by default,it’s checked on “only notify LTS kernels” and under that there 's an unchecked “only notify recommended Kernels”.
does the latter apply to the LTS one or is it in general?aren’t LTS recommended anyway?
right now I’m on 5.9.11-3 which came with the downloaded ISO; it’s marked as running/installed.
I’m not sure yet i want to use LTS Kernels since-if i understand correctly-it defies a bit the reason to be using Manjaro in the first place and also don’t want to run experimental ones(just tested latest ones).
so what should i do with the settings above?
