My computer, manjaro operating system, linux often lagging when watching videos, and the keyboard and mouse are paralyzed. Can someone help me…
Sorry for my english is not good…
It can be any of a multitude reasons. Search and you will find that you are not alone.
If you still needs help you must apply below actions to your system as we need you to be using a clean up-to-date Manjaro system - only packages from official repo allowed.
- Save a list of foreign packages (AUR akind)
pacman -Qmq > ~/foreign-pkgs.txt
- Remove all packages built from AUR.
sudo pacman -R $(pacman -Qmq)
- Reboot the system
reboot
- Update your mirrorlist
sudo pacman-mirrors -c all -p all
- Run a full system update
sudo pacman -Syyu
- Reboot
reboot
Thanks for your help. I have followed those steps already. Now what should I do next?
My system: 1. OS: Majaro 21.2.0;
2. CPU:Core i3 GEN 6;
3. RAM: 8GB
4. SSD: 120 GB
I install manjaro dual boot windows.
Thank for your support .
I have installed teamviewer in my computer. Could you help me for a second? Thank for your support . Sorry for my english is not good…
Have you removed all AUR packages - if any - you have installed?
Do you have any swap configured? What is the output of
swapon
sudo sysctl -a | grep 'vm.'
Copy the text from your terminal → paste it → select the text → click on </>
in the reply toolbar. This ensures nicely formatted and readable text.
uname -a
Not enough information. Anyway, aside from copying the output of shell commands from @linux-aarhus, also run inxi --admin --verbosity=7 --filter --width
to provide the full system information; I also suspect your computer is too old.
Yes, here are the results:
vm.admin_reserve_kbytes = 8192
vm.compact_unevictable_allowed = 1
vm.compaction_proactiveness = 20
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 1500
vm.dirty_ratio = 20
vm.dirty_writeback_centisecs = 1500
vm.dirtytime_expire_seconds = 43200
vm.extfrag_threshold = 500
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256 256 32 0 0
vm.max_map_count = 65530
vm.memory_failure_early_kill = 0
vm.memory_failure_recovery = 1
vm.min_free_kbytes = 67584
vm.min_slab_ratio = 5
vm.min_unmapped_ratio = 1
vm.mmap_min_addr = 65536
vm.mmap_rnd_bits = 28
vm.mmap_rnd_compat_bits = 8
vm.nr_hugepages = 0
vm.nr_hugepages_mempolicy = 0
vm.nr_overcommit_hugepages = 0
vm.numa_stat = 1
vm.numa_zonelist_order = Node
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_kbytes = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 3
vm.page_lock_unfairness = 5
vm.panic_on_oom = 0
vm.percpu_pagelist_high_fraction = 0
vm.stat_interval = 1
vm.swappiness = 60
vm.unprivileged_userfaultfd = 0
vm.user_reserve_kbytes = 131072
vm.vfs_cache_pressure = 100
vm.watermark_boost_factor = 15000
vm.watermark_scale_factor = 10
vm.zone_reclaim_mode = 0
And:
Linux viet-ms7a15 5.15.7-1-MANJARO #1 SMP PREEMPT Wed Dec 8 10:09:19 UTC 2021 x86_64 GNU/Linux
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4162225a-bbdb-4b0d-86f4-053e33667644 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: MSI model: H110M PRO-VD PLUS (MS-7A15) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.C0
date: 06/16/2018
RAM: total: 7.66 GiB used: 2.53 GiB (33.0%)
RAM Report:
Info: model: Intel Core i3-6100 bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 29608
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 530 vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DP-1 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: e000 bus-ID: 01:00.0
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 111.79 GiB used: 13.19 GiB (11.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SP550 size: 111.79 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 5A scheme: GPT
ID-1: / raw-size: 34.18 GiB size: 33.35 GiB (97.56%) used: 11.03 GiB (33.1%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 4162225a-bbdb-4b0d-86f4-053e33667644
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: C837-4795
ID-3: /home raw-size: 10.74 GiB size: 10.47 GiB (97.48%)
used: 2.16 GiB (20.6%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 08a1069f-390f-4aa2-af59-e9c795132f03
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 906B-ACC3
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 59.31 GiB fs: ntfs label: N/A
uuid: 9A9C70909C7068A1
ID-4: /dev/sda4 maj-min: 8:4 size: 593 MiB fs: ntfs label: N/A
uuid: DA68B6ED68B6C811
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-4:2 info: Canon LBP2900 type: Printer driver: usblp
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 04a9:2676 class-ID: 0701
serial: <filter>
Device-2: 1-7:3 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
power: 100mA chip-ID: 258a:0001 class-ID: 0300
Device-3: 1-8:4 info: Dell Dell MS116 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 413c:301a class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C pch: 41.0 C mobo: 27.8 C
Processes: 198 Uptime: 37m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1129 lib: 339 flatpak: 0
Shell: Bash v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
Or just:
Enclose YOUR_PASTE_INFORMATION with ```.
Anyway, yours is already formatted.
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.numa_stat = 1
vm.page-cluster = 3
vm.panic_on_oom = 0
vm.swappiness = 60
You could be running out of disk space
Please configure swap - Swap - Manjaro
Network latency - browser configuration - impossible to say - software rendering of videos in the browser will stress the CPU and create excessive heat - if heat cannot get away the system cripples.
It is well known that mitigations against cpu speculation vulnerabilities is a stomach punch crippling almost any system.
Removing mitagations can be done in /etc/default/grub
by adding the mitigations=off
to the config
CMDLINE_LINUX_DEFAULT="... mitigations=off ..."
Save and rebuild the config
sudo grub-mkconfig -o /boot/grub/grub.cfg
date: 06/16/2018
RAM Report:
Type: l1tf
uuid: C837-4795
uuid: 906B-ACC3
serial: <filter>
But something doesn’t make sense here, the RAM used is still about 33 prcnt (2.53 Gib out of 7.66 Gib).
date: 06/16/2018
The laptop is not old either.
And the system temperature is within normal.
I have installed teamviewer in my computer. Can you help me. Thank you.
Sorry for my english is not good.
It’s better not to let someone remote connect your system.
