when i turn on my hotspot, and connect my phone to it, the maximum speed i get is around 100KBps even though my internet is good enough to give around 2.5 MBps
Welcome to Manjaro!
Please read this:
and post some more information so we can see whatās really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin liesā¦
An inxi --admin --verbosity=7 --filter --no-host
would be the minimum required informationā¦ (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
mod-edit: Formatting
Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=1d6e6343-47ff-45fe-bfbe-e2222d29d250 rw quiet apparmor=1
security=apparmor resume=UUID=717a20bd-088d-4ba6-a3a4-b3182d2ddbfc
udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 80E3 v: Lenovo G50-45 serial: <filter>
Chassis: type: 10 v: Lenovo G50-45 serial: <filter>
Mobo: LENOVO model: Lancer 5B2 v: SDK0F82990 WIN serial: <filter>
UEFI [Legacy]: LENOVO v: A2CN45WW(V2.13) date: 08/04/2016
ID-1: BAT1 charge: 9.0 Wh condition: 24.7/31.7 Wh (78%) volts: 15.0/14.4
model: LENOVO PABAS0241231 type: Li-ion serial: <filter> status: Charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K230
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 3.32 GiB used: 1.36 GiB (41.0%)
Topology: Quad Core model: AMD A8-6410 APU with AMD Radeon R5 Graphics bits: 64
type: MCP arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1
microcode: 7030105 L2 cache: 2048 KiB bogomips: 15979
Speed: 998 MHz min/max: 1000/2000 MHz boost: enabled Core speeds (MHz): 1: 1030
2: 1040 3: 1118 4: 1013
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr
mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm
svm_lock syscall topoext tsc tsc_scale vme vmmcall wdt xsave xsaveopt
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Lenovo driver: radeon
v: kernel alternate: amdgpu bus ID: 00:01.0 chip ID: 1002:9851
Device-2: Microdia type: USB driver: uvcvideo bus ID: 2-1.2:3
chip ID: 0c45:6513
Display: x11 server: X.O rg 1.20.8 compositor: kwin_x11 driver: radeon
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.7.17-2-MANJARO LLVM 10.0.1)
v: 4.5 Mesa 20.1.6 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:01.1 chip ID: 1002:9840
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1022:780d
Sound Server: ALSA v: k5.7.17-2-MANJARO
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lenovo Z50-75
driver: rtl8723be v: kernel port: 3000 bus ID: 01:00.0 chip ID: 10ec:b723
IF: wlp1s0 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 2000 bus ID: 02:00.0 chip ID: 10ec:8168
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.36 TiB used: 24.34 GiB (1.7%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: LVM1 scheme: MBR
ID-2: /dev/sdb vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: 1A scheme: MBR
ID-1: / raw size: 30.13 GiB size: 29.53 GiB (98.02%) used: 13.08 GiB (44.3%)
fs: ext4 dev: /dev/sdb5 label: N/A uuid: 1d6e6343-47ff-45fe-bfbe-e2222d29d250
ID-2: /home raw size: 97.66 GiB size: 95.62 GiB (97.92%)
used: 11.23 GiB (11.7%) fs: ext4 dev: /dev/sdb3 label: N/A
uuid: 66ec21d4-ecc1-4e0b-b653-dda566ac95b7
ID-1: swap-1 type: partition size: 7.82 GiB used: 26.6 MiB (0.3%) priority: -2
dev: /dev/sdb2 label: N/A uuid: 717a20bd-088d-4ba6-a3a4-b3182d2ddbfc
ID-1: /dev/sda1 size: 579.0 MiB fs: ntfs label: System Reserved
uuid: CA804FBC804FAE2F
ID-2: /dev/sda2 size: 194.75 GiB fs: ntfs label: N/A uuid: 2C741F75741F414E
ID-3: /dev/sda3 size: 97.66 GiB fs: ntfs label: N/A uuid: 50A29A0DA299F824
ID-4: /dev/sda4 size: 172.79 GiB fs: ntfs label: N/A uuid: 76B6A266B6A22699
ID-5: /dev/sdb1 size: 1 KiB fs: <superuser/root required> label: N/A uuid: N/A
ID-6: /dev/sdb4 size: 795.90 GiB fs: ntfs label: N/A uuid: 64E222F6E222CC5C
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 0438:7900
Device-1: 1-1.1:3 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 046d:c534
Device-2: 1-1.3:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 serial: <filter>
Device-3: 1-1.4:5 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
chip ID: 046d:c52b
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 2-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
Device-1: 2-1.2:3 info: Microdia type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s chip ID: 0c45:6513
Device-2: 2-1.3:4 info: Realtek RTL8723B Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s chip ID: 0bda:b728
serial: <filter>
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 47.0 C mobo: N/A gpu: radeon temp: 48 C
Processes: 205 Uptime: 41m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1414 pacman: 1410 lib: 354 flatpak: 0 snap: 4 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.05
This piece of ā¦ ermā¦ hardware has 2 known problemsā¦ Please provide the output of:
cat /proc/sys/kernel/random/entropy_avail
cat /etc/modprobe.d/50-rtl8723be.conf
[abhra@abhra ~]$ cat /proc/sys/kernel/random/entropy_avail
3817
[abhra@ ~]$ cat /etc/modprobe.d/50-rtl8723be.conf
cat: /etc/modprobe.d/50-rtl8723be.conf: No such file or directory
Thatās good (>1000)
Thatās bad. Try this:
echo "options rtl8723be swenc=1 fwlps=0 ips=0 ant_sel=1" | sudo tee /etc/modprobe.d/rtl8723be.conf
sudo sed -i 's/wifi.powersave = 3/wifi.powersave = 2/' /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Then reboot and try again.
The first option does this:
parm: swenc:using hardware crypto (default 0 [hardware]) (bool)
parm: ips:using no link power save (default 1 is open) (bool)
parm: fwlps:using linked fw control power save (default 1 is open) (bool)
parm: ant_sel:Set to 1 or 2 to force antenna number (default 0) (int)
The second option tells NetworkManager to not use power saving on top of the module itself.
thanks a lot but the second command is having issues
[abhra~]$ echo āoptions rtl8723be swenc=1 fwlps=0 ips=0 ant_sel=1ā | sudo tee /etc/modprobe.d/rtl8723be.conf
[abhra@ab ~]$ sudo sed -i ās/wifi.powersave = 3/wifi.powersave = 2/ā /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
sed: canāt read /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf: No such file or directory
If youāre not using NetWorkManager (which this looks like) you should ignore that.
Any improvements after a reboot???
sorry , no imrovement after reboot .
also the directory ā/etc/NetworkManager/conf.d/ā looks empty
Try the following then:
sudo nano --backup /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
copy-paste this in there:
wifi.powersave = 2
and hit Ctrl+X Enter to save that
then restart NM or reboot.
Then feed back again.
well i tried that but during reboot it says āfailed to start network managerā and also ran into some issues with network as expected, so had to revert the changes and i deleted it
