Hi! Using Manjaro for some time already and have been liking it, but lately I suffer from a certain issue related to slowness in the system. The instances of it I have noticed are:
- while browsing photos with Gwenview, it periodically (once 2-10 minutes) freezes the app on transition between two photos around 10 seconds
- Timeshift happened to hang on starting up in a similar way before it appeared
- Telegram less frequently hangs for similar period of time when sending a sticker in a chat
- I feel there was something else that I simply forgot about in the process of typing…
Weirdly, the issue seems to have two side effects:
- when the freeze happens, from what I can hear it seems like the data HDD I have in my computer starts spinning up a moment before the freeze ends, together with the fans in the case
- the fans are probably related to how in KDE system monitor when the freeze happens, one seemingly randomly picked CPU thread goes for the freeze period on solid 100% load, yet looking through the process table trying to find out what exactly consumes that thread seems pretty futile, as nothing really appears to go beyond 3% of load.
That issue seems to be a thing since Manjaro 21.1.5 version. First it troubled me a few days ago and I thought that for some weird kind of fashion it was caused by swapping CD/DVD drives between my and another computer for utility reasons (I made the swap and very soon that started happening). Today I used BTRFS snapshots though and I loaded state of the system from 09.10.2021, when I still had 21.1.4. I played around for a couple moments, which normally would trigger the issue easily, but nothing like that happened, either with the CD drive unplugged, or plugged, so I went for updating system from that snapshot to see if it’s just a broken update process, of the update itself. For some reason the .4 version updated to .5, refusing to find the .6 in the updater (pretty conveniently for this case actually I guess) and pretty soon after getting the .5, the issue returned. In the end I just returned to the first, original “branch” of my snapshots/updates for the sake of just being up to date.
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.14-x86_64
root=UUID=dc3b1840-1309-41c0-bf94-ac04cabb1309 rw rootflags=subvol=@ quiet
udev.log_priority=3
resume=/dev/disk/by-uuid/4344342b-abea-4d58-a8fb-de929973eeae
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C35 v: 1.0 serial: <filter>
Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 1.B0 date: 09/07/2020
Device-1: hidpp_battery_0
model: Logitech MX Vertical Advanced Ergonomic Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 31.27 GiB used: 3.13 GiB (10.0%)
Info: 16-Core (2-Die) model: AMD Ryzen 9 3950X bits: 64 type: MT MCP MCM
arch: Zen 2 family: 17 (23) model-id: 71 (113) stepping: 0
microcode: 8701021 cache: L2: 8 MiB bogomips: 224073
Speed: 2196 MHz min/max: 2200/3500 MHz boost: enabled Core speeds (MHz):
1: 2196 2: 2054 3: 2197 4: 2196 5: 2200 6: 2198 7: 2197 8: 2196 9: 3598
10: 3600 11: 2056 12: 2055 13: 2057 14: 2058 15: 3600 16: 2059 17: 2056
18: 2200 19: 2200 20: 2199 21: 2201 22: 2199 23: 2200 24: 2058 25: 2199
26: 2199 27: 2199 28: 2197 29: 2197 30: 2199 31: 2198 32: 2198
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 2d:00.0
chip-ID: 1002:67df class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1185x285mm (46.7x11.2")
s-diag: 1219mm (48")
Monitor-1: HDMI-A-0 res: 2560x1080 hz: 75 dpi: 96
size: 677x290mm (26.7x11.4") diag: 736mm (29")
Monitor-2: DVI-D-0 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.42.0
5.14.10-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 2d:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: e000 bus-ID: 26:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp39s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 28:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
Local Storage: total: 3.64 TiB used: 1.8 TiB (49.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUS724030ALE641
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A5F0 scheme: GPT
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-5240S rev: 1.03
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 899.01 GiB size: 899.01 GiB (100.00%)
used: 88.6 GiB (9.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: dc3b1840-1309-41c0-bf94-ac04cabb1309
used: 568 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: BF10-DB6C
ID-3: /home raw-size: 899.01 GiB size: 899.01 GiB (100.00%)
ID-4: /mnt/HDDDATA raw-size: 2.73 TiB size: 2.69 TiB (98.39%)
used: 1.71 TiB (63.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: H_NEONdata uuid: 1e0a0afc-df78-497d-9d13-45a61fdbdbd3
ID-5: /run/timeshift/backup raw-size: 899.01 GiB size: 899.01 GiB (100.00%)
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 4344342b-abea-4d58-a8fb-de929973eeae
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-6:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MEG X570 ACE type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c35 class-ID: 0300 serial: <filter>
Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-1:2 info: Microdia USB DEVICE type: Keyboard,Mouse
power: 100mA chip-ID: 0c45:8508 class-ID: 0301
Device-2: 5-2:3 info: Wacom PTH-651 [Intuos pro (M)] type: HID,Mouse
driver: usbhid,wacom interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 498mA
chip-ID: 056a:0315 class-ID: 0301
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.4 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 909
Processes: 537 Uptime: 43m wakeups: 3 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1345 lib: 429
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.07```
Is there anything to be done about this?
