Slow and unstable WiFi
Hi,
It’s been a couple of months since I switched to Manjaro (from Windows) and so far I’m very happy with the decision.
One issue that I couldn´t resolve yet is the unreliable/weak signal I get from Wifi.
It’s not an issue of distance to the router or the hardware itself: if boot into Windows (yes, I still have it because some software doesn´t run in Linux, not even using a virtual machine with Windows) the WiFi signal is great.
I’ve google this issue and although there are a ton of post, I haven´t found a solution to it.
This is the information about my system:
  Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
    root=UUID=2f59c53d-f669-48fb-a956-3d5e1b4008b7 rw rootflags=subvol=@ quiet
    splash resume=UUID=a61801d6-a5e1-47fa-9c6c-f00b9becbc17
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
  Type: Laptop System: Dell product: XPS 13 9370 v: N/A
  Mobo: Dell model: 0F6P3V v: A00 serial: <superuser required> UEFI: Dell
    v: 1.21.0 date: 07/06/2022
  ID-1: BAT0 charge: 44.2 Wh (98.9%) condition: 44.7/52.0 Wh (85.9%) volts: 8.7
    min: 7.6 model: LGC-LGC6.73 DELL H754V79 type: Li-poly serial: <filter>
    status: charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
    status: discharging
  Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
    model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF2
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1679 high: 2000 min/max: 400/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 638 2: 2000 3: 2000
    4: 2000 5: 797 6: 2000 7: 2000 8: 2000 bogomips: 32012
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-1,DP-5
    off: eDP-1 empty: DP-2,DP-3,DP-4 bus-ID: 00:02.0 chip-ID: 8086:5917
    class-ID: 0300
  Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0bda:58f4
  Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.4.2:8
    chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 d-rect: 3840x1080 display-ID: 0
  Monitor-1: DP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
  Monitor-2: DP-5 pos: right res: 1920x1080 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel UHD Graphics 620 (KBL
    GT2) direct-render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_skl
    bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  Device-2: Realtek USB Audio driver: hid-generic,usbhid type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3.1:5 chip-ID: 0bda:48f0
    class-ID: 0300
  Device-4: GN Netcom Jabra SPEAK 410 USB driver: jabra,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.4.3:9
    chip-ID: 0b0e:0412 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.74 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
    class-ID: 0280 temp: 47.0 C
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.3.4:6
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp60s0u1u3u4 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0489:e0a2
    class-ID: e001
  Local Storage: total: 238.47 GiB used: 65.83 GiB (27.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
    model: KXG50ZNV256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
    fw-rev: AADA4106 temp: 45.9 C scheme: GPT
  ID-1: / raw-size: 29.49 GiB size: 29.49 GiB (100.00%) used: 15.99 GiB (54.2%)
    fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
  ID-2: /boot raw-size: 512 MiB size: 487.2 MiB (95.16%)
    used: 84.5 MiB (17.3%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
  ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p10 maj-min: 259:10
  ID-4: /home raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
    used: 49.76 GiB (84.9%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
  ID-5: /var/log raw-size: 29.49 GiB size: 29.49 GiB (100.00%)
    used: 15.99 GiB (54.2%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
  ID-1: swap-1 type: partition size: 8.77 GiB used: 4.8 MiB (0.1%)
    priority: -2 dev: /dev/nvme0n1p11 maj-min: 259:11
  System Temperatures: cpu: 51.0 C pch: 48.0 C mobo: 41.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 0
  Processes: 309 Uptime: 38m wakeups: 104 Memory: total: 16 GiB note: est.
  available: 15.35 GiB used: 6.38 GiB (41.6%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1227 libs: 354 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.2
What about the logs?
journalctl | grep wlp2s0 -n1
And … does the slowness/instability have any specific triggers? Does it occur after sleep?
What if you reload the module?
ex:
sudo modprobe -r ath10k_pci && sudo modprobe ath10k_pci
I cannot relate the issue to any particular event. For instance I booted the latpop one hour ago (from a total shutdown) I sent a big file to print and the print stopped halfway because Manjaro lost network connectivity. I mean, the computer was not coming back from sleep or anything specific.
I tried reloading the module, at least from a signal strenght point of view, it looks as if nothing changed.
Here is the log you’ve requested:
585165-Jul 20 17:35:13 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585166:Jul 20 17:35:13 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:44 [PTK=CCMP GTK=CCMP]
585167:Jul 20 17:35:13 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:44 completed [id=0 id_str=]
585168:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8280] device (wlp2s0): supplicant interface state: associating -> completed
585169:Jul 20 17:35:13 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:44
585170:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8289] device (wlp2s0): ip:dhcp4: restarting
585171:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8517] dhcp4 (wlp2s0): canceled DHCP transaction
585172:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8517] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585173:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8517] dhcp4 (wlp2s0): state changed no lease
585174:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8517] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585175:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8518] device (wlp2s0): ip:dhcp6: restarting
585176:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8518] dhcp6 (wlp2s0): canceled DHCP transaction
585177:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8518] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585178:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8518] dhcp6 (wlp2s0): state changed no lease
585179:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8519] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585180:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8519] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
585181:Jul 20 17:35:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892513.8821] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585182-Jul 20 17:35:13 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
585185-Jul 20 17:35:13 ernesto-xps139370 systemd[1]: Started Network Manager Script Dispatcher Service.
585186:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Disassociation Imminent - Disassociation Timer 60
585187:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Preferred List Available
585188:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585189:Jul 20 17:35:15 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:44 for new auth to 0c:7c:28:b9:22:40
585190:Jul 20 17:35:15 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585191:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585192:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.3601] device (wlp2s0): supplicant interface state: completed -> authenticating
585193:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.3601] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585194:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585195:Jul 20 17:35:15 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585196:Jul 20 17:35:15 ernesto-xps139370 kernel: wlp2s0: authenticated
585197:Jul 20 17:35:15 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585198:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.3641] device (wlp2s0): supplicant interface state: authenticating -> associating
585199:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.3641] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585200:Jul 20 17:35:15 ernesto-xps139370 kernel: wlp2s0: RX ReassocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=0 aid=23)
585201:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:40
585202:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585203:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585204:Jul 20 17:35:15 ernesto-xps139370 kernel: wlp2s0: associated
585205-Jul 20 17:35:15 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585211-Jul 20 17:35:15 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585212:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.3720] device (wlp2s0): supplicant interface state: associating -> 4way_handshake
585213:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.3720] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> 4way_handshake
585214:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:40 [PTK=CCMP GTK=CCMP]
585215:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:40 completed [id=0 id_str=]
585216:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.3789] device (wlp2s0): supplicant interface state: 4way_handshake -> completed
585217:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.3799] device (wlp2s0): ip:dhcp4: restarting
585218:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4117] dhcp4 (wlp2s0): canceled DHCP transaction
585219:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4117] dhcp4 (wlp2s0): state changed no lease
585220:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4117] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585221:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4118] device (wlp2s0): ip:dhcp6: restarting
585222:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4119] dhcp6 (wlp2s0): canceled DHCP transaction
585223:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4119] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585224:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4119] dhcp6 (wlp2s0): state changed no lease
585225:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4119] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585226:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4120] device (p2p-dev-wlp2s0): supplicant management interface state: 4way_handshake -> completed
585227:Jul 20 17:35:15 ernesto-xps139370 NetworkManager[502]: <info>  [1689892515.4333] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585228:Jul 20 17:35:15 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:40
585229:Jul 20 17:35:15 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-71 noise=-93 txrate=234000
585230:Jul 20 17:35:17 ernesto-xps139370 NetworkManager[502]: <info>  [1689892517.5581] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
585231:Jul 20 17:35:22 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585232:Jul 20 17:35:22 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:40 for new auth to 0c:7c:28:b9:22:44
585233:Jul 20 17:35:22 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
585234:Jul 20 17:35:22 ernesto-xps139370 NetworkManager[502]: <info>  [1689892522.3193] device (wlp2s0): supplicant interface state: completed -> authenticating
585235:Jul 20 17:35:22 ernesto-xps139370 NetworkManager[502]: <info>  [1689892522.3193] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585236:Jul 20 17:35:22 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585237:Jul 20 17:35:22 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
585238:Jul 20 17:35:22 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 2/3)
585239:Jul 20 17:35:22 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 3/3)
585240:Jul 20 17:35:22 ernesto-xps139370 kernel: wlp2s0: authentication with 0c:7c:28:b9:22:44 timed out
585241-Jul 20 17:35:22 ernesto-xps139370 wpa_supplicant[567]: BSSID 0c:7c:28:b9:22:44 ignore list count incremented to 2, ignoring for 10 seconds
585242:Jul 20 17:35:22 ernesto-xps139370 NetworkManager[502]: <info>  [1689892522.6619] device (wlp2s0): supplicant interface state: authenticating -> disconnected
585243:Jul 20 17:35:22 ernesto-xps139370 NetworkManager[502]: <info>  [1689892522.6619] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> disconnected
585244:Jul 20 17:35:22 ernesto-xps139370 NetworkManager[502]: <info>  [1689892522.7619] device (wlp2s0): supplicant interface state: disconnected -> scanning
585245:Jul 20 17:35:22 ernesto-xps139370 NetworkManager[502]: <info>  [1689892522.7620] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585246:Jul 20 17:35:22 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585247:Jul 20 17:35:22 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585248:Jul 20 17:35:22 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585249:Jul 20 17:35:23 ernesto-xps139370 NetworkManager[502]: <info>  [1689892523.0180] device (wlp2s0): supplicant interface state: scanning -> authenticating
585250:Jul 20 17:35:23 ernesto-xps139370 NetworkManager[502]: <info>  [1689892523.0180] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
585251:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585252:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: authenticated
585253:Jul 20 17:35:23 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585254:Jul 20 17:35:23 ernesto-xps139370 NetworkManager[502]: <info>  [1689892523.0190] device (wlp2s0): supplicant interface state: authenticating -> associating
585255:Jul 20 17:35:23 ernesto-xps139370 NetworkManager[502]: <info>  [1689892523.0190] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585256:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585257:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=23)
585258:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585259:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 2/3)
585260:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=23)
585261:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585262:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 3/3)
585263:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=23)
585264:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585265-Jul 20 17:35:23 ernesto-xps139370 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
585266:Jul 20 17:35:23 ernesto-xps139370 kernel: wlp2s0: association with 0c:7c:28:b9:22:40 timed out
585267:Jul 20 17:35:23 ernesto-xps139370 NetworkManager[502]: <info>  [1689892523.9786] device (wlp2s0): supplicant interface state: associating -> disconnected
585268:Jul 20 17:35:23 ernesto-xps139370 NetworkManager[502]: <info>  [1689892523.9786] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> disconnected
585269:Jul 20 17:35:24 ernesto-xps139370 NetworkManager[502]: <info>  [1689892524.4784] device (wlp2s0): supplicant interface state: disconnected -> scanning
585270:Jul 20 17:35:24 ernesto-xps139370 NetworkManager[502]: <info>  [1689892524.4784] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585271:Jul 20 17:35:28 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585272:Jul 20 17:35:29 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585273:Jul 20 17:35:29 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
585274:Jul 20 17:35:29 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
585275:Jul 20 17:35:29 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585276:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.3362] device (wlp2s0): supplicant interface state: scanning -> associating
585277:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.3362] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> associating
585278:Jul 20 17:35:29 ernesto-xps139370 kernel: wlp2s0: authenticated
585279:Jul 20 17:35:29 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:44 (try 1/3)
585280:Jul 20 17:35:29 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:44 (capab=0x11 status=0 aid=19)
585281:Jul 20 17:35:29 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:44
585282:Jul 20 17:35:29 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585283:Jul 20 17:35:29 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585284:Jul 20 17:35:29 ernesto-xps139370 kernel: wlp2s0: associated
585285-Jul 20 17:35:29 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585291-Jul 20 17:35:29 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585292:Jul 20 17:35:29 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:44
585293:Jul 20 17:35:29 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:44 [PTK=CCMP GTK=CCMP]
585294:Jul 20 17:35:29 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:44 completed [id=0 id_str=]
585295:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4133] device (wlp2s0): supplicant interface state: associating -> completed
585296:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4143] device (wlp2s0): ip:dhcp4: restarting
585297:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4417] dhcp4 (wlp2s0): canceled DHCP transaction
585298:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4417] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585299:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4417] dhcp4 (wlp2s0): state changed no lease
585300:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4417] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585301:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4418] device (wlp2s0): ip:dhcp6: restarting
585302:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4418] dhcp6 (wlp2s0): canceled DHCP transaction
585303:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4418] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585304:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4419] dhcp6 (wlp2s0): state changed no lease
585305:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4419] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585306:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4419] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
585307:Jul 20 17:35:29 ernesto-xps139370 NetworkManager[502]: <info>  [1689892529.4651] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585308-Jul 20 17:35:29 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
585311-Jul 20 17:35:29 ernesto-xps139370 systemd[1]: Started Network Manager Script Dispatcher Service.
585312:Jul 20 17:35:30 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-64 noise=-97 txrate=175600
585313:Jul 20 17:35:31 ernesto-xps139370 NetworkManager[502]: <info>  [1689892531.4498] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
585314:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Disassociation Imminent - Disassociation Timer 60
585315:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Preferred List Available
585316:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585317:Jul 20 17:35:32 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:44 for new auth to 0c:7c:28:b9:22:40
585318:Jul 20 17:35:32 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585319:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585320:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7003] device (wlp2s0): supplicant interface state: completed -> authenticating
585321:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7003] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585322:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585323:Jul 20 17:35:32 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585324:Jul 20 17:35:32 ernesto-xps139370 kernel: wlp2s0: authenticated
585325:Jul 20 17:35:32 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585326:Jul 20 17:35:32 ernesto-xps139370 kernel: wlp2s0: RX ReassocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=0 aid=8)
585327:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:40
585328:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585329:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585330:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7077] device (wlp2s0): supplicant interface state: authenticating -> associating
585331:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7077] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585332:Jul 20 17:35:32 ernesto-xps139370 kernel: wlp2s0: associated
585333-Jul 20 17:35:32 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585339-Jul 20 17:35:32 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585340:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:40 [PTK=CCMP GTK=CCMP]
585341:Jul 20 17:35:32 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:40 completed [id=0 id_str=]
585342:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7134] device (wlp2s0): supplicant interface state: associating -> completed
585343:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7144] device (wlp2s0): ip:dhcp4: restarting
585344:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7416] dhcp4 (wlp2s0): canceled DHCP transaction
585345:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7417] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585346:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7417] dhcp4 (wlp2s0): state changed no lease
585347:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7418] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585348:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7419] device (wlp2s0): ip:dhcp6: restarting
585349:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7419] dhcp6 (wlp2s0): canceled DHCP transaction
585350:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7420] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585351:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7420] dhcp6 (wlp2s0): state changed no lease
585352:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7420] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585353:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7421] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
585354:Jul 20 17:35:32 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:40
585355:Jul 20 17:35:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892532.7716] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585356:Jul 20 17:35:33 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-72 noise=-93 txrate=234000
585357:Jul 20 17:35:34 ernesto-xps139370 NetworkManager[502]: <info>  [1689892534.8632] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
585358:Jul 20 17:35:39 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585359-Jul 20 17:35:39 ernesto-xps139370 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
585360:Jul 20 17:35:39 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:40 for new auth to 0c:7c:28:b9:22:44
585361:Jul 20 17:35:39 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
585362:Jul 20 17:35:39 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585363:Jul 20 17:35:39 ernesto-xps139370 NetworkManager[502]: <info>  [1689892539.6461] device (wlp2s0): supplicant interface state: completed -> authenticating
585364:Jul 20 17:35:39 ernesto-xps139370 NetworkManager[502]: <info>  [1689892539.6461] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585365:Jul 20 17:35:39 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
585366:Jul 20 17:35:39 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 2/3)
585367:Jul 20 17:35:39 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 3/3)
585368:Jul 20 17:35:39 ernesto-xps139370 kernel: wlp2s0: authentication with 0c:7c:28:b9:22:44 timed out
585369-Jul 20 17:35:39 ernesto-xps139370 wpa_supplicant[567]: BSSID 0c:7c:28:b9:22:44 ignore list count incremented to 2, ignoring for 10 seconds
585370:Jul 20 17:35:39 ernesto-xps139370 NetworkManager[502]: <info>  [1689892539.9789] device (wlp2s0): supplicant interface state: authenticating -> disconnected
585371:Jul 20 17:35:39 ernesto-xps139370 NetworkManager[502]: <info>  [1689892539.9789] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> disconnected
585372:Jul 20 17:35:40 ernesto-xps139370 NetworkManager[502]: <info>  [1689892540.0788] device (wlp2s0): supplicant interface state: disconnected -> scanning
585373:Jul 20 17:35:40 ernesto-xps139370 NetworkManager[502]: <info>  [1689892540.0788] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585374:Jul 20 17:35:40 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585375:Jul 20 17:35:40 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585376:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585377:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585378:Jul 20 17:35:40 ernesto-xps139370 NetworkManager[502]: <info>  [1689892540.3254] device (wlp2s0): supplicant interface state: scanning -> authenticating
585379:Jul 20 17:35:40 ernesto-xps139370 NetworkManager[502]: <info>  [1689892540.3254] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
585380:Jul 20 17:35:40 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585381:Jul 20 17:35:40 ernesto-xps139370 NetworkManager[502]: <info>  [1689892540.3262] device (wlp2s0): supplicant interface state: authenticating -> associating
585382:Jul 20 17:35:40 ernesto-xps139370 NetworkManager[502]: <info>  [1689892540.3262] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585383:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: authenticated
585384:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585385:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=8)
585386:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585387:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 2/3)
585388:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=8)
585389:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585390:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 3/3)
585391:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=8)
585392:Jul 20 17:35:40 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585393:Jul 20 17:35:41 ernesto-xps139370 kernel: wlp2s0: association with 0c:7c:28:b9:22:40 timed out
585394:Jul 20 17:35:41 ernesto-xps139370 NetworkManager[502]: <info>  [1689892541.2723] device (wlp2s0): supplicant interface state: associating -> disconnected
585395:Jul 20 17:35:41 ernesto-xps139370 NetworkManager[502]: <info>  [1689892541.2723] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> disconnected
585396:Jul 20 17:35:41 ernesto-xps139370 NetworkManager[502]: <info>  [1689892541.7719] device (wlp2s0): supplicant interface state: disconnected -> scanning
585397:Jul 20 17:35:41 ernesto-xps139370 NetworkManager[502]: <info>  [1689892541.7720] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585398-Jul 20 17:35:43 ernesto-xps139370 dbus-daemon[487]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.35' (uid=1000 pid=910 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
585399-Jul 20 17:35:43 ernesto-xps139370 dbus-daemon[487]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
585400:Jul 20 17:35:45 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585401:Jul 20 17:35:46 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585402:Jul 20 17:35:46 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
585403:Jul 20 17:35:46 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
585404:Jul 20 17:35:46 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585405:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.6328] device (wlp2s0): supplicant interface state: scanning -> associating
585406:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.6328] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> associating
585407:Jul 20 17:35:46 ernesto-xps139370 kernel: wlp2s0: authenticated
585408:Jul 20 17:35:46 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:44 (try 1/3)
585409:Jul 20 17:35:46 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:44 (capab=0x11 status=0 aid=27)
585410:Jul 20 17:35:46 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:44
585411:Jul 20 17:35:46 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585412:Jul 20 17:35:46 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585413:Jul 20 17:35:46 ernesto-xps139370 kernel: wlp2s0: associated
585414-Jul 20 17:35:46 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585420-Jul 20 17:35:46 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585421:Jul 20 17:35:46 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:44 [PTK=CCMP GTK=CCMP]
585422:Jul 20 17:35:46 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:44 completed [id=0 id_str=]
585423:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7046] device (wlp2s0): supplicant interface state: associating -> completed
585424:Jul 20 17:35:46 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:44
585425:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7055] device (wlp2s0): ip:dhcp4: restarting
585426:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7283] dhcp4 (wlp2s0): canceled DHCP transaction
585427:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7284] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585428:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7284] dhcp4 (wlp2s0): state changed no lease
585429:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7284] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585430:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7285] device (wlp2s0): ip:dhcp6: restarting
585431:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7285] dhcp6 (wlp2s0): canceled DHCP transaction
585432:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7285] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585433:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7285] dhcp6 (wlp2s0): state changed no lease
585434:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7285] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585435:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7286] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
585436:Jul 20 17:35:46 ernesto-xps139370 NetworkManager[502]: <info>  [1689892546.7494] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585437-Jul 20 17:35:46 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
585440-Jul 20 17:35:46 ernesto-xps139370 systemd[1]: Started Network Manager Script Dispatcher Service.
585441:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Disassociation Imminent - Disassociation Timer 60
585442:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Preferred List Available
585443:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585444:Jul 20 17:35:48 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:44 for new auth to 0c:7c:28:b9:22:40
585445:Jul 20 17:35:48 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585446:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585447:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2071] device (wlp2s0): supplicant interface state: completed -> authenticating
585448:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2071] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585449:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585450:Jul 20 17:35:48 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585451:Jul 20 17:35:48 ernesto-xps139370 kernel: wlp2s0: authenticated
585452:Jul 20 17:35:48 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585453:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2100] device (wlp2s0): supplicant interface state: authenticating -> associating
585454:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2100] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585455:Jul 20 17:35:48 ernesto-xps139370 kernel: wlp2s0: RX ReassocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=0 aid=26)
585456:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:40
585457:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585458:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585459:Jul 20 17:35:48 ernesto-xps139370 kernel: wlp2s0: associated
585460-Jul 20 17:35:48 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585466-Jul 20 17:35:48 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585467:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:40 [PTK=CCMP GTK=CCMP]
585468:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:40 completed [id=0 id_str=]
585469:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2199] device (wlp2s0): supplicant interface state: associating -> completed
585470:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2209] device (wlp2s0): ip:dhcp4: restarting
585471:Jul 20 17:35:48 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:40
585472:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2417] dhcp4 (wlp2s0): canceled DHCP transaction
585473:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2417] dhcp4 (wlp2s0): state changed no lease
585474:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2417] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585475:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2418] device (wlp2s0): ip:dhcp6: restarting
585476:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2418] dhcp6 (wlp2s0): canceled DHCP transaction
585477:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2418] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585478:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2418] dhcp6 (wlp2s0): state changed no lease
585479:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2418] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585480:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2419] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
585481:Jul 20 17:35:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892548.2669] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585482:Jul 20 17:35:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-70 noise=-93 txrate=234000
585483:Jul 20 17:35:50 ernesto-xps139370 NetworkManager[502]: <info>  [1689892550.3265] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
585484:Jul 20 17:35:54 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585485:Jul 20 17:35:54 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:40 for new auth to 0c:7c:28:b9:22:44
585486:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
585487:Jul 20 17:35:55 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585488:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.0928] device (wlp2s0): supplicant interface state: completed -> authenticating
585489:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.0928] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585490:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
585491:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 2/3)
585492:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 3/3)
585493:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: authentication with 0c:7c:28:b9:22:44 timed out
585494-Jul 20 17:35:55 ernesto-xps139370 wpa_supplicant[567]: BSSID 0c:7c:28:b9:22:44 ignore list count incremented to 2, ignoring for 10 seconds
585495:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.4356] device (wlp2s0): supplicant interface state: authenticating -> disconnected
585496:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.4356] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> disconnected
585497:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.5357] device (wlp2s0): supplicant interface state: disconnected -> scanning
585498:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.5357] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585499:Jul 20 17:35:55 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585500:Jul 20 17:35:55 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585501:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585502:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.7823] device (wlp2s0): supplicant interface state: scanning -> authenticating
585503:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.7823] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
585504:Jul 20 17:35:55 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585505:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.7837] device (wlp2s0): supplicant interface state: authenticating -> associating
585506:Jul 20 17:35:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892555.7837] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585507:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585508:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: authenticated
585509:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585510:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=26)
585511:Jul 20 17:35:55 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585512:Jul 20 17:35:56 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 2/3)
585513:Jul 20 17:35:56 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=26)
585514:Jul 20 17:35:56 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585515:Jul 20 17:35:56 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 3/3)
585516:Jul 20 17:35:56 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=26)
585517:Jul 20 17:35:56 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585518:Jul 20 17:35:56 ernesto-xps139370 kernel: wlp2s0: association with 0c:7c:28:b9:22:40 timed out
585519:Jul 20 17:35:56 ernesto-xps139370 NetworkManager[502]: <info>  [1689892556.7221] device (wlp2s0): supplicant interface state: associating -> disconnected
585520:Jul 20 17:35:56 ernesto-xps139370 NetworkManager[502]: <info>  [1689892556.7222] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> disconnected
585521-Jul 20 17:35:56 ernesto-xps139370 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
585522:Jul 20 17:35:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689892557.2217] device (wlp2s0): supplicant interface state: disconnected -> scanning
585523:Jul 20 17:35:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689892557.2218] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585524:Jul 20 17:36:01 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585525:Jul 20 17:36:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585526:Jul 20 17:36:02 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
585527:Jul 20 17:36:02 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
585528:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.0823] device (wlp2s0): supplicant interface state: scanning -> authenticating
585529:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.0823] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
585530:Jul 20 17:36:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585531:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.0832] device (wlp2s0): supplicant interface state: authenticating -> associating
585532:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.0832] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585533:Jul 20 17:36:02 ernesto-xps139370 kernel: wlp2s0: authenticated
585534:Jul 20 17:36:02 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:44 (try 1/3)
585535:Jul 20 17:36:02 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:44 (capab=0x11 status=0 aid=29)
585536:Jul 20 17:36:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:44
585537:Jul 20 17:36:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585538:Jul 20 17:36:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585539:Jul 20 17:36:02 ernesto-xps139370 kernel: wlp2s0: associated
585540-Jul 20 17:36:02 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585546-Jul 20 17:36:02 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585547:Jul 20 17:36:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:44 [PTK=CCMP GTK=CCMP]
585548:Jul 20 17:36:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:44 completed [id=0 id_str=]
585549:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1538] device (wlp2s0): supplicant interface state: associating -> completed
585550:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1547] device (wlp2s0): ip:dhcp4: restarting
585551:Jul 20 17:36:02 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:44
585552:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1683] dhcp4 (wlp2s0): canceled DHCP transaction
585553:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1683] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585554:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1684] dhcp4 (wlp2s0): state changed no lease
585555:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1684] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585556:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1685] device (wlp2s0): ip:dhcp6: restarting
585557:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1685] dhcp6 (wlp2s0): canceled DHCP transaction
585558:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1685] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585559:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1685] dhcp6 (wlp2s0): state changed no lease
585560:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1685] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585561:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1686] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
585562:Jul 20 17:36:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892562.1819] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585563-Jul 20 17:36:02 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
585566-Jul 20 17:36:02 ernesto-xps139370 systemd[1]: Started Network Manager Script Dispatcher Service.
585567:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-76 noise=-98 txrate=175600
585568:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Disassociation Imminent - Disassociation Timer 60
585569:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Preferred List Available
585570:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585571:Jul 20 17:36:03 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:44 for new auth to 0c:7c:28:b9:22:40
585572:Jul 20 17:36:03 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585573:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585574:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.7676] device (wlp2s0): supplicant interface state: completed -> authenticating
585575:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.7676] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585576:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585577:Jul 20 17:36:03 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585578:Jul 20 17:36:03 ernesto-xps139370 kernel: wlp2s0: authenticated
585579:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.7712] device (wlp2s0): supplicant interface state: authenticating -> associating
585580:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.7712] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585581:Jul 20 17:36:03 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585582:Jul 20 17:36:03 ernesto-xps139370 kernel: wlp2s0: RX ReassocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=0 aid=15)
585583:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:40
585584:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585585:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585586:Jul 20 17:36:03 ernesto-xps139370 kernel: wlp2s0: associated
585587-Jul 20 17:36:03 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585593-Jul 20 17:36:03 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585594:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:40 [PTK=CCMP GTK=CCMP]
585595:Jul 20 17:36:03 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:40 completed [id=0 id_str=]
585596:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.7831] device (wlp2s0): supplicant interface state: associating -> 4way_handshake
585597:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.7831] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> 4way_handshake
585598:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.7881] device (wlp2s0): supplicant interface state: 4way_handshake -> completed
585599:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.7891] device (wlp2s0): ip:dhcp4: restarting
585600:Jul 20 17:36:03 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:40
585601:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8183] dhcp4 (wlp2s0): canceled DHCP transaction
585602:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8183] dhcp4 (wlp2s0): state changed no lease
585603:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8184] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585604:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8184] device (wlp2s0): ip:dhcp6: restarting
585605:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8185] dhcp6 (wlp2s0): canceled DHCP transaction
585606:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8185] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585607:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8185] dhcp6 (wlp2s0): state changed no lease
585608:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8185] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585609:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8185] device (p2p-dev-wlp2s0): supplicant management interface state: 4way_handshake -> completed
585610:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8247] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
585611:Jul 20 17:36:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689892563.8396] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585612:Jul 20 17:36:04 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-71 noise=-93 txrate=234000
585613:Jul 20 17:36:10 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585614:Jul 20 17:36:10 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:40 for new auth to 0c:7c:28:b9:22:44
585615:Jul 20 17:36:10 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
585616:Jul 20 17:36:10 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585617:Jul 20 17:36:10 ernesto-xps139370 NetworkManager[502]: <info>  [1689892570.6857] device (wlp2s0): supplicant interface state: completed -> authenticating
585618:Jul 20 17:36:10 ernesto-xps139370 NetworkManager[502]: <info>  [1689892570.6857] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585619:Jul 20 17:36:10 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
585620:Jul 20 17:36:10 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 2/3)
585621:Jul 20 17:36:10 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 3/3)
585622:Jul 20 17:36:10 ernesto-xps139370 kernel: wlp2s0: authentication with 0c:7c:28:b9:22:44 timed out
585623-Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: BSSID 0c:7c:28:b9:22:44 ignore list count incremented to 2, ignoring for 10 seconds
585624:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.0185] device (wlp2s0): supplicant interface state: authenticating -> disconnected
585625:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.0185] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> disconnected
585626:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.1185] device (wlp2s0): supplicant interface state: disconnected -> scanning
585627:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.1186] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585628:Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585629:Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585630:Jul 20 17:36:11 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585631:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.3615] device (wlp2s0): supplicant interface state: scanning -> authenticating
585632:Jul 20 17:36:11 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585633:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.3615] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
585634:Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585635:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.3630] device (wlp2s0): supplicant interface state: authenticating -> associating
585636:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.3631] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585637:Jul 20 17:36:11 ernesto-xps139370 kernel: wlp2s0: authenticated
585638:Jul 20 17:36:11 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585639:Jul 20 17:36:11 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=0 aid=17)
585640:Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:40
585641:Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585642:Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585643:Jul 20 17:36:11 ernesto-xps139370 kernel: wlp2s0: associated
585644-Jul 20 17:36:11 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585650-Jul 20 17:36:11 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585651:Jul 20 17:36:11 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:40
585652:Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:40 [PTK=CCMP GTK=CCMP]
585653:Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:40 completed [id=0 id_str=]
585654:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4635] device (wlp2s0): supplicant interface state: associating -> completed
585655:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4645] device (wlp2s0): ip:dhcp4: restarting
585656:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4783] dhcp4 (wlp2s0): canceled DHCP transaction
585657:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4783] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585658:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4784] dhcp4 (wlp2s0): state changed no lease
585659:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4784] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585660:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4785] device (wlp2s0): ip:dhcp6: restarting
585661:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4786] dhcp6 (wlp2s0): canceled DHCP transaction
585662:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4786] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585663:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4786] dhcp6 (wlp2s0): state changed no lease
585664:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4786] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585665:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4787] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
585666:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4787] device (wlp2s0): ip:dhcp4: restarting
585667:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4788] dhcp4 (wlp2s0): canceled DHCP transaction
585668:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4788] dhcp4 (wlp2s0): state changed no lease
585669:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4788] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585670:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4789] device (wlp2s0): ip:dhcp6: restarting
585671:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4789] dhcp6 (wlp2s0): canceled DHCP transaction
585672:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4789] dhcp6 (wlp2s0): state changed no lease
585673:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.4789] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585674:Jul 20 17:36:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892571.5009] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585675:Jul 20 17:36:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-68 noise=-93 txrate=234000
585676-Jul 20 17:36:12 ernesto-xps139370 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
585677:Jul 20 17:36:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892573.4875] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
585678-Jul 20 17:36:13 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
585682-Jul 20 17:36:23 ernesto-xps139370 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
585683:Jul 20 17:36:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585684:Jul 20 17:36:48 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:40 for new auth to 0c:7c:28:b9:22:44
585685:Jul 20 17:36:48 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
585686:Jul 20 17:36:48 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585687:Jul 20 17:36:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892608.1992] device (wlp2s0): supplicant interface state: completed -> authenticating
585688:Jul 20 17:36:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892608.1992] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585689:Jul 20 17:36:48 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
585690:Jul 20 17:36:48 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 2/3)
585691:Jul 20 17:36:48 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 3/3)
585692:Jul 20 17:36:48 ernesto-xps139370 kernel: wlp2s0: authentication with 0c:7c:28:b9:22:44 timed out
585693-Jul 20 17:36:48 ernesto-xps139370 wpa_supplicant[567]: BSSID 0c:7c:28:b9:22:44 ignore list count incremented to 3, ignoring for 60 seconds
585694:Jul 20 17:36:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892608.5388] device (wlp2s0): supplicant interface state: authenticating -> disconnected
585695:Jul 20 17:36:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892608.5388] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> disconnected
585696:Jul 20 17:36:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892608.6388] device (wlp2s0): supplicant interface state: disconnected -> scanning
585697:Jul 20 17:36:48 ernesto-xps139370 NetworkManager[502]: <info>  [1689892608.6388] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585698:Jul 20 17:36:49 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585699:Jul 20 17:36:52 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585700:Jul 20 17:36:53 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585701:Jul 20 17:36:53 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585702:Jul 20 17:36:53 ernesto-xps139370 NetworkManager[502]: <info>  [1689892613.5745] device (wlp2s0): supplicant interface state: scanning -> authenticating
585703:Jul 20 17:36:53 ernesto-xps139370 NetworkManager[502]: <info>  [1689892613.5745] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
585704:Jul 20 17:36:53 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585705:Jul 20 17:36:53 ernesto-xps139370 kernel: wlp2s0: authenticated
585706:Jul 20 17:36:53 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585707:Jul 20 17:36:53 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585708:Jul 20 17:36:53 ernesto-xps139370 NetworkManager[502]: <info>  [1689892613.5756] device (wlp2s0): supplicant interface state: authenticating -> associating
585709:Jul 20 17:36:53 ernesto-xps139370 NetworkManager[502]: <info>  [1689892613.5756] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585710:Jul 20 17:36:53 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=17)
585711:Jul 20 17:36:53 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585712:Jul 20 17:36:53 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 2/3)
585713:Jul 20 17:36:53 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=17)
585714:Jul 20 17:36:53 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585715:Jul 20 17:36:54 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 3/3)
585716:Jul 20 17:36:54 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=30 aid=17)
585717:Jul 20 17:36:54 ernesto-xps139370 kernel: wlp2s0: 0c:7c:28:b9:22:40 rejected association temporarily; comeback duration 292 TU (299 ms)
585718:Jul 20 17:36:54 ernesto-xps139370 kernel: wlp2s0: association with 0c:7c:28:b9:22:40 timed out
585719:Jul 20 17:36:54 ernesto-xps139370 NetworkManager[502]: <info>  [1689892614.5084] device (wlp2s0): supplicant interface state: associating -> disconnected
585720:Jul 20 17:36:54 ernesto-xps139370 NetworkManager[502]: <info>  [1689892614.5084] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> disconnected
585721:Jul 20 17:36:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892615.0085] device (wlp2s0): supplicant interface state: disconnected -> scanning
585722:Jul 20 17:36:55 ernesto-xps139370 NetworkManager[502]: <info>  [1689892615.0086] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585723-Jul 20 17:36:58 ernesto-xps139370 dbus-daemon[487]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.35' (uid=1000 pid=910 comm="/usr/lib/org_kde_powerdevil") (using servicehelper)
585724-Jul 20 17:36:58 ernesto-xps139370 dbus-daemon[487]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
585725:Jul 20 17:36:59 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:3c (SSID='27131' freq=2412 MHz)
585726:Jul 20 17:36:59 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:3c
585727:Jul 20 17:36:59 ernesto-xps139370 kernel: wlp2s0: 80 MHz not supported, disabling VHT
585728:Jul 20 17:36:59 ernesto-xps139370 NetworkManager[502]: <info>  [1689892619.9579] device (wlp2s0): supplicant interface state: scanning -> authenticating
585729:Jul 20 17:36:59 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:3c (try 1/3)
585730:Jul 20 17:36:59 ernesto-xps139370 NetworkManager[502]: <info>  [1689892619.9579] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
585731:Jul 20 17:36:59 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:3c (SSID='27131' freq=2412 MHz)
585732:Jul 20 17:36:59 ernesto-xps139370 NetworkManager[502]: <info>  [1689892619.9635] device (wlp2s0): supplicant interface state: authenticating -> associating
585733:Jul 20 17:36:59 ernesto-xps139370 NetworkManager[502]: <info>  [1689892619.9635] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585734:Jul 20 17:36:59 ernesto-xps139370 kernel: wlp2s0: authenticated
585735:Jul 20 17:36:59 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:3c (try 1/3)
585736:Jul 20 17:36:59 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:3c (capab=0x411 status=0 aid=29)
585737:Jul 20 17:36:59 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:3c
585738:Jul 20 17:36:59 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585739:Jul 20 17:36:59 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585740:Jul 20 17:36:59 ernesto-xps139370 kernel: wlp2s0: associated
585741-Jul 20 17:36:59 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585747-Jul 20 17:36:59 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585748:Jul 20 17:36:59 ernesto-xps139370 NetworkManager[502]: <info>  [1689892619.9773] device (wlp2s0): supplicant interface state: associating -> 4way_handshake
585749:Jul 20 17:36:59 ernesto-xps139370 NetworkManager[502]: <info>  [1689892619.9773] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> 4way_handshake
585750:Jul 20 17:37:00 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:3c [PTK=CCMP GTK=CCMP]
585751:Jul 20 17:37:00 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:3c completed [id=0 id_str=]
585752:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0469] device (wlp2s0): supplicant interface state: 4way_handshake -> completed
585753:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0479] device (wlp2s0): ip:dhcp4: restarting
585754:Jul 20 17:37:00 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:3c
585755:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0650] dhcp4 (wlp2s0): canceled DHCP transaction
585756:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0650] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585757:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0650] dhcp4 (wlp2s0): state changed no lease
585758:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0651] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585759:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0651] device (wlp2s0): ip:dhcp6: restarting
585760:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0651] dhcp6 (wlp2s0): canceled DHCP transaction
585761:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0652] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585762:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0652] dhcp6 (wlp2s0): state changed no lease
585763:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0652] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585764:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0652] device (p2p-dev-wlp2s0): supplicant management interface state: 4way_handshake -> completed
585765:Jul 20 17:37:00 ernesto-xps139370 NetworkManager[502]: <info>  [1689892620.0759] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585766-Jul 20 17:37:00 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
585770-Jul 20 17:37:00 ernesto-xps139370 plasmashell[9124]: [9119:9148:0720/173700.654453:ERROR:connection_factory_impl.cc(428)] Failed to connect to MCS endpoint with error -105
585771:Jul 20 17:37:00 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=-105 txrate=144400
585772:Jul 20 17:37:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892622.0737] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
585773-Jul 20 17:37:10 ernesto-xps139370 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
585774:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Disassociation Imminent - Disassociation Timer 60
585775:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WNM: Preferred List Available
585776:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585777:Jul 20 17:37:11 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:3c for new auth to 0c:7c:28:b9:22:40
585778:Jul 20 17:37:11 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585779:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4107] device (wlp2s0): supplicant interface state: completed -> authenticating
585780:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4107] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585781:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585782:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585783:Jul 20 17:37:11 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585784:Jul 20 17:37:11 ernesto-xps139370 kernel: wlp2s0: authenticated
585785:Jul 20 17:37:11 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585786:Jul 20 17:37:11 ernesto-xps139370 kernel: wlp2s0: RX ReassocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=0 aid=18)
585787:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4150] device (wlp2s0): supplicant interface state: authenticating -> associating
585788:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4150] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585789:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:40
585790:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585791:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585792:Jul 20 17:37:11 ernesto-xps139370 kernel: wlp2s0: associated
585793-Jul 20 17:37:11 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585799-Jul 20 17:37:11 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585800:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:40 [PTK=CCMP GTK=CCMP]
585801:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:40 completed [id=0 id_str=]
585802:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4247] device (wlp2s0): supplicant interface state: associating -> completed
585803:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4257] device (wlp2s0): ip:dhcp4: restarting
585804:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4550] dhcp4 (wlp2s0): canceled DHCP transaction
585805:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4550] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585806:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4550] dhcp4 (wlp2s0): state changed no lease
585807:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4551] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585808:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4551] device (wlp2s0): ip:dhcp6: restarting
585809:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4552] dhcp6 (wlp2s0): canceled DHCP transaction
585810:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4552] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585811:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4552] dhcp6 (wlp2s0): state changed no lease
585812:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4552] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585813:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4552] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
585814:Jul 20 17:37:11 ernesto-xps139370 NetworkManager[502]: <info>  [1689892631.4812] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585815:Jul 20 17:37:11 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:40
585816-Jul 20 17:37:11 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
585819-Jul 20 17:37:11 ernesto-xps139370 systemd[1]: Started Network Manager Script Dispatcher Service.
585820:Jul 20 17:37:11 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-71 noise=-92 txrate=234000
585821:Jul 20 17:37:13 ernesto-xps139370 NetworkManager[502]: <info>  [1689892633.4600] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
585822-Jul 20 17:37:21 ernesto-xps139370 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
585853-Jul 20 17:38:19 ernesto-xps139370 systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dclean.service.mount: Deactivated successfully.
585854:Jul 20 17:38:24 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
585855:Jul 20 17:38:24 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:40 for new auth to 0c:7c:28:b9:22:44
585856:Jul 20 17:38:24 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
585857:Jul 20 17:38:24 ernesto-xps139370 NetworkManager[502]: <info>  [1689892704.8376] device (wlp2s0): supplicant interface state: completed -> authenticating
585858:Jul 20 17:38:24 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
585859:Jul 20 17:38:24 ernesto-xps139370 NetworkManager[502]: <info>  [1689892704.8377] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
585860:Jul 20 17:38:24 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
585861:Jul 20 17:38:24 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 2/3)
585862:Jul 20 17:38:25 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 3/3)
585863:Jul 20 17:38:25 ernesto-xps139370 kernel: wlp2s0: authentication with 0c:7c:28:b9:22:44 timed out
585864-Jul 20 17:38:25 ernesto-xps139370 wpa_supplicant[567]: BSSID 0c:7c:28:b9:22:44 ignore list count incremented to 4, ignoring for 120 seconds
585865:Jul 20 17:38:25 ernesto-xps139370 NetworkManager[502]: <info>  [1689892705.1803] device (wlp2s0): supplicant interface state: authenticating -> disconnected
585866:Jul 20 17:38:25 ernesto-xps139370 NetworkManager[502]: <info>  [1689892705.1804] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> disconnected
585867:Jul 20 17:38:25 ernesto-xps139370 NetworkManager[502]: <info>  [1689892705.2803] device (wlp2s0): supplicant interface state: disconnected -> scanning
585868:Jul 20 17:38:25 ernesto-xps139370 NetworkManager[502]: <info>  [1689892705.2804] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
585869:Jul 20 17:38:26 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585870:Jul 20 17:38:29 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
585871:Jul 20 17:38:30 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585872:Jul 20 17:38:30 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
585873:Jul 20 17:38:30 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
585874:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.2177] device (wlp2s0): supplicant interface state: scanning -> authenticating
585875:Jul 20 17:38:30 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
585876:Jul 20 17:38:30 ernesto-xps139370 kernel: wlp2s0: authenticated
585877:Jul 20 17:38:30 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
585878:Jul 20 17:38:30 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=0 aid=27)
585879:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.2178] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
585880:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.2199] device (wlp2s0): supplicant interface state: authenticating -> associating
585881:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.2200] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
585882:Jul 20 17:38:30 ernesto-xps139370 kernel: wlp2s0: associated
585883-Jul 20 17:38:30 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
585889-Jul 20 17:38:30 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
585890:Jul 20 17:38:30 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:40
585891:Jul 20 17:38:30 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:40
585892:Jul 20 17:38:30 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
585893:Jul 20 17:38:30 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
585894:Jul 20 17:38:30 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:40 [PTK=CCMP GTK=CCMP]
585895:Jul 20 17:38:30 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:40 completed [id=0 id_str=]
585896:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3103] device (wlp2s0): supplicant interface state: associating -> completed
585897:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3114] device (wlp2s0): ip:dhcp4: restarting
585898:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3316] dhcp4 (wlp2s0): canceled DHCP transaction
585899:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3317] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585900:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3319] dhcp4 (wlp2s0): state changed no lease
585901:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3319] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585902:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3321] device (wlp2s0): ip:dhcp6: restarting
585903:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3321] dhcp6 (wlp2s0): canceled DHCP transaction
585904:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3321] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585905:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3321] dhcp6 (wlp2s0): state changed no lease
585906:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3321] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585907:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3322] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
585908:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3322] device (wlp2s0): ip:dhcp4: restarting
585909:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3323] dhcp4 (wlp2s0): canceled DHCP transaction
585910:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3323] dhcp4 (wlp2s0): state changed no lease
585911:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3323] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585912:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3323] device (wlp2s0): ip:dhcp6: restarting
585913:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3324] dhcp6 (wlp2s0): canceled DHCP transaction
585914:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3324] dhcp6 (wlp2s0): state changed no lease
585915:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.3324] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
585916:Jul 20 17:38:30 ernesto-xps139370 NetworkManager[502]: <info>  [1689892710.6147] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
585917-Jul 20 17:38:30 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
585918:Jul 20 17:38:30 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-73 noise=-93 txrate=234000
585919-Jul 20 17:38:30 ernesto-xps139370 systemd[1]: Starting Network Manager Script Dispatcher Service...
585924-Jul 20 17:38:31 ernesto-xps139370 pipewire[992]: mod.client-node: 0x55ae5ee1c870: unknown peer 0x55ae5ee081c0 fd:55
585925:Jul 20 17:38:32 ernesto-xps139370 NetworkManager[502]: <info>  [1689892712.3427] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
585926-Jul 20 17:38:33 ernesto-xps139370 kwin_wayland[721]: kwin_screencast: Dropping a screencast frame because the compositor is slow
588443-Jul 20 17:40:56 ernesto-xps139370 kde-print-queue[9044]: 4 "Processing page 120..."
588444:Jul 20 17:40:56 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
588445:Jul 20 17:40:56 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:40 for new auth to 0c:7c:28:b9:22:44
588446:Jul 20 17:40:56 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
588447:Jul 20 17:40:56 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
588448:Jul 20 17:40:56 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
588449:Jul 20 17:40:56 ernesto-xps139370 NetworkManager[502]: <info>  [1689892856.8986] device (wlp2s0): supplicant interface state: completed -> authenticating
588450:Jul 20 17:40:56 ernesto-xps139370 NetworkManager[502]: <info>  [1689892856.8987] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
588451:Jul 20 17:40:57 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 2/3)
588452:Jul 20 17:40:57 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 3/3)
588453:Jul 20 17:40:57 ernesto-xps139370 kernel: wlp2s0: authentication with 0c:7c:28:b9:22:44 timed out
588454-Jul 20 17:40:57 ernesto-xps139370 wpa_supplicant[567]: BSSID 0c:7c:28:b9:22:44 ignore list count incremented to 5, ignoring for 600 seconds
588455:Jul 20 17:40:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689892857.2469] device (wlp2s0): supplicant interface state: authenticating -> disconnected
588456:Jul 20 17:40:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689892857.2470] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> disconnected
588457:Jul 20 17:40:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689892857.3469] device (wlp2s0): supplicant interface state: disconnected -> scanning
588458:Jul 20 17:40:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689892857.3470] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
588459:Jul 20 17:40:58 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
588460:Jul 20 17:41:01 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
588461:Jul 20 17:41:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
588462:Jul 20 17:41:02 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
588463:Jul 20 17:41:02 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
588464:Jul 20 17:41:02 ernesto-xps139370 kernel: wlp2s0: authenticated
588465:Jul 20 17:41:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
588466:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.2954] device (wlp2s0): supplicant interface state: scanning -> authenticating
588467:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.2955] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
588468:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.2991] device (wlp2s0): supplicant interface state: authenticating -> associating
588469:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.2992] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
588470:Jul 20 17:41:02 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
588471:Jul 20 17:41:02 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=0 aid=9)
588472:Jul 20 17:41:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:40
588473:Jul 20 17:41:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
588474:Jul 20 17:41:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
588475:Jul 20 17:41:02 ernesto-xps139370 kernel: wlp2s0: associated
588476-Jul 20 17:41:02 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
588482-Jul 20 17:41:02 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
588483:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.3127] device (wlp2s0): supplicant interface state: associating -> 4way_handshake
588484:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.3128] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> 4way_handshake
588485:Jul 20 17:41:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:40 [PTK=CCMP GTK=CCMP]
588486:Jul 20 17:41:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:40 completed [id=0 id_str=]
588487:Jul 20 17:41:02 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:40
588488:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4026] device (wlp2s0): supplicant interface state: 4way_handshake -> completed
588489:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4042] device (wlp2s0): ip:dhcp4: restarting
588490:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4350] dhcp4 (wlp2s0): canceled DHCP transaction
588491:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4350] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
588492:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4350] dhcp4 (wlp2s0): state changed no lease
588493:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4351] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
588494:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4352] device (wlp2s0): ip:dhcp6: restarting
588495:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4352] dhcp6 (wlp2s0): canceled DHCP transaction
588496:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4353] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
588497:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4353] dhcp6 (wlp2s0): state changed no lease
588498:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4353] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
588499:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4354] device (p2p-dev-wlp2s0): supplicant management interface state: 4way_handshake -> completed
588500:Jul 20 17:41:02 ernesto-xps139370 NetworkManager[502]: <info>  [1689892862.4588] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
588501-Jul 20 17:41:02 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
588504-Jul 20 17:41:02 ernesto-xps139370 systemd[1]: Started Network Manager Script Dispatcher Service.
588505:Jul 20 17:41:02 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-70 noise=-93 txrate=234000
588506-Jul 20 17:41:04 ernesto-xps139370 kde-print-queue[9044]: "Canon_MF4700_Series" "Canon_MF4700_Series"
588525-Jul 20 17:41:04 ernesto-xps139370 kde-print-queue[9044]: 4 "Processing page 121..."
588526:Jul 20 17:41:04 ernesto-xps139370 NetworkManager[502]: <info>  [1689892864.4401] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
588527-Jul 20 17:41:04 ernesto-xps139370 kde-print-queue[9044]: "Canon_MF4700_Series" "Canon_MF4700_Series"
593481-Jul 20 17:52:49 ernesto-xps139370 kde-print-queue[9044]: 4 "Processing page 366..."
593482:Jul 20 17:52:51 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:44 (SSID='27131' freq=5745 MHz)
593483:Jul 20 17:52:51 ernesto-xps139370 kernel: wlp2s0: disconnect from AP 0c:7c:28:b9:22:40 for new auth to 0c:7c:28:b9:22:44
593484:Jul 20 17:52:51 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:44
593485:Jul 20 17:52:51 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 1/3)
593486:Jul 20 17:52:51 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
593487:Jul 20 17:52:51 ernesto-xps139370 NetworkManager[502]: <info>  [1689893571.8555] device (wlp2s0): supplicant interface state: completed -> authenticating
593488:Jul 20 17:52:51 ernesto-xps139370 NetworkManager[502]: <info>  [1689893571.8556] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> authenticating
593489:Jul 20 17:52:51 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 2/3)
593490:Jul 20 17:52:52 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:44 (try 3/3)
593491:Jul 20 17:52:52 ernesto-xps139370 kernel: wlp2s0: authentication with 0c:7c:28:b9:22:44 timed out
593492-Jul 20 17:52:52 ernesto-xps139370 wpa_supplicant[567]: BSSID 0c:7c:28:b9:22:44 ignore list count incremented to 6, ignoring for 1800 seconds
593493:Jul 20 17:52:52 ernesto-xps139370 NetworkManager[502]: <info>  [1689893572.2002] device (wlp2s0): supplicant interface state: authenticating -> disconnected
593494:Jul 20 17:52:52 ernesto-xps139370 NetworkManager[502]: <info>  [1689893572.2003] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> disconnected
593495:Jul 20 17:52:52 ernesto-xps139370 NetworkManager[502]: <info>  [1689893572.3002] device (wlp2s0): supplicant interface state: disconnected -> scanning
593496:Jul 20 17:52:52 ernesto-xps139370 NetworkManager[502]: <info>  [1689893572.3003] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
593497:Jul 20 17:52:53 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
593498:Jul 20 17:52:56 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
593499:Jul 20 17:52:57 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: SME: Trying to authenticate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
593500:Jul 20 17:52:57 ernesto-xps139370 kernel: wlp2s0: authenticate with 0c:7c:28:b9:22:40
593501:Jul 20 17:52:57 ernesto-xps139370 kernel: wlp2s0: send auth to 0c:7c:28:b9:22:40 (try 1/3)
593502:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.2397] device (wlp2s0): supplicant interface state: scanning -> authenticating
593503:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.2398] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
593504:Jul 20 17:52:57 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Trying to associate with 0c:7c:28:b9:22:40 (SSID='27131' freq=5180 MHz)
593505:Jul 20 17:52:57 ernesto-xps139370 kernel: wlp2s0: authenticated
593506:Jul 20 17:52:57 ernesto-xps139370 kernel: wlp2s0: associate with 0c:7c:28:b9:22:40 (try 1/3)
593507:Jul 20 17:52:57 ernesto-xps139370 kernel: wlp2s0: RX AssocResp from 0c:7c:28:b9:22:40 (capab=0x11 status=0 aid=20)
593508:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.2471] device (wlp2s0): supplicant interface state: authenticating -> associating
593509:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.2472] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
593510:Jul 20 17:52:57 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: Associated with 0c:7c:28:b9:22:40
593511:Jul 20 17:52:57 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
593512:Jul 20 17:52:57 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
593513:Jul 20 17:52:57 ernesto-xps139370 kernel: wlp2s0: associated
593514-Jul 20 17:52:57 ernesto-xps139370 kernel: ath: EEPROM regdomain: 0x8348
593520-Jul 20 17:52:57 ernesto-xps139370 kernel: ath: regdomain 0x8348 dynamically updated by country element
593521:Jul 20 17:52:57 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: WPA: Key negotiation completed with 0c:7c:28:b9:22:40 [PTK=CCMP GTK=CCMP]
593522:Jul 20 17:52:57 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 0c:7c:28:b9:22:40 completed [id=0 id_str=]
593523:Jul 20 17:52:57 ernesto-xps139370 kernel: wlp2s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:7c:28:b9:22:40
593524:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3512] device (wlp2s0): supplicant interface state: associating -> completed
593525:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3523] device (wlp2s0): ip:dhcp4: restarting
593526:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3749] dhcp4 (wlp2s0): canceled DHCP transaction
593527:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3749] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
593528:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3749] dhcp4 (wlp2s0): state changed no lease
593529:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3750] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
593530:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3751] device (wlp2s0): ip:dhcp6: restarting
593531:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3751] dhcp6 (wlp2s0): canceled DHCP transaction
593532:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3751] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
593533:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3751] dhcp6 (wlp2s0): state changed no lease
593534:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3752] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
593535:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3752] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
593536:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3752] device (wlp2s0): ip:dhcp4: restarting
593537:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3753] dhcp4 (wlp2s0): canceled DHCP transaction
593538:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3753] dhcp4 (wlp2s0): state changed no lease
593539:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3753] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
593540:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3753] device (wlp2s0): ip:dhcp6: restarting
593541:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3754] dhcp6 (wlp2s0): canceled DHCP transaction
593542:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3754] dhcp6 (wlp2s0): state changed no lease
593543:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3754] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
593544:Jul 20 17:52:57 ernesto-xps139370 NetworkManager[502]: <info>  [1689893577.3974] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
593545-Jul 20 17:52:57 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
593548-Jul 20 17:52:57 ernesto-xps139370 systemd[1]: Started Network Manager Script Dispatcher Service.
593549:Jul 20 17:52:57 ernesto-xps139370 wpa_supplicant[567]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-70 noise=-93 txrate=234000
593550-Jul 20 17:52:57 ernesto-xps139370 kde-print-queue[9044]: "Canon_MF4700_Series" "Canon_MF4700_Series"
593589-Jul 20 17:52:59 ernesto-xps139370 kde-print-queue[9044]: 4 "Processing page 368..."
593590:Jul 20 17:52:59 ernesto-xps139370 NetworkManager[502]: <info>  [1689893579.3815] dhcp4 (wlp2s0): state changed new lease, address=192.168.1.137
593591-Jul 20 17:53:04 ernesto-xps139370 kde-print-queue[9044]: "Canon_MF4700_Series" "Canon_MF4700_Series"
598480-Jul 20 18:19:59 ernesto-xps139370 kwin_wayland[721]: This plugin does not support raise()
598481:Jul 20 18:20:03 ernesto-xps139370 NetworkManager[502]: <info>  [1689895203.8191] dhcp6 (wlp2s0): state changed new lease, address=2600:1700:1120:d470::22
598482-Jul 20 18:20:03 ernesto-xps139370 dbus-daemon[487]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=502 comm="/usr/bin/NetworkManager --no-daemon")
I have the same issue with Optimum right now and also on Nord VPN servers out of Phoenix. PHX has had real problems last week or two.
You can try disabling wifi MAC randomization. Create /etc/NetworkManager/conf.d/disable-random-mac.conf and paste this code inside:
[device]
    wifi.scan-rand-mac-address=no
Then restart. In my computer MAC randomization active means a lot of disconnections.
If this does not work, try disabling powersave:
It seems that disabling MAC randomization worked. Although the signal still shows “low” there are no connection issues and I’m getting some 150Mb/s with the router on the other end of the house, so it seems good.
Thanks!
Glad to have helped you. :+1: Remember you can use the iwconfig command to see the connection speed (Bit Rate) and the connection strenght (Link Quality).
