Thanks for the update, it went smoothly, and I didn’t notice any major issues. That’s why I selected “no issue.”
Afterwards, I noticed that sleep mode is gone. It no longer goes into sleep mode when I close the lid.
The sleep mode option is also completely missing from the power options in the system settings. Before the stable update from May 2nd, 2026, closing the lid worked without any problems.
KDE Plasma Version: 6.6.4
KDE Frameworks Version: 6.25.0
Qt Version: 6.11.0
Kernel Version: 7.0.3-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 × Intel® Core™ i7-9750H CPU @ 2.60GHz
Memory: 16 GiB of RAM (15.4 GiB usable)
Graphics Processor 1: Intel® UHD Graphics 630
Graphics Processor 2: NVIDIA GeForce GTX 1650
I can provide a screenshot of the power settings and system settings.
Also, screenshots of grub, fstab, mkinitcpio, and anything else that might be needed.
Kernel: 7.0.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.0-x86_64
root=UUID=da5b5cc5-xxxx-<filter>-xxxx rw rootflags=subvol=@
resume=UUID=5d84e5ab-xxxx-<filter>-xxxx udev.log_priority=3
Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
Type: Laptop System: MEDION product: P15609 v: N/A
Mobo: MEDION model: NH55RAQM1 serial: <superuser required>
part-nu: ML-210008 30028146 uuid: <superuser required> Firmware: UEFI
vendor: INSYDE v: 1.07.08RME8 date: 03/02/2020
ID-1: BAT0 charge: 47.1 Wh (100%) condition: 47.1/48 Wh (98%) volts: 16.51
min: 14.4 model: Notebook BAT type: Li-ion serial: <filter> charging:
status: full cycles: N/A
System RAM: total: 16 GiB available: 15.45 GiB used: 7.07 GiB (45.8%)
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2667 MT/s volts: curr: 1 min: 1.35 max: 2 width (bits): data: 64
total: 64 manufacturer: Samsung part-no: M471A1K43CB1-CTD serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: MEDION AG
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: CLEVO/KAPOK driver: nvidia v: 595.71.05
alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as
of 2025-11; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none empty: DP-1 bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 04f2:b685
class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x05e5 built: 2018 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.369
green: x: 0.349 y: 0.557 blue: x: 0.153 y: 0.110 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e9b memory: 15.08 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.341 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 26.0.6-arch1.1
device-ID: 8086:3e9b surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 595.71.05
device-ID: 10de:1f91 surfaces: N/A
Local Storage: total: 1.38 TiB used: 1005.11 GiB (71.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Phison
model: E12-512G-SSD-B16-BB1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: ECFM22.4 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A scheme: GPT
ID-1: / raw-size: 59.57 GiB size: 59.57 GiB (100.00%)
used: 39.31 GiB (66.0%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
label: NVMe-NB uuid: da5b5cc5-xxxx-<filter>-xxxx
used: 26 MiB (27.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 9CC5-B476
ID-3: /home raw-size: 341.56 GiB size: 335.14 GiB (98.12%)
used: 84.96 GiB (25.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: home uuid: b96131d3-xxxx-<filter>-xxxx
ID-4: /run/media/tony/Boot raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
used: 39.4 GiB (67.3%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: Boot uuid: 3EFECxxxx-<filter>-xxxx
ID-5: /run/media/tony/Data raw-size: 901.51 GiB size: 901.51 GiB (100.00%)
used: 819.14 GiB (90.9%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: Data
uuid: 622463xxxx-<filter>-xxxx
ID-6: /run/media/tony/Recover raw-size: 30 GiB size: 30 GiB (100.00%)
used: 22.21 GiB (74.0%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Recover
uuid: 6AB86546xxxx-<filter>-xxxx1BD
ID-7: /var/cache raw-size: 59.57 GiB size: 59.57 GiB (100.00%)
ID-8: /var/log raw-size: 59.57 GiB size: 59.57 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.6 GiB used: 56.9 MiB (0.3%)
priority: -1 dev: /dev/nvme0n1p6 maj-min: 259:6 label: swap
uuid: 5d84e5ab-xxxx-<filter>-xxxx
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: ext4 label: N/A
uuid: 62dbe56e-4011-49c6-876d-10d0010c3f21
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 510 MiB fs: ntfs label: N/A
uuid: 9A8265xxxx-<filter>-xxxx69
Device-1: 1-8:2 info: Chicony USB2.0 Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b685 class-ID: 0e02
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 57.0 C pch: 72.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1459 libs: 411 tools: pamac
1: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
2: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
4: https://mirror.23m.com/manjaro/stable/$repo/$arch
5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
6: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
7: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
CPU top: 5 of 389
1: cpu: 11.4% command: brave pid: 20405 mem: 297.9 MiB (1.8%)
2: cpu: 6.3% command: konsole pid: 20783 mem: 345.1 MiB (2.1%)
3: cpu: 4.9% command: chromium pid: 19899 mem: 237.3 MiB (1.5%)
4: cpu: 3.9% command: chromium pid: 17381 mem: 638.8 MiB (4.0%)
5: cpu: 3.7% command: kwin_wayland pid: 787 mem: 224.3 MiB (1.4%)
Memory top: 5 of 389
1: mem: 965.0 MiB (6.1%) command: brave pid: 17768 cpu: 2.7%
2: mem: 638.8 MiB (4.0%) command: chromium pid: 17381 cpu: 3.9%
3: mem: 447.6 MiB (2.8%) command: brave pid: 17822 cpu: 1.4%
4: mem: 441.4 MiB (2.7%) command: plasmashell pid: 962 cpu: 2.1%
5: mem: 390.8 MiB (2.4%) command: chromium pid: 17431 cpu: 2.6%
Processes: 389 Power: uptime: 1h 47m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.3.9
running-in: konsole inxi: 3.3.40
Thanks and regards,
Tony
