If i try to do something that requires “sudo” user, it says my password is incorrect.
I checked, its not a hardware issue, i can login with the same pass. Sometimes it works sometimes its not.
Probably it happens when i mistype the password it blocks for x time.
I dont know where did i started, i havent really used sudo user a while
That’s normal. You usually get three attempts.
But after one mistype im blocked.
That is possible too. I depends on the PAM settings.
And can i change that to 3 attempts?
Technically, yes. But PAM is a rather complicated subsystem to deal with.
This here is for Debian-based distributions, but it should give you an idea…
And this one’s for CentOS…
Three attempts should be the default. I believe the setting is in
/etc/security/faillock.conf
Edit: sorry, I think that may be for login
