My department upgraded their routers and its a wifi6 connectivity where i am facing very slow connection speed in manjaro. I dont know if its a hardware spec or a driver issue. It connects to the router and the speed is very low. i get only 2mbps where others get 192mbps average!!!
i will share my driver details below.
supporting an 802.11n connection at up to 72.2 Mbps for 20 MHz and 150 Mbps for 40 MHz channel operations respectively, and IEEE 802.11a/b/g data rates.
If only 802.11ax is enabled on the router, then I assume that your wifi device will you use the 802.11a standard. But not sure. However, that could explain the low transfer rates.
Using the 5 GHz band gives 802.11a a significant advantage, since the 2.4 GHz band is heavily used to the point of being crowded. Degradation caused by such conflicts can cause frequent dropped connections and degradation of service.
