Hallo zusammen,
ich habe hier einen alten USB Filmscanner von Minolta, der laut der Sane Website gut unterstützt werden sollte: SANE: Supported Devices
sane-find-scanner findet ihn auch:
~ sane-find-scanner
sane-find-scanner will now attempt to detect your scanner. If the
result is different from what you expected, first make sure your
scanner is powered up and properly connected to your computer.
No SCSI scanners found. If you expected something different, make sure that
you have loaded a kernel SCSI driver for your SCSI adapter.
Also you need support for SCSI Generic (sg) in your operating system.
If using Linux, try “modprobe sg”.
could not open USB device 0x1058/0x2621 at 006:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0003 at 006:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 005:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0003 at 004:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 003:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0003 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x248a/0x8367 at 001:002: Access denied (insufficient permissions)
found USB scanner (vendor=0x0638, product=0x026a) at libusb:001:004
could not open USB device 0x0bda/0xb00e at 001:003: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)Your USB scanner was (probably) detected. It may or may not be supported by
SANE. Try scanimage -L and read the backend’s manpage.
Not checking for parallel port scanners.
Most Scanners connected to the parallel port or other proprietary ports
can’t be detected by this program.
You may want to run this program as root to find all devices. Once you
found the scanner devices, be sure to adjust access permissions as
XSane findet ihn leider nicht. Muss ich da noch etwas installieren oder einstellen? Ich hoffe ihr könnt mir helfen.
Danke und Gruß, Andreas
