You may not post anything digital that belongs to someone else without permission. You may not post descriptions of, links to, or methods for stealing someone’s intellectual property (software, video, audio, images), or for breaking any other law.
Besides, you are posting on a support category and you haven’t made a single question.
This post has been edited to the essentials. Please post a question to make it a viable support request.
Went ahead since I figured everything would reset if I just reset the PC. I just get a black screen. Maybe because I’m running software RAID on a separate home partition is affecting the hooks.
#!/bin/bash
# Author: Sebastiaan Meijer (sebastiaan@passthroughpo.st)
# Copy this file to /etc/libvirt/hooks, make sure it's called "qemu".
# After this file is installed, restart libvirt.
# From now on, you can easily add per-guest qemu hooks.
# Add your hooks in /etc/libvirt/hooks/qemu.d/vm_name/hook_name/state_name.
# For a list of available hooks, please refer to https://www.libvirt.org/hooks.html
GUEST_NAME="$1"
HOOK_NAME="$2"
STATE_NAME="$3"
MISC="${@:4}"
BASEDIR="$(dirname $0)"
HOOKPATH="$BASEDIR/qemu.d/$GUEST_NAME/$HOOK_NAME/$STATE_NAME"
set -e # If a script exits with an error, we should as well.
# check if it's a non-empty executable file
if [ -f "$HOOKPATH" ] && [ -s "$HOOKPATH"] && [ -x "$HOOKPATH" ]; then
eval \"$HOOKPATH\" "$@"
elif [ -d "$HOOKPATH" ]; then
while read file; do
# check for null string
if [ ! -z "$file" ]; then
eval \"$file\" "$@"
fi
done <<< "$(find -L "$HOOKPATH" -maxdepth 1 -type f -executable -print;)"
fi
