Hola. Tuve un problema durante una actualización. Hice chroot al sistema mediante un debian instalado en la misma PC y lo que veo es que parece que vmlinuz está corrupto:
file /boot/vmlinuz-5.15-x86_64
/boot/vmlinuz-5.15-x86_64: data
Probé con
mhwd-kernel -i linux60
y sale:mhwd-kernel -i linux60
error: could not open file /var/lib/pacman/local/libmm-glib-1.20.2-1/desc: No such file or directory
error: local database is inconsistent: name mismatch on package libwps
error: local database is inconsistent: version mismatch on package libwps
error: local database is inconsistent: version mismatch on package libxnvctrl
error: local database is inconsistent: name mismatch on package lightdm-slick-greeter
error: local database is inconsistent: version mismatch on package lightdm-slick-greeter
error: could not open file /var/lib/pacman/local/mkinitcpio-33-1/desc: No such file or directory
core 163.9 KiB 71.4 KiB/s 00:02 [######################] 100%
extra 1865.8 KiB 498 KiB/s 00:04 [######################] 100%
community 7.5 MiB 487 KiB/s 00:16 [######################] 100%
multilib 169.3 KiB 363 KiB/s 00:00 [######################] 100%
The following packages are out of date, please update your system first: inxi
Do you want to continue anyway? [y/N] y
error: no targets specified (use -h for help)
**pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Starting full system upgrade…
resolving dependencies…
Packages (1) inxi-3.3.24.1-1
Total Installed Size: 1.15 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
error: hook /usr/share/libalpm/hooks/90-mkinitcpio-install.hook line 6: invalid option ELF_RELOC(R_X86_64_NONE, 0)
error: failed to commit transaction (failed to run transaction hooks)
Errors occurred, no packages were upgraded.**
(notarán que soy bastante bruto y no sólo intnté recetas que ví en otros posts). Alguna sugerencia sobre qué intentar? Muchas Gracias.
