Hi, I have my laptop Lenovo 82RJ IdeaPad 3 14IAU7 and other monitor external connected. I have configured after 20 min sleep and then hibernate
. When i connect external monitor, never hibernate and then Laptop battery drains and shuts down.
I have configured these file: sleep,conf
and login.conf
Version Kernel: 6.3.13-1-MANJARO
I remember, i was use kernel 6.2
(I dont remember exactly) but without external monitor, my laptop after 20 min sleep and then hibernate work fine and with kernel 6.3
too. Also i checked hibernate service work fine, because i have configured: when i press button power key then hibernate
, and work fine. But I need hibernate automatically after 20min with a monitor external connected.
Kernel: 6.3.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=6dcfb610-c04c-4089-8f6c-525d4445a805 rw quiet splash
resume=UUID=dd2292be-5e58-4339-8fa6-5a02ad875e8e udev.log_priority=3
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 82RJ v: IdeaPad 3 14IAU7
serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 14IAU7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76465 WIN
serial: <superuser required> UEFI: LENOVO v: JKCN29WW date: 06/20/2022
ID-1: BAT0 charge: 19.4 Wh (42.3%) condition: 45.9/45.0 Wh (102.0%)
power: 7.0 W volts: 11.3 min: 11.1 model: LGC L20L3PF0 type: Li-poly
serial: <filter> status: discharging cycles: 42
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x42A
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1696 high: 2500 min/max: 400/1300:900 scaling:
driver: intel_pstate governor: powersave cores: 1: 573 2: 492 3: 2500 4: 2500
5: 536 6: 2500 7: 2500 8: 2500 9: 693 10: 567 11: 2500 12: 2500
bogomips: 59916
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a8 class-ID: 0300
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:4 chip-ID: 5986:2155
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_wayland driver: X: loaded: intel dri: i965 gpu: i915
display-ID: 0
Monitor-1: eDP-1 res: 1600x900 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.3.13-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.74 status: off with: wireplumber status: active
tools: pw-cli,wpctl
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel
modules: rtw_8852be pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:b852 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 0bda:4853
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 68.68 GiB (7.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 700 GOLD
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V0620A0 temp: 44.9 C
scheme: GPT
ID-1: / raw-size: 140 GiB size: 136.74 GiB (97.67%) used: 24.5 GiB (17.9%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 181.3 GiB size: 177.39 GiB (97.85%)
used: 44.18 GiB (24.9%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 260 Uptime: 1h 16m wakeups: 13415 Memory: total: 16 GiB note: est.
available: 15.35 GiB used: 4 GiB (26.0%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1255 pm: pacman pkgs: 1242 libs: 346 tools: octopi,pamac,yay
pm: flatpak pkgs: 13 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.28
Here is my log file: log day 24
I go out from my home at: Jul 23 20:35:56. So you can help me, you can look after this time log.
Thanks !
