Now here is an alternative to my “Bootloader legacy install” Thread.
I could just go with extlinux for my DUAL or MULTIBOOT System. (In case u don|t know it, its a simple, maybe outdated Bootloader, but funktional AND the standard of Alpine linux).
I tried, but in my config there seem to be some errors in it. Alpine boots, Windows not (last entry), Manjaro boots not. Do you see any errors? I would be glad for help!!
Here"s my config (below); my hdd structure is:
sda
-sda1 /boot
-sda2 / for alpine
-sda3 is Windows 10 AME
-sda4 / for Manjaro
# Generated by update-extlinux 6.04_pre1-r6
#DEFAULT menu.c32
UI vesamenu.c32
PROMPT 0
MENU TITLE Alpine/Linux Boot Menu
#MENU HIDDEN
#MENU AUTOBOOT Alpine will be booted automatically in # seconds.
TIMEOUT 40
LABEL ALP
MENU DEFAULT
MENU LABEL Linux Alpine
LINUX vmlinuz-lts
INITRD initramfs-lts
APPEND root=/dev/sda2 modules=sd-mod,usb-storage,ext4 nomodeset quiet rootfstype=ext4
LABEL JARO
MENU LABEL Linux Manjaro KDE
LINUX vmlinuz-5.9-x86_64
INITRD initramfs-5.9-x86_64.img
# APPEND ro root=/dev/sda4 rootfstype=btrfs rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
APPEND ro root=/dev/sda4 rootfstype=btrfs quiet apparmor=1 security=apparmor udev.log_priority=3
LABEL JARO
MENU LABEL Manjaro - mod. INITRD
INITRD intel-ucode.img
# Windows CE/ME/NT, a very dense operating system.
# Second partition (2) on the first hard disk (hd0);
# Linux would *typically* call this /dev/hda2 or /dev/sda2.
LABEL WIN
MENU LABEL Windoof 10
KERNEL chain.c32
APPEND hd0 3
# LABEL cement
# KERNEL chain.c32
# APPEND hd0 2
MENU SEPARATOR
some general questions:
What’s this for? : udev.log_priority=3
Whats this .img file for that Manjaro standard installation produced?: intel-ucode.img
concerning the options that Manjaro usually uses in the grub.cfg entry, I just copied and pasted them to extlinux… because of a loack of knowledge and documentation of the extlinux/szslinux wiki.
The level of verbosity of certain warnings printed during the boot process - so it stays rather quiet overall.
intel-ucode.img
That is the firmware (Intel specific, there is also one for AMD-Processors)
for correcting bugs in the hardware of the CPU
AFAIK
It could work without it - but it might not, or in a flawed manner.
… that is how I understood it …
research if you want to know better/more in depth
Syslinux bootloader setup, install and update is not as automated as it is for Grub.
You’ll probably have to maintain it all by yourself
(on any kernel change/update).
Manjaro (or Arch) won’t do it for you.
Yes. In the grub.cfg there is also a APPEND or INITRD part. How do I activate BOTH intel-ucode.img and initramfs-5.9-x86_64.img ? Because Manjaro’s grub installation gives options with either one. Or how is it best?
yes of course. I will go look somewhere else. But this was meant for the grub cfg:
I don’t really know.
Sorry.
From looking at the script /usr/bin/update-grub
which calls /usr/bin/grub-mkconfig
any microcode image with these names intel-uc.img intel-ucode.img amd-uc.img amd-ucode.img early_ucode.cpio microcode.cpio
that are present in the /boot directory
will be included in the initrd that is generated
… I have only the intel-ucode.img there since I have no need for the amd-ucode.img or any others.
