Slow PC, FSCK runs at every boot and login appears after some minutes
I am trying to figure out why fsck is run at every boot getting into login screen after a while.
lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINTS
sda           8:0    0   2.7T  0 disk
└─md127       9:127  0   2.7T  0 raid1
  └─md127p1 259:3    0   2.7T  0 part
sdb           8:16   0 465.8G  0 disk
└─sdb1        8:17   0 465.8G  0 part
  └─md0       9:0    0 931.3G  0 raid0 /home
sdc           8:32   0   2.7T  0 disk
sdd           8:48   0 465.8G  0 disk
└─sdd1        8:49   0 465.8G  0 part
sde           8:64   1     0B  0 disk
nvme0n1     259:0    0 232.9G  0 disk
├─nvme0n1p1 259:1    0     1G  0 part  /boot/efi
└─nvme0n1p2 259:2    0 231.9G  0 part  /
sudo journalctl -xb | grep fsck         ✔
Jun 07 12:32:26 user-PC systemd[1]: Created slice Slice /system/systemd-fsck.
░░ Subject: A start job for unit systemd-fsck-root.service has finished successfully
░░ A start job for unit systemd-fsck-root.service has finished successfully.
░░ Subject: A start job for unit systemd-fsck@dev-disk-by\x2duuid-6ad93ea3\x2dd6cc\x2d4281\x2db613\x2d15b34d0f35f5.service has begun execution
░░ A start job for unit systemd-fsck@dev-disk-by\x2duuid-6ad93ea3\x2dd6cc\x2d4281\x2db613\x2d15b34d0f35f5.service has begun execution.
░░ Subject: A start job for unit systemd-fsck@dev-disk-by\x2duuid-BC31\x2d04FB.service has begun execution
░░ A start job for unit systemd-fsck@dev-disk-by\x2duuid-BC31\x2d04FB.service has begun execution.
░░ Subject: A start job for unit systemd-fsck@dev-disk-by\x2duuid-b883af5c\x2df50a\x2d4d7c\x2daf28\x2d77a6a86c2ad9.service has begun execution
░░ A start job for unit systemd-fsck@dev-disk-by\x2duuid-b883af5c\x2df50a\x2d4d7c\x2daf28\x2d77a6a86c2ad9.service has begun execution.
Jun 07 12:32:26 user-PC systemd-fsck[663]: fsck.fat 4.2 (2021-01-31)
Jun 07 12:32:26 user-PC systemd-fsck[663]: /dev/nvme0n1p1: 5 files, 74/261876 clusters
░░ Subject: A start job for unit systemd-fsck@dev-disk-by\x2duuid-BC31\x2d04FB.service has finished successfully
░░ A start job for unit systemd-fsck@dev-disk-by\x2duuid-BC31\x2d04FB.service has finished successfully.
Jun 07 12:32:26 user-PC systemd-fsck[662]: /dev/md127p1: clean, 19/183140352 files, 11840743/732533248 blocks
░░ Subject: A start job for unit systemd-fsck@dev-disk-by\x2duuid-b883af5c\x2df50a\x2d4d7c\x2daf28\x2d77a6a86c2ad9.service has finished successfully
░░ A start job for unit systemd-fsck@dev-disk-by\x2duuid-b883af5c\x2df50a\x2d4d7c\x2daf28\x2d77a6a86c2ad9.service has finished successfully.
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: Fix the reported corruption.
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: MKFS version
Jun 07 12:34:47 user-PC systemd-fsck[661]:   "Linux version 6.9.2-1-MANJARO (builduser@fv-az1434-290) (gcc (GCC) 14.1.1 20240522, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Mon May 27 03:56:18 UTC 2024"
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: FSCK version
Jun 07 12:34:47 user-PC systemd-fsck[661]:   from "Linux version 6.9.2-1-MANJARO (builduser@fv-az1434-290) (gcc (GCC) 14.1.1 20240522, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Mon May 27 03:56:18 UTC 2024"
Jun 07 12:34:47 user-PC systemd-fsck[661]:     to "Linux version 6.9.2-1-MANJARO (builduser@fv-az1434-290) (gcc (GCC) 14.1.1 20240522, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Mon May 27 03:56:18 UTC 2024"
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: superblock features = 0 :
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: fs errors: invalid_blkaddr
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: Segments per section = 1
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: Sections per zone = 1
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: total FS sectors = 1953015808 (953621 MB)
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: CKPT version = 240e3aee
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: Checked valid nat_bits in checkpoint
Jun 07 12:34:47 user-PC systemd-fsck[661]: Info: checkpoint state = c5 :  nat_bits crc compacted_summary unmount
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 1 / 778999 (0.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 77900 / 778999 (10.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 155799 / 778999 (20.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 233698 / 778999 (30.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 311597 / 778999 (40.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 389496 / 778999 (50.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 467395 / 778999 (60.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 545294 / 778999 (70.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 623193 / 778999 (80.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 701092 / 778999 (90.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Check node 778991 / 778999 (100.00%)
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Max image size: 508896 MB, Free space: 444724 MB
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Unreachable nat entries                        [Ok..] [0x0]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] SIT valid block bitmap checking                [Ok..]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] Hard link checking for regular file            [Ok..] [0x3309]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] valid_block_count matching with CP             [Ok..] [0x7bb9fab]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] valid_node_count matching with CP (de lookup)  [Ok..] [0xbe2f7]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] valid_node_count matching with CP (nat lookup) [Ok..] [0xbe2f7]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] valid_inode_count matched with CP              [Ok..] [0xa4ed7]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] free segment_count matched with CP             [Ok..] [0x321d8]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] next block offset is free                      [Ok..]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] fixing SIT types
Jun 07 12:34:47 user-PC systemd-fsck[661]: [FSCK] other corrupted bugs                           [Ok..]
Jun 07 12:34:47 user-PC systemd-fsck[661]: [update_superblock: 765] Info: Done to update superblock
Jun 07 12:34:47 user-PC systemd-fsck[661]: Done: 140.846780 secs
░░ Subject: A start job for unit systemd-fsck@dev-disk-by\x2duuid-6ad93ea3\x2dd6cc\x2d4281\x2db613\x2d15b34d0f35f5.service has finished successfully
░░ A start job for unit systemd-fsck@dev-disk-by\x2duuid-6ad93ea3\x2dd6cc\x2d4281\x2db613\x2d15b34d0f35f5.service has finished successfully.
Jun 07 12:37:14 user-PC sudo[3830]: linuxuser : TTY=pts/1 ; PWD=/home/linuxuser ; USER=root ; COMMAND=/usr/bin/fsck /dev/md127p1
Jun 07 12:37:31 user-PC sudo[3986]: linuxuser : TTY=pts/1 ; PWD=/home/linuxuser ; USER=root ; COMMAND=/usr/bin/fsck /dev/md127p1
smartctl
smartctl -A /dev/sdb && smartctl -A /dev/sdd && smartctl -A /dev/sda && smartctl -A /dev/sdc
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.9.2-1-MANJARO] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   000    Pre-fail  Always       -       0
  5 Reallocate_NAND_Blk_Cnt 0x0032   100   100   010    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       12794
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       8030
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
173 Ave_Block-Erase_Count   0x0032   064   064   000    Old_age   Always       -       548
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       489
180 Unused_Reserve_NAND_Blk 0x0033   000   000   000    Pre-fail  Always       -       41
183 SATA_Interfac_Downshift 0x0032   100   100   000    Old_age   Always       -       2
184 Error_Correction_Count  0x0032   100   100   000    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   065   037   000    Old_age   Always       -       35 (Min/Max 0/63)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_ECC_Cnt 0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       1
202 Percent_Lifetime_Remain 0x0030   064   064   001    Old_age   Offline      -       36
206 Write_Error_Rate        0x000e   100   100   000    Old_age   Always       -       0
210 Success_RAIN_Recov_Cnt  0x0032   100   100   000    Old_age   Always       -       0
246 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       149831237895
247 Host_Program_Page_Count 0x0032   100   100   000    Old_age   Always       -       2452458749
248 FTL_Program_Page_Count  0x0032   100   100   000    Old_age   Always       -       2652452678
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       12285
173 Ave_Block-Erase_Count   0x0032   065   065   000    Old_age   Always       -       526
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       484
180 Unused_Reserve_NAND_Blk 0x0033   000   000   000    Pre-fail  Always       -       40
194 Temperature_Celsius     0x0022   064   038   000    Old_age   Always       -       36 (Min/Max 0/62)
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
202 Percent_Lifetime_Remain 0x0030   065   065   001    Old_age   Offline      -       35
246 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       145620394347
247 Host_Program_Page_Count 0x0032   100   100   000    Old_age   Always       -       2382739778
248 FTL_Program_Page_Count  0x0032   100   100   000    Old_age   Always       -       2493932955
SMART Attributes Data Structure revision number: 10
  1 Raw_Read_Error_Rate     0x000f   079   063   044    Pre-fail  Always       -       88160044
  3 Spin_Up_Time            0x0003   093   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   099   099   020    Old_age   Always       -       1180
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   088   060   030    Pre-fail  Always       -       774443070
  9 Power_On_Hours          0x0032   027   027   000    Old_age   Always       -       64794
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   099   099   020    Old_age   Always       -       1130
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       8590065666
189 High_Fly_Writes         0x003a   082   082   000    Old_age   Always       -       18
190 Airflow_Temperature_Cel 0x0022   061   043   045    Old_age   Always   In_the_past 39 (4 117 39 29 0)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       395
193 Load_Cycle_Count        0x0032   099   099   000    Old_age   Always       -       3782
194 Temperature_Celsius     0x0022   039   057   000    Old_age   Always       -       39 (0 21 0 0 0)
195 Hardware_ECC_Recovered  0x001a   019   005   000    Old_age   Always       -       88160044
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
  1 Raw_Read_Error_Rate     0x000f   081   063   044    Pre-fail  Always       -       133164366
  4 Start_Stop_Count        0x0032   099   099   020    Old_age   Always       -       1195
  7 Seek_Error_Rate         0x000f   089   060   045    Pre-fail  Always       -       909219337
  9 Power_On_Hours          0x0032   044   044   000    Old_age   Always       -       49662
 12 Power_Cycle_Count       0x0032   099   099   020    Old_age   Always       -       1119
189 High_Fly_Writes         0x003a   084   084   000    Old_age   Always       -       16
190 Airflow_Temperature_Cel 0x0022   060   051   045    Old_age   Always       -       40 (Min/Max 29/40)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       388
193 Load_Cycle_Count        0x0032   099   099   000    Old_age   Always       -       3084
194 Temperature_Celsius     0x0022   040   049   000    Old_age   Always       -       40 (0 23 0 0 0)
195 Hardware_ECC_Recovered  0x001a   021   004   000    Old_age   Always       -       133164366
If you have fsck set in mkinitcpio hooks it will run on every boot. That is normal.
systemd-fsck-root.service - File System Check on Root Device
     Loaded: loaded (/usr/lib/systemd/system/systemd-fsck-root.service; enabled-runtime; preset: disabled)
     Active: active (exited) since Fri 2024-06-07 05:54:51 EDT; 7h ago
       Docs: man:systemd-fsck-root.service(8)
   Main PID: 232 (code=exited, status=0/SUCCESS)
        CPU: 7ms
Jun 07 05:54:51 manjaro systemd[1]: Starting File System Check on /dev/disk/by-uuid/a4356953-snip...
Jun 07 05:54:51 manjaro systemd-fsck[235]: /dev/nvme0n1p2: clean, 398101/2564096 files, 3835489/10240000 blocks
Jun 07 05:54:51 manjaro systemd[1]: Finished File System Check on /dev/disk/by-uuid/a4356953-snip
Ok. I took it out so it doesn’t run. But how can I be sure nothing is happening with the RAID setups? I rebooted and it gets a disk busy and it is advancing slow. Now I hit ESC and I am not show with a console screen with FSCK messages
Yes. However, what is NOT normal is the errors reported in his log.
Bad idea. Pretending the problem doesn’t exist doesn’t make it go away. You have many file system errors that you need to address. See fsck - ArchWiki
see this
https://wiki.archlinux.org/title/RAID
if you have in /etc/mdadm.conf , you can check status and mdstats
added!
