dline is a simple script that serves as a visual calendar. Compatible with both bash and zsh, this script can help you stay on top of your deadlines and keep track of your time effectively.
Set your deadline using the command dline --set and enter the targeted date in “YYYY/MM/DD” format. This creates a file in the same directory your project resides and is called .deadline which stores your current deadline. Run dline anytime you want to display your calendar.
