I dont know why my system is very slow with wifi-6 connections. I will share the details below:-
inxi -Fazy
Kernel: 5.16.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.16-x86_64
root=UUID=fc2e3534-fcf8-40a3-af0e-283bdf105cc9 rw rootflags=subvol=@ quiet
udev.log_priority=3
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.31 info: plank vt: 7
Type: Laptop System: ASUSTeK product: X542UQR v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X542UQR v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X542UQR.309 date: 05/21/2019
ID-1: BAT0 charge: 20.5 Wh (100.0%) condition: 20.5/38.0 Wh (54.0%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 868
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 903 high: 1675 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 907 3: 1675 4: 929
5: 800 6: 800 7: 713 8: 701 bogomips: 28808
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:134d class-ID: 0302
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:5a01 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 driver: loaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.5
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.45 running: yes
vendor: ASUSTeK driver: r8169 v: kernel modules: r8168 port: d000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel bus-ID: 03:00.0 chip-ID: 168c:0036
class-ID: 0280
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
chip-ID: 04ca:3018 class-ID: e001
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 1 state: down
bt-service: disabled rfk-block: hardware: no software: no address: N/A
Local Storage: total: 1.82 TiB used: 124.02 GiB (6.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 3D scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO M.2 1TB
type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-1: / raw-size: 192.57 GiB size: 192.57 GiB (100.00%)
used: 21.28 GiB (11.1%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /boot/efi raw-size: 320.7 MiB size: 320 MiB (99.80%)
used: 568 KiB (0.2%) fs: vfat dev: /dev/sdb3 maj-min: 8:19
ID-3: /home raw-size: 738.63 GiB size: 738.63 GiB (100.00%)
used: 102.74 GiB (13.9%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 192.57 GiB size: 192.57 GiB (100.00%)
System Temperatures: cpu: 47.0 C pch: 43.5 C mobo: N/A
Fan Speeds (RPM): cpu: 2500
Processes: 313 Uptime: 35m wakeups: 1 Memory: 7.65 GiB
used: 2.32 GiB (30.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1309 lib: 376 flatpak: 0
Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.12
