changing the default gnome terminal to xfce4 treminal in manjaro
GNOME Desktop
Open dconf Editor (sudo pacman -S dconf-editor
) and go to org > gnome > desktop > application > terminal and change gnome-terminal to xfce4-terminal. This is how it should look:
Alternatively you can use this command:
gsettings set org.gnome.desktop.default-applications.terminal exec xfce4-terminal
thank you very much
