Hey guys. I had an issue with the latest NVIDIA drivers just a short while ago. Discord updated, so now I have to update my computer again. Will this update kill the 3000 series graphics cards? If yes, how should I avoid that fate before I reboot my computer xD
I doubt it. The last update was only the discord
package, so nothing else will be updated unless your system was not up-to-date to begin with.
Well I previously had to backdate the drivers. How would I know if my manual driver change has been overwritten in the latest update?
Can I show you my console logs? Perhaps you can help.
sudo pacman -Syyuu  ✔
[sudo] password for twrecks:
core 163.0 KiB 156 KiB/s 00:01 [####################################] 100%
extra 1834.1 KiB 340 KiB/s 00:05 [####################################] 100%
community 7.4 MiB 1894 KiB/s 00:04 [####################################] 100%
multilib 174.6 KiB 746 KiB/s 00:00 [####################################] 100%
resolving dependencies...
Packages (8) discord-0.0.21-1 linux515-5.15.74-3 linux515-nvidia-470xx-470.141.03-18
manjaro-pulse-20221015-2 matray-1.1.4-1 mhwd-nvidia-520.56.06-2
onlyoffice-desktopeditors-7.2.1-1 timeshift-22.06.5-3
Total Download Size: 435.96 MiB
Total Installed Size: 1082.41 MiB
Net Upgrade Size: -2.02 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
onlyoffice-desktopeditors-7.2.1-... 244.0 MiB 871 KiB/s 04:47 [####################################] 100%
linux515-5.15.74-3-x86_64 101.1 MiB 854 KiB/s 02:01 [##############################################################] 100%
discord-0.0.21-1-x86_64 57.6 MiB 752 KiB/s 01:18 [##############################################################] 100%
linux515-nvidia-470xx-470.141.03-18-x86_64 32.4 MiB 991 KiB/s 00:33 [##############################################################] 100%
timeshift-22.06.5-3-x86_64 774.2 KiB 830 KiB/s 00:01 [##############################################################] 100%
matray-1.1.4-1-x86_64 116.4 KiB 471 KiB/s 00:00 [##############################################################] 100%
mhwd-nvidia-520.56.06-2-any 21.0 KiB 91.2 KiB/s 00:00 [##############################################################] 100%
manjaro-pulse-20221015-2-any 20.1 KiB 118 KiB/s 00:00 [##############################################################] 100%
Total (8/8) 436.0 MiB 854 KiB/s 08:43 [##############################################################] 100%
(8/8) checking keys in keyring [##############################################################] 100%
(8/8) checking package integrity [##############################################################] 100%
(8/8) loading package files [##############################################################] 100%
(8/8) checking for file conflicts [##############################################################] 100%
(8/8) checking available disk space [##############################################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Removing linux initcpios...
(1/8) upgrading discord [##############################################################] 100%
(2/8) upgrading linux515 [##############################################################] 100%
(3/8) upgrading linux515-nvidia-470xx [##############################################################] 100%
(4/8) upgrading manjaro-pulse [##############################################################] 100%
(5/8) upgrading matray [##############################################################] 100%
(6/8) upgrading mhwd-nvidia [##############################################################] 100%
(7/8) upgrading onlyoffice-desktopeditors [##############################################################] 100%
warning: directory permissions differ on /opt/onlyoffice/
filesystem: 755 package: 775
(8/8) upgrading timeshift [##############################################################] 100%
(1/8) Arming ConditionNeedsUpdate...
(2/8) Updating module dependencies...
(3/8) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.74-3-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
loadkeys: Unable to open file: au: No such file or directory
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: bfa
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
(4/8) Updating Kernel initcpios for Nvidia-DRM...
(5/8) Refreshing PackageKit...
(6/8) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
fgrep: warning: fgrep is obsolescent; using grep -F
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
(7/8) Updating icon theme caches...
(8/8) Updating the desktop file MIME type cache...
That would be the case, given that you need to update the kernel.
If you only want discord
, then you can try…
sudo pacman -S discord
… but be advised that this will leave your system in a partial-upgrade state, which we cannot support.
I’ve already done the full update. The logs are above in the previous post. It does mention NVIDIA in there. How can I know that these aren’t drivers that are gonna kill my computer on reboot?
You don’t. Or I don’t think you do. I think that issue had been solved, but since I didn’t have it, I don’t know for sure.
You’ll either have to check the #announcements:stable-updates announcements, Nvidia’s website, or install the previous driver, or update, reboot and test. You can always install the drivers from a chroot
environment.
Ah thanking you kindly for the link to the announcements. This answers my problem. They reckon they fixed it which is nice.
