphics]
    vendor: Lenovo driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
    process: TSMC 28nm built: 2014-19 ports: active: eDP-1
    empty: DP-1,HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9874 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Topaz XT [Radeon R7 M260/M265
    / M340/M360 M440/M445 530/535 620/625 Mobile] vendor: Lenovo
    process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s bus-ID: 03:00.0 chip-ID: 1002:6900
    class-ID: 0380 temp: 42.0 C
  Device-3: IMC Networks EasyCamera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.2:4 chip-ID: 13d3:5a02
  Display: x11 server: X.org v: 1.21.1.24 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: BOE Display 0x0729 built: 2017 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.345 green: x: 0.329 y: 0.573
    blue: x: 0.149 y: 0.114 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon R5 Graphics (radeonsi carrizo ACO
    DRM 3.64 7.2.9-1-MANJARO) device-ID: 1002:9874 memory: 500 MiB
    unified: yes
  Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xprop
  Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:01.1
    chip-ID: 1002:9840 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 15h Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
    class-ID: 0403
  API: ALSA v: k7.2.9-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.9 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: rtl8821ae v: kernel modules: wl pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8821
    class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: Realtek RTL8821A Bluetooth driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.1:3 chip-ID: 0bda:0821
  Local Storage: total: 465.76 GiB used: 5.48 GiB (1.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545050KTA300
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: BKFO scheme: GPT
  ID-1: / raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
    used: 5.47 GiB (1.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 131b9b58-ea7a-4688-b829-30b5816dd047
    used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: E21D-38D8
  ID-3: /home raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-4: /var/cache raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  ID-5: /var/log raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
  Device-1: 1-3:2 info: JMicron / USA JM20329 SATA Bridge type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 2mA chip-ID: 152d:2329 class-ID: 0806
    serial: <filter>
  Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-3: 2-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
    chip-ID: 0438:7900 class-ID: 0900
  Device-1: 2-1.1:3 info: Realtek RTL8821A Bluetooth type: bluetooth
    driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:0821 class-ID: e001 serial: <filter>
  Device-2: 2-1.2:4 info: IMC Networks EasyCamera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5a02 class-ID: 0e02
    serial: <filter>
  Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 34.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 34.0 C device: amdgpu temp: N/A
  Packages: pm: pacman pkgs: 1117 libs: 350 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.hiesoft.net/manjaro/stable/$repo/$arch
    2: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 285
  1: cpu: 30.8% command: firefox pid: 2827 mem: 480.5 MiB (8.8%)
  2: cpu: 25.0% command: ps pid: 3533 mem: 3.72 MiB (0.0%)
  3: cpu: 6.9% command: firefox pid: 3000 mem: 170.5 MiB (3.1%)
  4: cpu: 3.5% command: Xorg pid: 811 mem: 107.4 MiB (1.9%)
  5: cpu: 2.3% command: firefox pid: 3121 mem: 114.7 MiB (2.1%)
  Memory top: 5 of 285
  1: mem: 480.5 MiB (8.8%) command: firefox pid: 2827 cpu: 30.8%
  2: mem: 170.5 MiB (3.1%) command: firefox pid: 3000 cpu: 6.9%
  3: mem: 125.1 MiB (2.3%) command: firefox pid: 3172 cpu: 1.6%
  4: mem: 115.0 MiB (2.1%) command: xfwm4 pid: 1166 cpu: 1.8%
  5: mem: 114.7 MiB (2.1%) command: firefox pid: 3121 cpu: 2.3%
  Processes: 285 Power: uptime: 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.06 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 261 default: graphical tool: systemctl
  Compilers: gcc: 16.2.1 Shell: Zsh v: 5.9.2 running-in: xfce4-terminal
    inxi: 3.3.41
There is a BIOS update available:
https://pcsupport.lenovo.com/de/de/products/laptops-and-netbooks/300-series/320-15abr/downloads/driver-list/component?name=BIOS&id=5AC6A815-321D-440E-8833-B07A93E0428C
You have not much RAM, in your case I would establish a small swap partition of at least 6 GiB.
You could be on a crowded channel. LinSSID is good for checking this. :wink:
Sounds suspiciously like my problem here: WiFi receive bitrate drops after approx 5 minutes QCA6174; and I secretly hope it is because that means it’s reproducible on another card.
I have mine working correctly by removing the CONFIG_NAN_USD from the build but am yet to trace exactly where the issue is. I can share the package if you don’t want to build it yourself.
Alternatively, dropping wpa_supplicant to version 6.11 would also work as it doesn’t include CONFIG_NAN_USD.
Have environmental issues been ruled out?
