Lvm is logical volume manager.
mine udisk is 106ms udisks2.service
you are using hdd not an sdd so that is also one of the reasons…
dev-loop0.device
- these are probably related to snap, so if you have installed any snap packages replace them, and then disable completely snap …
ModemManager.service
- this can be safely disabled if you are using modem;
cups.service
- this is for printing, so if you are not using prineters all cups services can be disabled;
lvm2-monitor.service
- this is for logical volumes, so if you dont have any logical volumes, can be disabled too
snapd.service
this is related to snap, as mentioned above, can be disabled
i have disabled snap, cups and modemmanager for the time being. i didnt disable lvm because my hdd has a logical volume and disabling snap didnt fix the dev-loop0 thing
i do have one snap package called ‘core’ and i dont know if that has anything to do with the system. should i completely remove it?
post output from:
snap list
Name Version Rev Tracking Publisher Notes
core 16-2.57.1 13741 latest/stable canonical✓ core
so yes remove it …
then completely uninstall snapd from add/remove software, that should also remove the snapd services …
then clear leftovers:
rm -rf ~/snap
sudo rm -rf /snap
sudo rm -rf /var/snap
sudo rm -rf /var/lib/snapd
Seems to have fixed it (dev-loop0)
did you masked all cups services?
also you probably running both pulse+pipewire, post output from:
inxi -A
Device-1: Intel 5 Series/3400 Series High Definition Audio
driver: snd_hda_intel
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.56 running: yes
im not sure how many cups services there are but i only masked cups.service
. Where can i see all others?
ok, so you running only pipewire …
then there are also those avahi services, so you can mask both of them, if you are not using it …
what are those used for?
it is used if you are on a local network, to find printers, files etc …
ill keep it on
also you can disable some services from system settings/backround services…
here is what i have disabled:
i disabled a few of them so it should be a bit faster now .
Can you post the output of systemctl
on console ?
LOAD ACTIVE SUB DESCRIPTION
loaded active running Arbitrary Executable File Formats File System Automount Point
acpi_video0.device loaded active plugged /sys/devices/pci0000:00/0000:00:02.0/backlight/acpi_video0
card0\x2dLVDS\x2d1-intel_backlight.device loaded active plugged /sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-LVDS-1/intel_backlight
0-controlC0.device loaded active plugged /sys/devices/pci0000:00/0000:00:1b.0/sound/card0/controlC0
.0-bcma0:1-net-wlp18s0b1.device loaded active plugged BCM4313 802.11bgn Wireless Network Adapter (Inspiron M5010 / XPS 8300)
.0-net-enp19s0.device loaded active plugged RTL810xE PCI Express Fast Ethernet controller
-target0:0:0-0:0:0:0-block-sda-sda1.device loaded active plugged SAMSUNG_HN-M320MBB 1
-target0:0:0-0:0:0:0-block-sda-sda2.device loaded active plugged SAMSUNG_HN-M320MBB Windows
-target0:0:0-0:0:0:0-block-sda-sda3.device loaded active plugged SAMSUNG_HN-M320MBB APP&DOWNLOADS
-target0:0:0-0:0:0:0-block-sda-sda4.device loaded active plugged SAMSUNG_HN-M320MBB 4
-target0:0:0-0:0:0:0-block-sda-sda5.device loaded active plugged SAMSUNG_HN-M320MBB 5
-target0:0:0-0:0:0:0-block-sda-sda6.device loaded active plugged SAMSUNG_HN-M320MBB General
-target0:0:0-0:0:0:0-block-sda-sda7.device loaded active plugged SAMSUNG_HN-M320MBB Media
-target0:0:0-0:0:0:0-block-sda-sda8.device loaded active plugged SAMSUNG_HN-M320MBB 8
-target0:0:0-0:0:0:0-block-sda.device loaded active plugged SAMSUNG_HN-M320MBB
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS0
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS1
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS10
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS11
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS12
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS13
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS14
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS15
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS16
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS17
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS18
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS19
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS2
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS20
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS21
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS22
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS23
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS24
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS25
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS26
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS27
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS28
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS29
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS3
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS30
ice loaded active plugged /sys/devices/platform/serial8250/tty/ttyS31
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS4
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS5
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS6
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS7
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS8
ce loaded active plugged /sys/devices/platform/serial8250/tty/ttyS9
loaded active plugged /sys/devices/virtual/misc/rfkill
loaded active plugged /sys/module/configfs
loaded active plugged /sys/module/fuse
loaded active mounted Root Mount
loaded active mounted Huge Pages File System
loaded active mounted POSIX Message Queue File System
loaded active mounted Arbitrary Executable File Formats File System
loaded active mounted /run/media/reyyan/A8E0256AE0254044
loaded active mounted /run/media/reyyan/APP&DOWNLOADS
loaded active mounted /run/media/reyyan/General
loaded active mounted /run/media/reyyan/Media
loaded active mounted /run/media/reyyan/Windows
loaded active mounted /run/user/1000/doc
loaded active mounted /run/user/1000/gvfs
loaded active mounted FUSE Control File System
loaded active mounted Kernel Configuration File System
loaded active mounted Kernel Debug File System
loaded active mounted Kernel Trace File System
loaded active mounted Temporary Directory /tmp
loaded active waiting Dispatch Password Requests to Console Directory Watch
loaded active waiting Forward Password Requests to Wall Directory Watch
loaded active running System and Service Manager
loaded active running Session 2 of User reyyan
loaded active exited Save/Restore Sound Card State
loaded active running Periodic Command Scheduler
loaded active running D-Bus System Message Bus
loaded active exited Create List of Static Device Nodes
loaded active exited Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
loaded active exited Network Manager Wait Online
loaded active running Network Manager
loaded active running Authorization Manager
loaded active running RealtimeKit Scheduling Policy Service
loaded active running Simple Desktop Display Manager
e loaded active exited Load/Save Screen Backlight Brightness of backlight:acpi_video0
rvice loaded active exited Load/Save Screen Backlight Brightness of backlight:intel_backlight
loaded active exited Set Up Additional Binary Formats
loaded active exited Flush Journal to Persistent Storage
loaded active running Journal Service
loaded active running User Login Management
loaded active exited Load Kernel Modules
loaded active exited Load/Save Random Seed
loaded active exited Remount Root and Kernel File Systems
loaded active exited Apply Kernel Variables
loaded active running Network Time Synchronization
loaded active exited Create Static Device Nodes in /dev
loaded active exited Create Volatile Files and Directories
loaded active exited Coldplug All udev Devices
loaded active running Rule-based Manager for Device Events and Files
loaded active exited Record System Boot/Shutdown in UTMP
loaded active exited Permit User Sessions
loaded active running Disk Manager
loaded active running Daemon for power management
loaded active exited User Runtime Directory /run/user/1000
loaded active running User Manager for UID 1000
loaded active running WPA supplicant
loaded active active Root Slice
loaded active active Slice /system/getty
loaded active active Slice /system/modprobe
loaded active active Slice /system/systemd-backlight
loaded active active System Slice
loaded active active User Slice of UID 1000
loaded active active User and Session Slice
loaded active running D-Bus System Message Bus Socket
loaded active listening Device-mapper event daemon FIFOs
loaded active listening LVM2 poll daemon socket
loaded active listening Process Core Dump Socket
loaded active running Journal Audit Socket
loaded active running Journal Socket (/dev/log)
loaded active listening Load/Save RF Kill Switch Status /dev/rfkill Watch
loaded active running udev Control Socket
loaded active running udev Kernel Socket
2d81e6\x2d6d14df23566b.swap loaded active active /dev/disk/by-uuid/cb4185d1-f25c-458e-81e6-6d14df23566b
loaded active active /swapfile
loaded active active Basic System
loaded active active Local Encrypted Volumes
loaded active active Login Prompts
loaded active active Graphical Interface
loaded active active Local Integrity Protected Volumes
loaded active active Preparation for Local File Systems
loaded active active Local File Systems
loaded active active Multi-User System
loaded active active Network is Online
loaded active active Path Units
loaded active active Remote File Systems
loaded active active Slice Units
loaded active active Socket Units
loaded active active Sound Card
loaded active active Swaps
loaded active active System Initialization
loaded active active System Time Set
loaded active active Timer Units
loaded active active Local Verity Protected Volumes
loaded active waiting Daily rotation of log files
loaded active waiting Daily man-db regeneration
loaded active waiting Monthly clean packages cache
loaded active waiting Generate mirrorlist weekly
loaded active waiting pkgfile database update timer
loaded active waiting Daily verification of password and group files
loaded active waiting Daily Cleanup of Temporary Directories
s properly loaded.
.e. generalization of SUB.
lues depend on unit type.
d but inactive units, too.
list-unit-files'.
lines 122-158/158 (END)
You can also disable LVM2 poll daemon socket
Manjaro used to be very fast to boot but after my last install its slow as snail. Here are some outputs:
systemd-analyze blame | head -n 20
27.666s udisks2.service
9.758s pkgfile-update.service
6.859s systemd-modules-load.service
6.302s NetworkManager-wait-online.service
759ms systemd-random-seed.service
435ms dev-sda2.device
191ms user@1000.service
144ms systemd-udev-trigger.service
117ms lvm2-monitor.service
107ms ModemManager.service
88ms systemd-journal-flush.service
78ms boot-efi.mount
62ms logrotate.service
56ms systemd-journald.service
51ms cups.service
44ms systemd-logind.service
43ms upower.service
40ms systemd-udevd.service
40ms NetworkManager.service
37ms polkit.service
and
inxi -Fza
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1b9ad4f0-2926-4b4e-ac1f-7fe2604701eb rw quiet
resume=UUID=a086efd7-88b3-468e-bf05-d12530cd4b49 udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x
serial: UEFI: American Megatrends v: 3211
date: 08/10/2021
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1692 high: 3215 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1380 2: 1335
3: 2414 4: 1376 5: 1376 6: 1376 7: 2373 8: 1333 9: 3215 10: 1375
11: 1376 12: 1377 bogomips: 81630
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
svm
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled
via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user
pointer sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: ASUSTeK
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm
non-free: 520.xx+ status: current (as of 2022-10) arch: Turing
code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 08:00.0 chip-ID: 10de:1f06 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1080 s-dpi: 81
s-size: 803x343mm (31.61x13.50") s-diag: 873mm (34.38")
Monitor-1: HDMI-1 res: 2560x1080 hz: 60 dpi: 81
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce RTX
2060 SUPER/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 08:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK
bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp3s0 state: down mac:
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2526
class-ID: 0280
IF: wlp7s0 state: up mac:
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB
driver: btusb v: 0.8 bus-ID: 1-6:3 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Local Storage: total: 13.21 TiB used: 70.09 GiB (0.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT525MX300SSD1
size: 489.05 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: rev: R040 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: rev: 2B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWD110
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: rev: A8R0
scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba
model: External USB 3.0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: rev: 5438 scheme: GPT
ID-5: /dev/sdf maj-min: 8:80 type: USB vendor: Western Digital
model: WD80EZAZ-11TDBA0 size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: rev: 4007
scheme: GPT
ID-1: / raw-size: 454.38 GiB size: 446.16 GiB (98.19%)
used: 70.09 GiB (15.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 30.2 C mobo: N/A gpu: nvidia temp: 43 C
Processes: 304 Uptime: 13m wakeups: 0 Memory: 31.25 GiB
used: 2.84 GiB (9.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1276
pm: pacman pkgs: 1216 libs: 317 tools: pamac pm: flatpak pkgs: 60
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.23
last
journalctl --boot --priority=3
Dec 12 09:44:56 kiushin-manj kernel: sd 10:0:0:0: [sde] No Caching mode page found
Dec 12 09:44:56 kiushin-manj kernel: sd 10:0:0:0: [sde] Assuming drive cache: write through
Dec 12 09:44:56 kiushin-manj kernel: sd 11:0:0:0: [sdf] No Caching mode page found
Dec 12 09:44:56 kiushin-manj kernel: sd 11:0:0:0: [sdf] Assuming drive cache: write through
Dec 12 09:44:56 kiushin-manj kernel: kvm: disabled by bios
Dec 12 09:44:57 kiushin-manj kernel: xhci_hcd 0000:04:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x>
Dec 12 09:44:57 kiushin-manj kernel: kvm: disabled by bios
Dec 12 09:45:01 kiushin-manj kernel: kvm: disabled by bios
Dec 12 09:45:01 kiushin-manj kernel: scsi 11:0:0:1: Wrong diagnostic page; asked for 1 got 8
Dec 12 09:45:01 kiushin-manj kernel: scsi 11:0:0:1: Failed to get diagnostic page 0x1
Dec 12 09:45:01 kiushin-manj kernel: scsi 11:0:0:1: Failed to bind enclosure -19
Dec 12 09:45:02 kiushin-manj bluetoothd[576]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 12 09:45:02 kiushin-manj bluetoothd[576]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 12 09:45:02 kiushin-manj bluetoothd[576]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 12 09:45:02 kiushin-manj bluetoothd[576]: Failed to set mode: Blocked through rfkill (0x12)
Dec 12 09:45:02 kiushin-manj kernel: nvidia-gpu 0000:08:00.3: i2c timeout error e0000000
Dec 12 09:45:02 kiushin-manj kernel: ucsi_ccg 0-0008: i2c_transfer failed -110
Dec 12 09:45:02 kiushin-manj kernel: ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
Dec 12 09:45:08 kiushin-manj bluetoothd[576]: Failed to set mode: Blocked through rfkill (0x12)
Dec 12 09:45:11 kiushin-manj systemd[664]: Failed to start Powerdevil.
Dec 12 09:45:16 kiushin-manj systemd[664]: Failed to start Powerdevil.
Dec 12 09:45:22 kiushin-manj systemd[664]: Failed to start Powerdevil.
Dec 12 09:45:27 kiushin-manj systemd[664]: Failed to start Powerdevil.
Dec 12 09:45:32 kiushin-manj kernel: xhci_hcd 0000:04:00.0: xHCI host controller not responding, assume d>
Dec 12 09:45:32 kiushin-manj kernel: xhci_hcd 0000:04:00.0: HC died; cleaning up
Dec 12 09:45:32 kiushin-manj kernel: blk_u
Hi @embrance,
Please open a new support ticket with your problem, including the necessary information as per:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as formatted text.
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Also, if your language isn’t English, please prepend any and all terminal commands with
LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
