Im running 5.15 kernel, should i be moving to a newer version. I was told awhile ago that sticking with this one was better at the time for gaming like minecraft for instance. I dont even see 5.17 as an option KDE gives me.
Yes sir Yochanan, I will remember that, but I wasnt using the Konsole for this update, I was using the Desktop GUI And that is why I formatted it like that. Maybe I should have taken screenshots I thought about doing that. The system is now up-to-date. I appreciate the lesson in pamac
You can still copy and paste the output from Add / Remove Software. Click the right arrow in the bottom right while a package transaction is in progress to see the output.
Please do not post screenshots of text. They cannot be indexed by search engines or copied and pasted from.
