Slow booting time of Manjaro KDE
Hello,
I’ve installed Manjaro KDE in my Acer Nitro 5 with i5 10th gen and GTX 1650ti. I have a dual boot setup and installed manjaro on SSD. When I boot in windows it takes hardly 10-13s to boot into the home screen But, when I boot in Manjaro It takes more than 1 minute.
I have tried searching for this problem for a solution but nothing works.
I have provided some terminals outputs below :
systemd-analyze
Startup finished in 4.916s (firmware) + 13.092s (loader) + 3.386s (kernel) + 20.596s (userspace) = 41.992s
graphical.target reached after 20.301s in userspace
systemd-analyze blame
11.018s systemd-journal-flush.service
6.294s lvm2-monitor.service
5.847s snapd.service
3.681s systemd-modules-load.service
3.278s dev-sda6.device
3.276s polkit.service
2.767s cups.service
2.465s NetworkManager.service
1.883s bluetooth.service
1.882s avahi-daemon.service
1.733s systemd-logind.service
1.531s apparmor.service
1.328s systemd-random-seed.service
1.220s systemd-udevd.service
1.162s ModemManager.service
892ms var-lib-snapd-snap-core18-1944.mount
869ms snapd.apparmor.service
857ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
817ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
662ms var-lib-snapd-snap-joplin\x2djames\x2dcarroll-41.mount
638ms var-lib-snapd-snap-joplin\x2djames\x2dcarroll-42.mount
553ms var-lib-snapd-snap-snapd-10492.mount
499ms systemd-tmpfiles-setup-dev.service
497ms systemd-rfkill.service
401ms upower.service
394ms modprobe@fuse.service
380ms systemd-tmpfiles-clean.service
357ms wpa_supplicant.service
347ms user@1000.service
312ms udisks2.service
307ms systemd-user-sessions.service
293ms tlp.service
266ms modprobe@drm.service
254ms systemd-udev-trigger.service
252ms systemd-journald.service
245ms modprobe@configfs.service
234ms systemd-tmpfiles-setup.service
233ms dev-loop4.device
204ms boot-efi.mount
194ms kmod-static-nodes.service
154ms rtkit-daemon.service
151ms systemd-timesyncd.service
145ms linux-module-cleanup.service
132ms systemd-backlight@backlight:intel_backlight.service
118ms systemd-sysctl.service
 86ms systemd-binfmt.service
 80ms systemd-fsck@dev-disk-by\x2duuid-0A64\x2dA0A0.service
 60ms dev-hugepages.mount
 59ms dev-mqueue.mount
systemd-analyze critical-chain
The time when unit became active or started is printed after the “@” character.
The time the unit took to start is printed after the “+” character.
graphical.target @ 20.301s
└─multi-user.target @ 20.301s
└─snapd.service @ 14.453s +5.847s
└─basic.target @ 14.305s
└─sockets.target @ 14.305s
└─snapd.socket @ 14.305s +420us
└─sysinit.target @ 14.265s
└─systemd-timesyncd.service @ 14.113s +151ms
└─systemd-tmpfiles-setup.service @ 13.801s +234ms
└─systemd-journal-flush.service @ 2.782s +11.018s
└─systemd-journald.service @ 2.529s +252ms
└─systemd-journald.socket @ 2.472s
└─system.slice @ 2.290s
└─-.slice @ 2.290s
Thanks in Advance
Hello,
That happens when the journal file is very large. You can check that with this command from terminal:
journalctl --disk-usage
I recommend doing this: systemd/Journal - ArchWiki to solve the problem. You can set the file larger than in that example, but you will not need more than 50M …
Thanks, @bogdancovaciu for the reply.
I did what you recommended but it didn’t work even it increased boot time. I have pasted the output below :
systemd-anaylyze
Startup finished in 4.891s (firmware) + 19.472s (loader) + 3.579s (kernel) + 22.003s (userspace) = 49.946s
graphical.target reached after 21.341s in userspace
11.509s systemd-journal-flush.service
 6.152s lvm2-monitor.service
 5.905s snapd.service
 3.791s systemd-modules-load.service
 3.533s dev-sda6.device
 3.475s polkit.service
 2.783s cups.service
 2.753s avahi-daemon.service
 2.751s bluetooth.service
 2.750s NetworkManager.service
 2.706s systemd-logind.service
 1.649s ModemManager.service
 1.137s apparmor.service
 1.052s systemd-tmpfiles-setup-dev.service
 1.050s systemd-random-seed.service
  867ms var-lib-snapd-snap-core18-1944.mount
  855ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
  833ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
  776ms systemd-udevd.service
  774ms var-lib-snapd-snap-joplin\x2djames\x2dcarroll-41.mount
  728ms snapd.apparmor.service
  710ms var-lib-snapd-snap-joplin\x2djames\x2dcarroll-42.mount
  651ms var-lib-snapd-snap-snapd-10492.mount
  570ms systemd-timesyncd.service
  560ms systemd-tmpfiles-clean.service
  458ms systemd-sysctl.service
  407ms tlp.service
  404ms systemd-binfmt.service
  369ms systemd-udev-trigger.service
  368ms upower.service
  357ms modprobe@drm.service
  357ms modprobe@fuse.service
  352ms wpa_supplicant.service
  351ms systemd-tmpfiles-setup.service
  309ms systemd-journald.service
  308ms udisks2.service
  308ms linux-module-cleanup.service
  285ms boot-efi.mount
  269ms proc-sys-fs-binfmt_misc.mount
  242ms user@1000.service
  185ms systemd-fsck@dev-disk-by\x2duuid-0A64\x2dA0A0.service
  126ms systemd-update-utmp.service
  119ms dev-hugepages.mount
  118ms dev-mqueue.mount
  118ms systemd-rfkill.service
  117ms sys-kernel-debug.mount
  115ms sys-kernel-tracing.mount
  105ms systemd-backlight@backlight:intel_backlight.service
Did you read the part where you clean journal files manually ? Do that, then reboot. I hope you did things the correct way and no typos. :slight_smile:
I tried. It helped me to reduce the boot time. While searching on the internet I found that others linux are take 6-10s to boot up.
Startup finished in 5.934s (firmware) + 2.874s (loader) + 3.591s (kernel) + 14.297s (userspace) = 26.698s
graphical.target reached after 13.983s in userspace
5.220s lvm2-monitor.service
4.557s snapd.service
3.301s systemd-modules-load.service
3.151s dev-sda6.device
2.275s NetworkManager.service
2.233s polkit.service
2.162s cups.service
1.730s avahi-daemon.service
1.729s bluetooth.service
1.542s apparmor.service
1.353s ModemManager.service
 878ms systemd-logind.service
 848ms linux-module-cleanup.service
 776ms var-lib-snapd-snap-joplin\x2djames\x2dcarroll-42.mount
 765ms systemd-rfkill.service
 721ms systemd-remount-fs.service
 695ms systemd-random-seed.service
 670ms systemd-tmpfiles-setup-dev.service
 617ms systemd-udevd.service
 483ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
 467ms var-lib-snapd-snap-core18-1944.mount
 453ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
 414ms modprobe@fuse.service
 408ms systemd-journal-flush.service
 407ms var-lib-snapd-snap-joplin\x2djames\x2dcarroll-41.mount
 397ms snapd.apparmor.service
 395ms upower.service
 388ms var-lib-snapd-snap-snapd-10492.mount
 381ms dev-loop0.device
 370ms modprobe@drm.service
 340ms systemd-tmpfiles-setup.service
 313ms tlp.service
 305ms udisks2.service
 301ms systemd-journald.service
 281ms systemd-udev-trigger.service
 223ms wpa_supplicant.service
 195ms dev-loop1.device
 179ms dev-loop5.device
 159ms dev-loop4.device
 151ms user@1000.service
 147ms modprobe@configfs.service
 140ms systemd-timesyncd.service
 126ms dev-loop3.device
 118ms systemd-binfmt.service
 113ms systemd-sysctl.service
 104ms kmod-static-nodes.service
 100ms dev-hugepages.mount
  98ms dev-mqueue.mount
  97ms sys-kernel-debug.mount
What else I do to decrease this boot time ?
