There you go:
sudo lspci -vk andrea@andrea
[sudo] password di andrea:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: ASRock Incorporation Device 1480
Flags: fast devsel
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: f7900000-f79fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Root Port (Slot+), MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Device 1234
Capabilities: [c8] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [270] Secondary PCI Express
Capabilities: [2a0] Access Control Services
Capabilities: [370] L1 PM Substates
Capabilities: [3c4] Designated Vendor-Specific: Vendor=1022 ID=0001 Rev=1 Len=44 <?>
Capabilities: [400] Data Link Feature <?>
Capabilities: [410] Physical Layer 16.0 GT/s <?>
Capabilities: [440] Lane Margining at the Receiver <?>
Kernel driver in use: pcieport
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=00, secondary=02, subordinate=06, sec-latency=0
I/O behind bridge: 0000f000-0000ffff [size=4K]
Memory behind bridge: f7500000-f76fffff [size=2M]
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: f6000000-f70fffff [size=17M]
Prefetchable memory behind bridge: 00000000e0000000-00000000f1ffffff [size=288M]
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
Memory behind bridge: [disabled]
Capabilities: [58] Express Root Port (Slot-), MSI 00
Capabilities: [c0] Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
Capabilities: [150] Advanced Error Reporting
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30
Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
Memory behind bridge: f7200000-f74fffff [size=3M]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 31
Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=0
Memory behind bridge: f7800000-f78fffff [size=1M]
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 32
Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
Memory behind bridge: f7700000-f77fffff [size=1M]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: ASRock Incorporation Device 790b
Flags: 66MHz, medium devsel
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Subsystem: ASRock Incorporation Device 790e
Flags: bus master, 66MHz, medium devsel, latency 0
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
Flags: fast devsel
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
Flags: fast devsel
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
Flags: fast devsel
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
Flags: fast devsel
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
Flags: fast devsel
01:00.0 Non-Volatile memory controller: ADATA Technology Co., Ltd. XPG SX8200 Pro PCIe Gen3x4 M.2 2280 Solid State Drive (rev 03) (prog-if 02 [NVM Express])
Subsystem: ADATA Technology Co., Ltd. Device 1cc1
Flags: bus master, fast devsel, latency 0, IRQ 39, NUMA node 0
Memory at f7900000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [b0] MSI-X: Enable+ Count=16 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [158] Secondary PCI Express
Capabilities: [178] Latency Tolerance Reporting
Capabilities: [180] L1 PM Substates
Kernel driver in use: nvme
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 XHCI Controller (rev 01) (prog-if 30 [XHCI])
Subsystem: ASRock Incorporation Device 43d0
Flags: bus master, fast devsel, latency 0, IRQ 61
Memory at f76a0000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [50] MSI: Enable+ Count=1/8 Maskable- 64bit+
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [200] Secondary PCI Express
Capabilities: [300] Latency Tolerance Reporting
Capabilities: [400] L1 PM Substates
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
02:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller (rev 01) (prog-if 01 [AHCI 1.0])
Subsystem: ASRock Incorporation Device 43c8
Flags: bus master, fast devsel, latency 0, IRQ 41
Memory at f7680000 (32-bit, non-prefetchable) [size=128K]
Expansion ROM at f7600000 [disabled] [size=512K]
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: ahci
02:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 33
Bus: primary=02, secondary=03, subordinate=06, sec-latency=0
Memory behind bridge: f7500000-f75fffff [size=1M]
Capabilities: [80] Express Upstream Port, MSI 00
Capabilities: [c0] Subsystem: ASRock Incorporation Device 43c6
03:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 35
Bus: primary=03, secondary=04, subordinate=04, sec-latency=0
Capabilities: [80] Express Downstream Port (Slot+), MSI 00
Capabilities: [c0] Subsystem: ASRock Incorporation Device 43c7
03:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 37
Bus: primary=03, secondary=05, subordinate=05, sec-latency=0
03:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 38
Bus: primary=03, secondary=06, subordinate=06, sec-latency=0
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: ASRock Incorporation Motherboard (one of many)
Flags: bus master, fast devsel, latency 0, IRQ 36
I/O ports at f000 [size=256]
Memory at f7504000 (64-bit, non-prefetchable) [size=4K]
Memory at f7500000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number ff-39-fa-c2-85-70-00-00
Capabilities: [170] Latency Tolerance Reporting
Capabilities: [178] L1 PM Substates
Kernel driver in use: r8169
Kernel modules: r8169
07:00.0 VGA compatible controller: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device 1438
Flags: bus master, fast devsel, latency 0, IRQ 79
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at f7000000 [virtual] [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
07:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 76
Memory at f7080000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Flags: fast devsel
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [64] Express Endpoint, MSI 00
09:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Flags: fast devsel
09:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Flags: bus master, fast devsel, latency 0, IRQ 72
Memory at f7300000 (32-bit, non-prefetchable) [size=1M]
Memory at f7408000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [c0] MSI-X: Enable+ Count=2 Masked-
Capabilities: [370] Transaction Processing Hints
Kernel driver in use: ccp
Kernel modules: ccp
09:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Subsystem: ASRock Incorporation Device 7914
Flags: bus master, fast devsel, latency 0, IRQ 62
Memory at f7200000 (64-bit, non-prefetchable) [size=1M]
Capabilities: [a0] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [c0] MSI-X: Enable+ Count=8 Masked-
09:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Subsystem: ASRock Incorporation Device 6893
Flags: bus master, fast devsel, latency 0, IRQ 78
Memory at f7400000 (32-bit, non-prefetchable) [size=32K]
0a:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
Subsystem: ASRock Incorporation Device 7901
Flags: bus master, fast devsel, latency 0, IRQ 43
Memory at f7800000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [a0] MSI: Enable+ Count=1/16 Maskable- 64bit+
Capabilities: [d0] SATA HBA v1.0
0b:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 45
Memory at f7700000 (32-bit, non-prefetchable) [size=2K]
