I was screen recording using Simple Screen Recorder -SSR. The recorded video is flickering and tearing for seconds in between the frames. I am new to manjaro and would be happy to know the problem and accurate solution.
it’s just a guess but you could try switching of the compositing (alt+shift+f12) and see if that helps.
I use vokoscreenNG and don’t experience this issue, so you could also try that out.
Ok. will try and come back soon.,Thanks
