Simplified way to configure Grub
Here is a simplified way to configure Grub, As always reading the manpages, wiki, online resources would be the first step.
Clarification for Manjaro users:
If your GRUB version is an older one then you should update GRUB by:
sudo pacman -Syu
If you get an error then you should install imagemagick:
sudo pacman -S imagemagick
