Sleep not working properly, fan is always on
Hi!
When my laptop goes into sleep mode the cpu fan keeps spinning, it doesn’t matter the temperature or the time it is sleeping, the fan will always be on, which ends up consuming all the battery.
  Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=9939d4db-d261-4554-a1a4-a0b3a2a54891 rw quiet "acpi_osi=!Windows
  2012"
  cryptdevice=UUID=ac0713bc-ad56-40fe-9a4b-e85fe39c0e3c:luks-ac0713bc-ad56-40fe-9a4b-e85fe39c0e3c
  root=/dev/mapper/luks-ac0713bc-ad56-40fe-9a4b-e85fe39c0e3c
  udev.log_priority=3
  Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 8707 v: 37.19 serial: <filter> UEFI: AMI v: F.33
  date: 02/09/2021
  ID-1: BAT0 charge: 38.8 Wh (93.7%) condition: 41.4/41.4 Wh (100.0%)
  volts: 13.0 min: 11.3 model: Hewlett-Packard Primary type: Li-ion
  serial: N/A status: Charging cycles: 372
  RAM: total: 15.07 GiB used: 9.73 GiB (64.6%)
  Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
  type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600106 cache: L2: 4 MiB bogomips: 31958
  Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
  lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
  nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
  pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
  skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
  svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
  vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: disabled, RSB filling
  Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-2: Luxvisions Innotech Limited HP TrueVision HD Camera type: USB
  driver: uvcvideo bus-ID: 1-3:2 chip-ID: 30c9:0035 class-ID: fe01
  serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.42-1-MANJARO LLVM 12.0.0)
  v: 4.6 Mesa 21.1.2 direct render: Yes
  Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
  alternate: snd_pci_acp3x bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3
  class-ID: 0403
  Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.30 running: yes
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
  vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
  port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c822 class-ID: 0280
  IF-ID-1: br-1e34c06bfc5f state: up speed: 10000 Mbps duplex: unknown
  mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-2: br-ad4effcd7382 state: up speed: 10000 Mbps duplex: unknown
  mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: veth1173eb4 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-5: veth1653e0b state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-6: veth2ba393d state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-7: veth3dde236 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-8: veth6bc4c90 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-9: veth7b323b7 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-10: veth9b4987e state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-11: vethb9cde47 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-12: vethbee3d56 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-13: vethc0e9175 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-14: vethd1f1fb2 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-15: vethed5175f state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 1-4:3 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 953.87 GiB used: 125.36 GiB (13.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KBG40ZNV1T02 KIOXIA
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 rotation: SSD serial: <filter> rev: HP00AE00 temp: 42.9 C
  scheme: GPT
  ID-1: / raw-size: 693.59 GiB size: 681.63 GiB (98.28%)
  used: 125.3 GiB (18.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-ac0713bc-ad56-40fe-9a4b-e85fe39c0e3c label: N/A
  uuid: 9939d4db-d261-4554-a1a4-a0b3a2a54891
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 62.6 MiB (24.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SYSTEM uuid: FA7A-7DC4
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
  ID-1: swap-1 type: file size: 8 GiB used: 256 KiB (0.0%) priority: -2
  file: /swapfile
  ID-2: swap-2 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -3
  file: /swapfile2
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 259.48 GiB fs: ntfs label: N/A
  uuid: N/A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 533 MiB fs: ntfs
  label: Windows RE tools uuid: 86361A57361A4897
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 693.59 GiB
  fs: <superuser required> label: N/A
  uuid: ac0713bc-ad56-40fe-9a4b-e85fe39c0e3c
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 1-3:2 info: Luxvisions Innotech Limited HP TrueVision HD Camera
  type: Video driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s
  power: 500mA chip-ID: 30c9:0035 class-ID: fe01 serial: <filter>
  Device-2: 1-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
  interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:b00c
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 76.5 C mobo: 73.0 C gpu: amdgpu temp: 51.0 C
  Processes: 422 Uptime: 2h 34m wakeups: 7735 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: 1271 pacman: 1267 lib: 340
  snap: 4 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.04
dmesg --level emerg,alert,crit,err,warn
[    1.119428] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[    1.259234] pci 0000:00:00.2: can't derive routing for PCI INT A
[    1.259234] pci 0000:00:00.2: PCI INT A: not connected
[    1.260390]  PPR X2APIC NX GT IA GA PC GA_vAPIC
[    1.272881] efifb: Ignoring BGRT: unexpected or invalid BMP data
[    1.346261] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P000 (20200925/dspkginit-438)
[    1.346271] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P001 (20200925/dspkginit-438)
[    1.346276] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P002 (20200925/dspkginit-438)
[    1.346280] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P003 (20200925/dspkginit-438)
[    1.346284] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P004 (20200925/dspkginit-438)
[    1.346288] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P005 (20200925/dspkginit-438)
[    1.346291] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P006 (20200925/dspkginit-438)
[    1.346295] ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P007 (20200925/dspkginit-438)
[    1.346309] ACPI: Invalid passive threshold
[    1.362462] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.691491] atkbd serio0: Failed to deactivate keyboard on isa0060/serio0
[    1.701565] clocksource: timekeeping watchdog on CPU2: Marking clocksource 'tsc-early' as unstable because the skew is too large:
[    1.701570] clocksource:                       'hpet' wd_now: 11e9a44 wd_last: e4859a mask: ffffffff
[    1.701572] clocksource:                       'tsc-early' cs_now: 12670aeec4 cs_last: 12261de13c mask: ffffffffffffffff
[    1.701602] TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
[    1.761619] atkbd serio0: Spurious ACK on isa0060/serio0. Some program might be trying to access hardware directly.
[   10.102452] i2c_hid i2c-ELAN071A:00: supply vdd not found, using dummy regulator
[   10.102485] i2c_hid i2c-ELAN071A:00: supply vddl not found, using dummy regulator
[   11.158601] acp_pdm_mach acp_pdm_mach.0: snd_soc_register_card(acp) failed: -517
[   11.158776] acp_pdm_mach acp_pdm_mach.0: snd_soc_register_card(acp) failed: -517
[   15.519702] kauditd_printk_skb: 301 callbacks suppressed
[ 3428.094987] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.P000.PPCV], AE_NOT_FOUND (20200925/psargs-330)
[ 3428.094995] ACPI Error: Aborting method \_SB.CPUS due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
[ 3428.095001] ACPI Error: Aborting method \_SB.PCI0.SBRG.EC0._Q20 due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
[ 9460.337034] kauditd_printk_skb: 10 callbacks suppressed
journalctl -k output after systemctl suspend
jul 03 16:02:02 Elektrik kernel: PM: suspend exit
jul 03 16:02:02 Elektrik kernel: Bluetooth: hci0: RTL: fw version 0x099a7253
jul 03 16:02:02 Elektrik kernel: audit: type=1130 audit(1625320922.446:366): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="sys>
jul 03 16:02:02 Elektrik kernel: audit: type=1131 audit(1625320922.446:367): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="sys>
jul 03 16:02:06 Elektrik kernel: audit: type=1100 audit(1625320926.583:368): pid=27688 uid=1000 auid=1000 ses=1 msg='op=PAM:unix_chkpwd acct="javi" exe="/u>
jul 03 16:02:06 Elektrik kernel: wlo1: authenticate with 10:c2:5a:68:f5:67
jul 03 16:02:06 Elektrik kernel: wlo1: send auth to 10:c2:5a:68:f5:67 (try 1/3)
jul 03 16:02:06 Elektrik kernel: audit: type=1131 audit(1625320926.943:369): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher>
jul 03 16:02:06 Elektrik kernel: audit: type=1131 audit(1625320926.953:370): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="syst>
jul 03 16:02:07 Elektrik kernel: wlo1: send auth to 10:c2:5a:68:f5:67 (try 2/3)
jul 03 16:02:07 Elektrik kernel: wlo1: authenticated
jul 03 16:02:07 Elektrik kernel: wlo1: associate with 10:c2:5a:68:f5:67 (try 1/3)
jul 03 16:02:07 Elektrik kernel: wlo1: RX AssocResp from 10:c2:5a:68:f5:67 (capab=0x1411 status=0 aid=1)
jul 03 16:02:07 Elektrik kernel: rtw_8822ce 0000:01:00.0: sta 10:c2:5a:68:f5:67 joined with macid 0
jul 03 16:02:07 Elektrik kernel: wlo1: associated
jul 03 16:02:07 Elektrik kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
jul 03 16:02:07 Elektrik kernel: wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by 10:c2:5a:68:f5:67
jul 03 16:02:10 Elektrik kernel: audit: type=1130 audit(1625320930.146:371): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher>
Let me know which logs could be useful.
I hadn’t found any similar post related to this. Thanks!
Welcome here, @fardenz,
have you tried a newer kernel, especially 5.12? Make sure your system is fully updated.
Hi @Wollie
Thanks! I am very grateful for your help :slight_smile:
I am running right now on 5.13 (Experimental version) and it is still happening. Should I try with 5.12 as well?
Yes, try 5.12 a well.
Hello,
Look at tlp and check the behaviour after closing lid in settings. I had similar problem few years ago in other distribution, but finally I found resolve of the issue in lid behaviour.
Hello fardenz,
welcome to the club! Right now, sleep with many AMD chips is broken.
It used to work, although sometimes a bit of fiddling around was necessary, but for several months now, it isn’t. As far as I can tell by trying to get “modern standby” to work, they have broken normal standby for a lot of us post-5.11.
You can try 5.10, that still works for me. Otherwise you can only hope and keep on waiting.
Rumor has it that 5.14 might work again, but I’m not holding my breath anymore.
What makes me a bit angry is that instead of getting a working new solution ready first and deploying it afterwards, they made a huge mess and broke a (mostly) working system.
Edit: However, I just noticed that one of the latest updates in testing has brought back some functionality. So at least there’s finally some progress!
It seems my laptop (with Ryzen 4600U) now enters sleep again and manages to wakes up most of the time (with 5.13.2 - not sure if recent firmware or other updates play a role, too) - sometimes it will lock up completely and require a hard reboot, though.
But it’s an improvement, finally. From no proper sleep and locking up everytime a few months ago, to no proper sleep and locking up every other time until recently to apparently proper sleep again and locking up about 1 out of 10 (estimated).
