Hello,
I’ve been suffering by slow boot. I am using dual boot with windows 8.1 and windows boots faster than Manjaro. Not sure if related, but I needed to restore grub recently.
This is actually a week old installation. I’ve installed only kodi and telegram on it.
The system itself seems to be slow.
Some video: youtube.com/watch?v=ZkKgaQiQU9s
Please advise.
systemd-analyze ✔
Startup finished in 7.101s (kernel) + 44.568s (userspace) = 51.670s
graphical.target reached after 39.932s in userspace
sudo systemd-analyze blame ✔ 4s
25.823s plymouth-quit-wait.service >
5.975s systemd-journal-flush.service >
5.920s snapd.service >
5.856s lvm2-monitor.service >
4.634s tlp.service >
4.241s polkit.service >
3.377s dev-sda5.device >
2.819s systemd-fsck@dev-disk-by\x2duuid-c06822b2\x2d7ce9\x2d4e68\x2da301\x2d82>
2.606s systemd-fsck@dev-disk-by\x2duuid-744C\x2d0628.service >
2.189s udisks2.service >
2.152s accounts-daemon.service >
1.742s apparmor.service >
1.666s cups.service >
1.590s ModemManager.service >
1.536s NetworkManager.service >
1.343s ufw.service >
1.065s systemd-vconsole-setup.service >
1.033s systemd-backlight@backlight:intel_backlight.service >
862ms colord.service >
846ms systemd-logind.service >
841ms systemd-udevd.service >
790ms systemd-tmpfiles-setup-dev.service >
768ms wpa_supplicant.service >
734ms user@1000.service >
587ms upower.service >
569ms modprobe@drm.service >
542ms systemd-udev-trigger.service >
444ms gdm.service >
385ms bluetooth.service >
357ms systemd-random-seed.service >
316ms modprobe@fuse.service >
298ms systemd-modules-load.service >
225ms systemd-journald.service >
167ms systemd-sysctl.service >
164ms snapd.apparmor.service >
148ms plymouth-start.service >
138ms systemd-tmpfiles-clean.service >
130ms fprintd.service >
129ms systemd-tmpfiles-setup.service >
104ms linux-module-cleanup.service >
102ms dev-hugepages.mount >
101ms dev-mqueue.mount >
100ms sys-kernel-debug.mount >
99ms sys-kernel-tracing.mount >
97ms systemd-timesyncd.service >
95ms kmod-static-nodes.service >
77ms systemd-user-sessions.service >
76ms rtkit-daemon.service >
68ms boot-efi.mount >
65ms tmp.mount >
60ms modprobe@configfs.service >
52ms plymouth-read-write.service >
41ms home.mount >
31ms systemd-update-utmp.service >
29ms user-runtime-dir@1000.service >
14ms systemd-remount-fs.service >
5ms systemd-rfkill.service >
4ms sys-fs-fuse-connections.mount >
3ms sys-kernel-config.mount >
1ms snapd.socket
inxi -Fazy ✔ 7s
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=034900ad-dd0a-46d3-b106-25ec0a6a8bf6 rw quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: LENOVO product: 20236 v: Lenovo G500 serial: <filter>
Chassis: type: 10 v: Lenovo G500 serial: <filter>
Mobo: LENOVO model: INVALID v: 31900003WIN8 STD MLT serial: <filter>
UEFI: LENOVO v: 78CN25WW(V2.03) date: 11/19/2013
ID-1: BAT1 charge: 22.3 Wh (71.0%) condition: 31.4/40.4 Wh (77.8%)
volts: 11.3 min: 10.8 model: LENOVO PABAS0241231 type: Li-ion
serial: <filter> status: Discharging
Info: Dual Core model: Intel Core i3-3110M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 19162
Speed: 1197 MHz min/max: 1200/2400 MHz Core speeds (MHz): 1: 1197 2: 1199
3: 1197 4: 1197
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: AMD Mars [Radeon HD 8670A/8670M/8750M] vendor: Lenovo
driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6600 class-ID: 0380
Device-3: Realtek Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 3-4:2
chip-ID: 0bda:5728 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: radeon note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.1.2 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo driver: alx
v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 1969:10a0 class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: 2000
bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
bus-ID: 1-1.3:6 chip-ID: 8087:07dc class-ID: e001
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 931.51 GiB used: 15.35 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM014-1EJ164
rotation: 5400 rpm serial: <filter> rev: LVD1 scheme: GPT
ID-1: / raw-size: 30.27 GiB size: 29.63 GiB (97.87%) used: 10.16 GiB (34.3%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
used: 24.3 MiB (25.3%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 55.66 GiB size: 54.49 GiB (97.89%)
used: 5.17 GiB (9.5%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 45.0 C mobo: N/A gpu: radeon temp: 40.0 C
Processes: 212 Uptime: 33m wakeups: 55 Memory: 3.71 GiB
used: 1.91 GiB (51.4%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1174 pacman: 1168 lib: 298 flatpak: 6 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.04
sudo efibootmgr -v
BootCurrent: 0003
Timeout: 0 seconds
BootOrder: 0003,0004,2001
Boot0000* EFI Network 0 for IPv4 (20-89-84-FE-A0-61) PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(208984fea061,0)/IPv4(0.0.0.00.0.0.0,0,0)RC
Boot0002* EFI Network 0 for IPv6 (20-89-84-FE-A0-61) PciRoot(0x0)/Pci(0x1c,0x0)/Pci(0x0,0x0)/MAC(208984fea061,0)/IPv6([::]:<->[::]:,0,0)RC
Boot0003* manjaro HD(2,GPT,0ac24a14-23a9-45c9-9898-b12874ec15a0,0x96800,0x32000)/File(\EFI\manjaro\grubx64.efi)
Boot0004* Windows Boot Manager HD(2,GPT,0ac24a14-23a9-45c9-9898-b12874ec15a0,0x96800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...d................
Boot2001* EFI USB Device RC
sudo parted -l ✔
Model: ATA ST1000LM014-1EJ1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 316MB 315MB ntfs Basic data partition hidden, diag
2 316MB 420MB 105MB fat32 EFI system partition boot, esp
3 420MB 555MB 134MB Microsoft reserved partition msftres
4 555MB 866GB 865GB ntfs Basic data partition msftdata
5 866GB 899GB 32,5GB ext4
6 899GB 958GB 59,8GB ext4
7 958GB 974GB 15,7GB ntfs Basic data partition msftdata
8 974GB 1000GB 26,2GB ntfs Basic data partition msftdata
cat /etc/default/grub | head -n6
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
