Sleep and Hibernation failures
Logs are lost then…
Yup: EXT4 is a transaction-based system: the entire transaction was rolled back…
Try:
  • Reboot and log in
  • Insert a FAT-32 formatted USB stick
  • mount it in /media/USB
  • Open a terminal and run:
    watch --interval=1 'journalctl --system | tail --lines=25 >>/media/USB/JimmysLog.txt;sync'
  • Open another another terminal and run:
    systemctl suspend
  • still try to REISUB when it comes back, but use 6 seconds in-between keystrokes.
  • provide the sanitised contents of JimmysLog.txt (I.E. remove duplicates) regardless whether or not REISUB worked.
:thinking:
Sorry for the late reply again. Been so busy, and ran out of energy before I can attend to the issue.
Took to your advice as mentioned above. Got the logging applied, and suspended the system. Upon relaunch, the system powered off immedatly, and I needed to power on the machine again, and the system went through a normal power on boot, rather than resuming.
Below is the log output below…
Oct 08 21:25:28 jimmyson-ms7a40 udisksd[2525]: Mounted /dev/sda at /run/media/jimmyson/STORE N GO on behalf of uid 1000
Oct 08 21:26:26 jimmyson-ms7a40 dbus-daemon[476]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.94' (uid=0 pid=4673 comm="sudo watch --interval=1 journalctl --system | tail")
Oct 08 21:26:26 jimmyson-ms7a40 dbus-daemon[476]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 08 21:26:26 jimmyson-ms7a40 audit[4673]: USER_AUTH pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=? acct="jimmyson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=failed'
Oct 08 21:26:26 jimmyson-ms7a40 kernel: audit: type=1100 audit(1633688786.740:110): pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=? acct="jimmyson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=failed'
Oct 08 21:27:37 jimmyson-ms7a40 audit[4673]: USER_AUTH pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="jimmyson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:37 jimmyson-ms7a40 audit[4673]: USER_ACCT pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="jimmyson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:37 jimmyson-ms7a40 audit[4673]: CRED_REFR pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:37 jimmyson-ms7a40 kernel: audit: type=1100 audit(1633688857.060:111): pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="jimmyson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:37 jimmyson-ms7a40 kernel: audit: type=1101 audit(1633688857.060:112): pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="jimmyson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:37 jimmyson-ms7a40 kernel: audit: type=1110 audit(1633688857.060:113): pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:37 jimmyson-ms7a40 audit[4673]: USER_START pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:37 jimmyson-ms7a40 kernel: audit: type=1105 audit(1633688857.063:114): pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:43 jimmyson-ms7a40 audit[4673]: USER_END pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:43 jimmyson-ms7a40 audit[4673]: CRED_DISP pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:43 jimmyson-ms7a40 kernel: audit: type=1106 audit(1633688863.606:115): pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:43 jimmyson-ms7a40 kernel: audit: type=1104 audit(1633688863.606:116): pid=4673 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:50 jimmyson-ms7a40 dbus-daemon[476]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.95' (uid=0 pid=4747 comm="sudo watch --interval=1 journalctl --system | tail")
Oct 08 21:27:50 jimmyson-ms7a40 dbus-daemon[476]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 08 21:27:50 jimmyson-ms7a40 audit[4747]: USER_ACCT pid=4747 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="jimmyson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:50 jimmyson-ms7a40 audit[4747]: CRED_REFR pid=4747 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:50 jimmyson-ms7a40 kernel: audit: type=1101 audit(1633688870.383:117): pid=4747 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="jimmyson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:50 jimmyson-ms7a40 kernel: audit: type=1110 audit(1633688870.383:118): pid=4747 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:50 jimmyson-ms7a40 audit[4747]: USER_START pid=4747 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:27:50 jimmyson-ms7a40 kernel: audit: type=1105 audit(1633688870.386:119): pid=4747 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Oct 08 21:29:57 jimmyson-ms7a40 NetworkManager[477]: <info>  [1633688997.6829] device (wlp28s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 08 21:29:57 jimmyson-ms7a40 ModemManager[526]: <info>  [sleep-monitor] system is about to suspend
Oct 08 21:29:57 jimmyson-ms7a40 NetworkManager[477]: <info>  [1633688997.6837] device (wlp28s0): set-hw-addr: reset MAC address to D4:3B:04:EF:59:20 (unmanage)
Oct 08 21:29:57 jimmyson-ms7a40 NetworkManager[477]: <info>  [1633688997.6845] manager: NetworkManager state is now ASLEEP
Oct 08 21:29:57 jimmyson-ms7a40 polkitd[478]: Unregistered Authentication Agent for unix-process:5035:195458 (system bus name :1.97, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_AU.utf8) (disconnected from bus)
Oct 08 21:29:57 jimmyson-ms7a40 NetworkManager[477]: <info>  [1633688997.6850] device (enp27s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Oct 08 21:29:57 jimmyson-ms7a40 dbus-daemon[476]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=477 comm="/usr/bin/NetworkManager --no-daemon ")
Oct 08 21:29:57 jimmyson-ms7a40 systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 08 21:29:57 jimmyson-ms7a40 dbus-daemon[476]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 08 21:29:57 jimmyson-ms7a40 systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 08 21:29:57 jimmyson-ms7a40 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 21:29:57 jimmyson-ms7a40 NetworkManager[477]: <info>  [1633688997.7056] device (enp27s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Oct 08 21:29:57 jimmyson-ms7a40 kernel: audit: type=1130 audit(1633688997.700:120): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 08 21:29:57 jimmyson-ms7a40 avahi-daemon[474]: Withdrawing address record for fe80::c4f6:5e69:f8bb:5488 on enp27s0.
Oct 08 21:29:57 jimmyson-ms7a40 avahi-daemon[474]: Leaving mDNS multicast group on interface enp27s0.IPv6 with address fe80::c4f6:5e69:f8bb:5488.
Oct 08 21:29:57 jimmyson-ms7a40 avahi-daemon[474]: Interface enp27s0.IPv6 no longer relevant for mDNS.
Oct 08 21:29:57 jimmyson-ms7a40 NetworkManager[477]: <info>  [1633688997.7264] dhcp4 (enp27s0): canceled DHCP transaction
Oct 08 21:29:57 jimmyson-ms7a40 NetworkManager[477]: <info>  [1633688997.7264] dhcp4 (enp27s0): state changed bound -> terminated
Oct 08 21:29:57 jimmyson-ms7a40 avahi-daemon[474]: Withdrawing address record for 192.168.1.24 on enp27s0.
Oct 08 21:29:57 jimmyson-ms7a40 avahi-daemon[474]: Leaving mDNS multicast group on interface enp27s0.IPv4 with address 192.168.1.24.
Oct 08 21:29:57 jimmyson-ms7a40 avahi-daemon[474]: Interface enp27s0.IPv4 no longer relevant for mDNS.
Oct 08 21:29:57 jimmyson-ms7a40 NetworkManager[477]: <info>  [1633688997.7338] device (enp27s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 08 21:29:57 jimmyson-ms7a40 kernel: r8169 0000:1b:00.0 enp27s0: Link is Down
Oct 08 21:29:57 jimmyson-ms7a40 systemd[1]: Reached target Sleep.
Oct 08 21:29:57 jimmyson-ms7a40 systemd[1]: Starting System Suspend...
That looks like a firmware bug. Look if there is an UEFI Firmware update (aka “BIOS update”) from your hardware manufacturer.
:thinking:
Seems there are several since I purchased the board. Mostly AGESA and Ryzen 3000 CPU supports. I’ll see what I can do here.
Seems I also experienced this issue twice again today. Setting the Power Management Options to Hibernate, and leave the system on Idle for 15 minutes, and returning yielded the machine inoperable when Powered Back on, black screen receiving no signal. I managed to check network connectivity, and yielded Ping echos from other devices on the network. Seems the Kernel is booting. SSH was out of action.
Plugged in my USB for SystemCtl monitoring, and I am revealed that LightDM is having issues upon awaking. I do also have the Display set to blank after 10 minutes as part of the Idle cycle, and I am of the belief that this causes the display to not send a signal upon it waking up.
Oct 12 21:55:12 jimmyson-ms7a40 rtkit-daemon[1472]: Supervising 7 threads of 2 processes of 1 users.
Oct 12 21:56:26 jimmyson-ms7a40 rtkit-daemon[1472]: Supervising 7 threads of 2 processes of 1 users.
Oct 12 21:56:26 jimmyson-ms7a40 rtkit-daemon[1472]: Successfully made thread 3583 of process 2167 owned by '1000' RT at priority 10.
Oct 12 21:56:26 jimmyson-ms7a40 rtkit-daemon[1472]: Supervising 8 threads of 3 processes of 1 users.
Oct 12 22:01:01 jimmyson-ms7a40 CROND[3670]: (root) CMD (run-parts /etc/cron.hourly)
Oct 12 22:01:01 jimmyson-ms7a40 CROND[3669]: (root) CMDEND (run-parts /etc/cron.hourly)
Oct 12 22:17:19 jimmyson-ms7a40 udisksd[2381]: Mounted /dev/sda at /run/media/jimmyson/STORE N GO on behalf of uid 1000
Oct 12 22:17:19 jimmyson-ms7a40 kernel: FAT-fs (sda): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Oct 12 22:18:16 jimmyson-ms7a40 rtkit-daemon[1472]: Supervising 8 threads of 3 processes of 1 users.
Oct 12 22:18:20 jimmyson-ms7a40 rtkit-daemon[1472]: Supervising 8 threads of 3 processes of 1 users.
Oct 12 22:18:20 jimmyson-ms7a40 rtkit-daemon[1472]: Successfully made thread 4262 of process 4208 owned by '1000' RT at priority 10.
Oct 12 22:18:20 jimmyson-ms7a40 rtkit-daemon[1472]: Supervising 9 threads of 4 processes of 1 users.
Oct 12 22:46:00 jimmyson-ms7a40 kernel: usb 3-4.4: device not accepting address 13, error -71
Oct 12 22:46:00 jimmyson-ms7a40 kernel: OOM killer enabled.
Oct 12 22:46:00 jimmyson-ms7a40 kernel: Restarting tasks ... done.
Oct 12 22:46:00 jimmyson-ms7a40 kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Oct 12 22:46:00 jimmyson-ms7a40 kernel: PM: suspend exit
Oct 12 22:46:00 jimmyson-ms7a40 kernel: usb 3-4.4: USB disconnect, device number 13
Oct 12 22:46:00 jimmyson-ms7a40 bluetoothd[810]: Endpoint unregistered: sender=:1.52 path=/MediaEndpoint/A2DPSink/sbc
Oct 12 22:46:00 jimmyson-ms7a40 systemd-sleep[6249]: System returned from sleep state.
Oct 12 22:46:00 jimmyson-ms7a40 bluetoothd[810]: Endpoint unregistered: sender=:1.52 path=/MediaEndpoint/A2DPSource/sbc
Oct 12 22:46:00 jimmyson-ms7a40 systemd[1]: Starting Load/Save RF Kill Switch Status...
Oct 12 22:46:00 jimmyson-ms7a40 bluetoothd[810]: Endpoint unregistered: sender=:1.52 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Oct 12 22:46:00 jimmyson-ms7a40 bluetoothd[810]: Endpoint unregistered: sender=:1.52 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Oct 12 22:46:00 jimmyson-ms7a40 bluetoothd[810]: Endpoint unregistered: sender=:1.52 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Oct 12 22:46:00 jimmyson-ms7a40 bluetoothd[810]: Endpoint unregistered: sender=:1.52 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Oct 12 22:46:00 jimmyson-ms7a40 bluetoothd[810]: Endpoint unregistered: sender=:1.52 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Oct 12 22:46:00 jimmyson-ms7a40 bluetoothd[810]: Endpoint unregistered: sender=:1.52 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Oct 12 22:46:00 jimmyson-ms7a40 kernel: Bluetooth: hci0: read Intel version: 370810225019140f00
Oct 12 22:46:00 jimmyson-ms7a40 kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
Oct 12 22:46:00 jimmyson-ms7a40 upowerd[1653]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-8
Oct 12 22:46:00 jimmyson-ms7a40 systemd[1]: Stopped target Bluetooth Support.
Oct 12 22:46:00 jimmyson-ms7a40 systemd[1]: Started Load/Save RF Kill Switch Status.
Oct 12 22:46:00 jimmyson-ms7a40 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 12 22:46:00 jimmyson-ms7a40 kernel: audit: type=1130 audit(1634039160.130:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 12 22:46:00 jimmyson-ms7a40 systemd[1]: Reached target Bluetooth Support.
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6884]: Please consult the The X.Org Foundation support
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6884]:          at http://wiki.x.org
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6884]:  for help.
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6884]: (EE)
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[647]: Failed to open log file /var/log/lightdm/x-1.log: Read-only file system
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6885]: (EE)
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6885]: Fatal server error:
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6885]: (EE) Cannot move old log file "/var/log/Xorg.1.log" to "/var/log/Xorg.1.log.old"
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6885]: Please consult the The X.Org Foundation support
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6885]:          at http://wiki.x.org
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6885]:  for help.
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6886]: (EE)
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6886]: Fatal server error:
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6886]: (EE) Cannot move old log file "/var/log/Xorg.1.log" to "/var/log/Xorg.1.log.old"
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6886]: Please consult the The X.Org Foundation support
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6886]:          at http://wiki.x.org
Oct 12 22:46:21 jimmyson-ms7a40 lightdm[6886]:  for help.
After being busy with work, I managed to get some time to update my system’s BIOS.
I can gleefully report that a time Suspend operation managed to reawaken itself without problems.
Network services are still running, X11 managed to accept the awakened session, and the logging resumed upon the awaken state.
Seems that it was a BIOS update that needed to be done. I also managed to set my boot type to UEFI, as the updated BIOS had it set to Legacy. I think that might’ve been altered from UEFI upon flashing the new BIOS. Thanks for your patience.
Oct 21 19:36:04 jimmyson-ms7a40 kernel: usb 3-2: Manufacturer: Verbatim
Oct 21 19:36:04 jimmyson-ms7a40 kernel: usb 3-2: SerialNumber: CA006AA89FE8DE43
Oct 21 19:36:04 jimmyson-ms7a40 kernel: usb-storage 3-2:1.0: USB Mass Storage device detected
Oct 21 19:36:04 jimmyson-ms7a40 kernel: scsi host10: usb-storage 3-2:1.0
Oct 21 19:36:04 jimmyson-ms7a40 mtp-probe[9923]: checking bus 3, device 13: "/sys/devices/pci0000:00/0000:00:07.1/0000:2a:00.3/usb3/3-2"
Oct 21 19:36:04 jimmyson-ms7a40 mtp-probe[9923]: bus: 3, device: 13 was not an MTP device
Oct 21 19:36:05 jimmyson-ms7a40 mtp-probe[9949]: checking bus 3, device 13: "/sys/devices/pci0000:00/0000:00:07.1/0000:2a:00.3/usb3/3-2"
Oct 21 19:36:05 jimmyson-ms7a40 mtp-probe[9949]: bus: 3, device: 13 was not an MTP device
Oct 21 19:36:05 jimmyson-ms7a40 kernel: scsi 10:0:0:0: Direct-Access     Verbatim STORE N GO       5.00 PQ: 0 ANSI: 6
Oct 21 19:36:09 jimmyson-ms7a40 kernel: sd 10:0:0:0: [sdb] 15117800 512-byte logical blocks: (7.74 GB/7.21 GiB)
Oct 21 19:36:09 jimmyson-ms7a40 kernel: sd 10:0:0:0: [sdb] Write Protect is off
Oct 21 19:36:09 jimmyson-ms7a40 kernel: sd 10:0:0:0: [sdb] Mode Sense: 23 00 00 00
Oct 21 19:36:09 jimmyson-ms7a40 kernel: sd 10:0:0:0: [sdb] No Caching mode page found
Oct 21 19:36:09 jimmyson-ms7a40 kernel: sd 10:0:0:0: [sdb] Assuming drive cache: write through
Oct 21 19:36:09 jimmyson-ms7a40 kernel:  sdb:
Oct 21 19:36:09 jimmyson-ms7a40 kernel: sd 10:0:0:0: [sdb] Attached SCSI removable disk
Oct 21 19:36:52 jimmyson-ms7a40 kernel: FAT-fs (sdb): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Oct 21 19:36:52 jimmyson-ms7a40 udisksd[3213]: Mounted /dev/sdb at /run/media/jimmyson/STORE N GO on behalf of uid 1000
Oct 21 19:37:28 jimmyson-ms7a40 kernel: usb 3-3.3: USB disconnect, device number 6
Oct 21 19:37:28 jimmyson-ms7a40 kernel: usb 3-3.3.1: USB disconnect, device number 9
Oct 21 19:37:28 jimmyson-ms7a40 kernel: usb 3-3.3.1.1: USB disconnect, device number 11
Oct 21 19:37:28 jimmyson-ms7a40 kernel: usb 3-3.3.2: USB disconnect, device number 10
Oct 21 19:47:01 jimmyson-ms7a40 anacron[2887]: Job `cron.daily' started
Oct 21 19:47:01 jimmyson-ms7a40 anacron[2887]: Job `cron.daily' terminated
Oct 21 19:47:01 jimmyson-ms7a40 anacron[2887]: Normal exit (1 job run)
Oct 21 20:14:11 jimmyson-ms7a40 kernel: usb usb2: root hub lost power or was reset
Oct 21 20:14:11 jimmyson-ms7a40 kernel: [drm] PCIE gen 3 link speeds already enabled
Oct 21 20:14:11 jimmyson-ms7a40 kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400000000).
Oct 21 20:14:11 jimmyson-ms7a40 kernel: amdgpu 0000:29:00.0: amdgpu: SRBM_SOFT_RESET=0x00100040
Oct 21 20:14:11 jimmyson-ms7a40 kernel: nvme nvme0: 16/0/0 default/read/poll queues
Oct 21 20:14:11 jimmyson-ms7a40 kernel: [drm] UVD initialized successfully.
Oct 21 20:14:11 jimmyson-ms7a40 kernel: usb 4-3: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
Oct 21 20:14:11 jimmyson-ms7a40 kernel: [drm] VCE initialized successfully.
Oct 21 20:14:11 jimmyson-ms7a40 kernel: SW scheduler is used
Oct 21 20:14:11 jimmyson-ms7a40 kernel: ata5: SATA link down (SStatus 0 SControl 330)
Oct 21 20:14:11 jimmyson-ms7a40 kernel: ata2: SATA link down (SStatus 0 SControl 330)
Oct 21 20:14:11 jimmyson-ms7a40 kernel: ata6: SATA link down (SStatus 0 SControl 330)
Oct 21 20:14:11 jimmyson-ms7a40 kernel: ata9: SATA link down (SStatus 0 SControl 300)
Oct 21 20:14:11 jimmyson-ms7a40 kernel: ata1: SATA link down (SStatus 0 SControl 330)
Oct 21 20:14:11 jimmyson-ms7a40 kernel: usb 1-8: reset full-speed USB device number 2 using xhci_hcd
Oct 21 20:14:11 jimmyson-ms7a40 kernel: hub 4-3:1.0: hub_ext_port_status failed (err = -71)
Oct 21 20:14:11 jimmyson-ms7a40 kernel: OOM killer enabled.
Oct 21 20:14:11 jimmyson-ms7a40 kernel: Restarting tasks ... done.
Oct 21 20:14:11 jimmyson-ms7a40 kernel: PM: suspend exit
Oct 21 20:14:11 jimmyson-ms7a40 bluetoothd[844]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc
Oct 21 20:14:11 jimmyson-ms7a40 systemd-sleep[11470]: System returned from sleep state.
Oct 21 20:14:11 jimmyson-ms7a40 bluetoothd[844]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc
Oct 21 20:14:11 jimmyson-ms7a40 systemd[1]: Starting Load/Save RF Kill Switch Status...
Oct 21 20:14:11 jimmyson-ms7a40 bluetoothd[844]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Oct 21 20:14:11 jimmyson-ms7a40 bluetoothd[844]: Endpoint unregistered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Oct 21 20:14:14 jimmyson-ms7a40 systemd[1]: Started User Manager for UID 971.
Oct 21 20:14:14 jimmyson-ms7a40 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 20:14:14 jimmyson-ms7a40 kernel: audit: type=1130 audit(1634807654.063:110): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 20:14:14 jimmyson-ms7a40 systemd[11876]: Starting Update XDG user dir configuration...
Oct 21 20:14:14 jimmyson-ms7a40 systemd[1]: Started Session c2 of User lightdm.
Oct 21 20:14:14 jimmyson-ms7a40 systemd[11876]: Finished Update XDG user dir configuration.
Oct 21 20:14:14 jimmyson-ms7a40 systemd[11876]: Reached target Main User Target.
Oct 21 20:14:14 jimmyson-ms7a40 systemd[11876]: Startup finished in 197ms.
Oct 21 20:14:14 jimmyson-ms7a40 audit[11872]: USER_START pid=11872 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 21 20:14:14 jimmyson-ms7a40 kernel: audit: type=1105 audit(1634807654.073:111): pid=11872 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 21 20:14:14 jimmyson-ms7a40 systemd[11876]: Started D-Bus User Message Bus.
Oct 21 20:14:14 jimmyson-ms7a40 dbus-daemon[11901]: [session uid=971 pid=11901] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=971 pid=11884 comm="/usr/bin/lightdm-gtk-greeter ")
Oct 21 20:14:14 jimmyson-ms7a40 systemd[11876]: Starting Accessibility services bus...
Oct 21 20:14:14 jimmyson-ms7a40 dbus-daemon[11901]: [session uid=971 pid=11901] Successfully activated service 'org.a11y.Bus'
Oct 21 20:14:14 jimmyson-ms7a40 systemd[11876]: Started Accessibility services bus.
Oct 21 20:14:14 jimmyson-ms7a40 dbus-daemon[11901]: [session uid=971 pid=11901] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=971 pid=11884 comm="/usr/bin/lightdm-gtk-greeter ")
Oct 21 20:14:14 jimmyson-ms7a40 systemd[11876]: Starting Virtual filesystem service...
Oct 21 20:14:14 jimmyson-ms7a40 dbus-daemon[11901]: [session uid=971 pid=11901] Successfully activated service 'org.gtk.vfs.Daemon'
Oct 21 20:14:14 jimmyson-ms7a40 systemd[11876]: Started Virtual filesystem service.
Oct 21 20:14:14 jimmyson-ms7a40 ModemManager[524]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.2/0000:20:04.0/0000:25:00.0': not supported by any plugin
Oct 21 20:14:14 jimmyson-ms7a40 polkitd[467]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Oct 21 20:14:14 jimmyson-ms7a40 polkitd[467]: <no filename>:4: subject=[Subject pid=11884 user='lightdm' groups=lightdm seat='seat0' session='c2' local=true active=true]
Oct 21 20:14:14 jimmyson-ms7a40 at-spi-bus-launcher[11908]: dbus-daemon[11908]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=971 pid=11884 comm="/usr/bin/lightdm-gtk-greeter ")
Oct 21 20:14:14 jimmyson-ms7a40 at-spi-bus-launcher[11908]: dbus-daemon[11908]: Successfully activated service 'org.a11y.atspi.Registry'
Oct 21 20:14:14 jimmyson-ms7a40 at-spi-bus-launcher[11935]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Oct 21 20:14:15 jimmyson-ms7a40 mtp-probe[11945]: bus: 3, device: 16 was not an MTP device
Oct 21 20:14:15 jimmyson-ms7a40 upowerd[1574]: treating change event as add on /sys/devices/pci0000:00/0000:00:07.1/0000:2a:00.3/usb3/3-3/3-3.3/3-3.3.1
Oct 21 20:14:15 jimmyson-ms7a40 mtp-probe[12008]: checking bus 3, device 17: "/sys/devices/pci0000:00/0000:00:07.1/0000:2a:00.3/usb3/3-3/3-3.3/3-3.3.1/3-3.3.1.1"
Oct 21 20:14:15 jimmyson-ms7a40 mtp-probe[12008]: bus: 3, device: 17 was not an MTP device
Oct 21 20:14:15 jimmyson-ms7a40 kernel: r8169 0000:25:00.0 enp37s0: Link is Up - 1Gbps/Full - flow control rx/tx
Oct 21 20:14:15 jimmyson-ms7a40 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp37s0: link becomes ready
