I just did a fresh install of Manjaro and I’m in the process of installing some apps, but I’ve run into a problem. Whenever I try to install an app with optional dependencies such as K3B the Add/Remove Software app crashes if I select any of them. If I install without any of the optional dependencies it works just fine. I ran it from the command line and I see this error when it crashes:
Optional Deps : cdrtools: for CD burning with cdrecord
dvd+rw-tools: for DVD burning support
vcdimager: for VCD burning support
emovix: for bootable multimedia CD/DVD support
cdrdao: for disk-at-once (DAO) mode support
cdparanoia: for CD ripping support
Thank you that got it installed. Although I still want to know what the problem is because I still need to install some other packages with optional dependencies like WINE (and boy does it have a lot of them)
local/libpamac 11.6.3-1
Library for Pamac package manager based on libalpm
local/libpamac-flatpak-plugin 11.6.3-1
Flatpak plugin for Pamac
local/pamac-cli 11.6.0-3
A CLI Package Manager based on libalpm with AUR support
local/pamac-gnome-integration 11.7.0-1
Pamac GNOME integration (GTK3)
local/pamac-gtk 11.7.0-1
A Package Manager based on libalpm with AUR and Appstream support (GTK4)
