I have just installed the signal-desktop
package via pacman. The first time a ran it I could go through a syncing routine where you need to scan a QR code on the mobile fone you want to connect the desktop version with.
However, as I am just starting with Signal I didn’t do it but now I can not get back to that point. Practically the application stays in the “Loading” status (which makes sense if you think it was trying to load content from a (non existing) linked account.
I have
- tried to remove and reinstall but nothing has changed in the mentioned behavior.
- disabled
ufw
without any change neither.
I can access all the menu items (one of which being the error log where I have looked at the entries marked as ERROR
but can not draw anything from them really).
Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Signal/1.38.2 Chrome/80.0.3987.165 Electron/8.5.2 Safari/537.36 node/12.13.0 env/production
INFO 2020-12-24T15:22:06.736Z app ready
INFO 2020-12-24T15:22:06.736Z starting version 1.38.2
INFO 2020-12-24T15:22:06.761Z updateSchema:
Current user_version: 20;
Most recent db schema: 21;
SQLite version: 3.30.1;
SQLCipher version: 4.3.0 community;
(deprecated) schema_version: 109;
INFO 2020-12-24T15:22:06.773Z updateToSchemaVersion21: success!
INFO 2020-12-24T15:22:06.781Z Initializing BrowserWindow config: {"show":true,"width":800,"height":610,"minWidth":680,"minHeight":550,"autoHideMenuBar":false,"backgroundColor":"#3a76f0","webPreferences":{"nodeIntegration":false,"nodeIntegrationInWorker":false,"contextIsolation":false,"preload":"[REDACTED]/app.asar/preload.js","nativeWindowOpen":true,"spellcheck":true,"backgroundThrottling":false},"icon":"[REDACTED]/app.asar/images/signal-logo-desktop-linux.png","x":287,"y":151}
INFO 2020-12-24T15:22:06.876Z spellcheck: user locale: en-US
INFO 2020-12-24T15:22:06.876Z spellcheck: available spellchecker languages: ["af","bg","ca","cs","cy","da","de","el","en-AU","en-CA","en-GB","en-US","es","es-419","es-AR","es-ES","es-MX","es-US","et","fa","fo","fr","he","hi","hr","hu","hy","id","it","ko","lt","lv","nb","nl","pl","pt-BR","pt-PT","ro","ru","sh","sk","sl","sq","sr","sv","ta","tg","tr","uk","vi"]
INFO 2020-12-24T15:22:06.877Z spellcheck: setting languages to: ["en-US"]
INFO 2020-12-24T15:22:06.924Z Begin ensuring permissions
INFO 2020-12-24T15:22:06.972Z Ensuring file permissions for 2 files
INFO 2020-12-24T15:22:06.978Z Finish ensuring permissions in 54ms
INFO 2020-12-24T15:22:07.450Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":289,"y":156}
INFO 2020-12-24T15:22:07.450Z config/set: Saving ephemeral config to disk
INFO 2020-12-24T15:22:08.580Z x-attr dependency did not load successfully
INFO 2020-12-24T15:22:08.640Z preload complete
INFO 2020-12-24T15:22:08.993Z pre-main prep time: 2 ms
INFO 2020-12-24T15:22:09.129Z background page reloaded
INFO 2020-12-24T15:22:09.129Z environment: production
INFO 2020-12-24T15:22:09.259Z SQL channel job 1 (getItemById) succeeded in 129ms
INFO 2020-12-24T15:22:09.259Z Storage fetch
INFO 2020-12-24T15:22:09.442Z SQL channel job 2 (getAllItems) succeeded in 182ms
INFO 2020-12-24T15:22:09.474Z SQL channel job 3 (createOrUpdateItem) succeeded in 32ms
WARN 2020-12-24T15:22:09.476Z Client is no longer authorized; deleting local configuration
INFO 2020-12-24T15:22:09.494Z SQL channel job 5 (removeAllConfiguration) succeeded in 18ms
INFO 2020-12-24T15:22:09.497Z SignalProtocolStore: Finished caching identityKeys data
INFO 2020-12-24T15:22:09.497Z SignalProtocolStore: Finished caching sessions data
INFO 2020-12-24T15:22:09.498Z SignalProtocolStore: Finished caching preKeys data
INFO 2020-12-24T15:22:09.498Z SignalProtocolStore: Finished caching signedPreKeys data
WARN 2020-12-24T15:22:09.498Z storage/put: undefined provided for key number_id
INFO 2020-12-24T15:22:09.513Z SQL channel job 14 (createOrUpdateItem) succeeded in 15ms
INFO 2020-12-24T15:22:09.537Z Successfully cleared local configuration
INFO 2020-12-24T15:22:09.552Z SQL channel job 19 (createOrUpdateItem) succeeded in 15ms
INFO 2020-12-24T15:22:09.552Z Starting background data migration. Target version: 10
INFO 2020-12-24T15:22:09.557Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-24T15:22:09.566Z ConversationController: starting initial fetch
INFO 2020-12-24T15:22:09.573Z ConversationController: done with initial fetch
INFO 2020-12-24T15:22:09.574Z SignalProtocolStore: Finished caching identityKeys data
INFO 2020-12-24T15:22:09.574Z SignalProtocolStore: Finished caching sessions data
INFO 2020-12-24T15:22:09.575Z SignalProtocolStore: Finished caching preKeys data
INFO 2020-12-24T15:22:09.575Z SignalProtocolStore: Finished caching signedPreKeys data
INFO 2020-12-24T15:22:09.576Z checkForConflicts: starting...
INFO 2020-12-24T15:22:09.576Z checkForConflicts: complete!
INFO 2020-12-24T15:22:09.578Z Cleanup: starting...
INFO 2020-12-24T15:22:09.578Z Initializing network observer every 5000ms
INFO 2020-12-24T15:22:09.579Z Cleanup: Found 0 messages for cleanup
INFO 2020-12-24T15:22:09.579Z Cleanup: complete
INFO 2020-12-24T15:22:09.579Z listening for registration events
INFO 2020-12-24T15:22:09.587Z connect {"connectCount":0}
INFO 2020-12-24T15:22:09.588Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-24T15:22:09.589Z open inbox
INFO 2020-12-24T15:22:09.676Z SQL channel job 32 (getNextExpiringMessage) succeeded in 89ms
INFO 2020-12-24T15:22:09.676Z SQL channel job 33 (getNextTapToViewMessageToAgeOut) succeeded in 90ms
ERROR 2020-12-24T15:22:10.143Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-24T15:22:10.144Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-24T15:22:10.144Z connect: Error refreshing remote config: HTTPError: promiseAjax: error response; code: 401
at makeHTTPError ([REDACTED]/app.asar/ts/textsecure/WebAPI.js:389:15)
at [REDACTED]/app.asar/ts/textsecure/WebAPI.js:354:24
Original stack:
Error
at _outerAjax ([REDACTED]/app.asar/ts/textsecure/WebAPI.js:384:21)
at _ajax ([REDACTED]/app.asar/ts/textsecure/WebAPI.js:529:20)
at Object.getConfig ([REDACTED]/app.asar/ts/textsecure/WebAPI.js:591:31)
at Object.exports.refreshRemoteConfig ([REDACTED]/app.asar/ts/RemoteConfig.js:34:36)
at connect (file://[REDACTED]/app.asar/ts/background.js:1282:54)
at start (file://[REDACTED]/app.asar/ts/background.js:1114:13)
INFO 2020-12-24T15:22:10.144Z Initializing socket and listening for messages
ERROR 2020-12-24T15:22:10.145Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
at invokeFunc ([REDACTED]/app.asar/node_modules/lodash/lodash.js:10359:23)
at leadingEdge ([REDACTED]/app.asar/node_modules/lodash/lodash.js:10369:26)
at Object.debounced [as maybeRefreshRemoteConfig] ([REDACTED]/app.asar/node_modules/lodash/lodash.js:10436:20)
at Object.initRemoteConfig ([REDACTED]/app.asar/ts/RemoteConfig.js:19:19)
at file://[REDACTED]/app.asar/ts/background.js:467:36
ERROR 2020-12-24T15:22:10.146Z Top-level unhandled promise rejection: TypeError: Cannot read property 'split' of undefined
at Object.unencodeNumber ([REDACTED]/app.asar/ts/textsecure/Helpers.js:82:40)
at new MessageReceiverInner ([REDACTED]/app.asar/ts/textsecure/MessageReceiver.js:46:52)
at new MessageReceiver ([REDACTED]/app.asar/ts/textsecure/MessageReceiver.js:1396:23)
at connect (file://[REDACTED]/app.asar/ts/background.js:1328:31)
INFO 2020-12-24T15:22:10.401Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":305,"y":94}
INFO 2020-12-24T15:22:10.401Z config/set: Saving ephemeral config to disk
INFO 2020-12-24T15:22:11.477Z onEmpty: All outstanding database requests complete
INFO 2020-12-24T15:22:11.477Z Next signed key rotation scheduled for 2020-12-24T15:22:11.477Z
INFO 2020-12-24T15:22:11.478Z refreshSenderCertificate: Getting new certificate...
INFO 2020-12-24T15:22:11.479Z updater/start: Updates disabled - not starting new version checks
INFO 2020-12-24T15:22:11.479Z GET https://textsecure-service.whispersystems.org/v1/certificate/delivery?includeUuid=true
INFO 2020-12-24T15:22:11.480Z Rotating signed prekey...
ERROR 2020-12-24T15:22:11.484Z rotateSignedPrekey error: TypeError: Cannot read property 'privKey' of undefined
at Object.generateSignedPreKey (file://[REDACTED]/app.asar/js/libtextsecure.js:24075:31)
at [REDACTED]/app.asar/ts/textsecure/AccountManager.js:209:73
ERROR 2020-12-24T15:22:11.484Z rotateSignedPrekey() failed. Trying again in five minutes
ERROR 2020-12-24T15:22:11.596Z GET https://textsecure-service.whispersystems.org/v1/certificate/delivery?includeUuid=true 401 Error
ERROR 2020-12-24T15:22:11.596Z refreshSenderCertificate: Get failed. Trying again in five minutes... HTTPError: promiseAjax: invalid response; code: 401
at [REDACTED]/app.asar/ts/textsecure/WebAPI.js:315:36
Original stack:
Error
at Object.getSenderCertificate ([REDACTED]/app.asar/ts/textsecure/WebAPI.js:599:20)
at run ([REDACTED]/app.asar/js/modules/refresh_sender_certificate.js:79:44)
at runWhenOnline ([REDACTED]/app.asar/js/modules/refresh_sender_certificate.js:121:7)
at Object.initialize ([REDACTED]/app.asar/js/modules/refresh_sender_certificate.js:34:3)
at onEmpty (file://[REDACTED]/app.asar/ts/background.js:1536:48)
INFO 2020-12-24T15:22:11.596Z Next sender certificate refresh scheduled for 2020-12-24T15:27:11.596Z
INFO 2020-12-24T15:22:11.597Z refreshOurProfile
ERROR 2020-12-24T15:22:11.597Z Top-level unhandled promise rejection: TypeError: Cannot read property 'getProfiles' of undefined
at refreshOurProfile ([REDACTED]/app.asar/js/modules/refresh_sender_certificate.js:23:16)
at run ([REDACTED]/app.asar/js/modules/refresh_sender_certificate.js:116:5)
INFO 2020-12-24T15:22:15.351Z opening provisioning socket https://textsecure-service.whispersystems.org
INFO 2020-12-24T15:22:15.842Z provisioning socket open
INFO 2020-12-24T15:23:10.959Z Sending a keepalive message
INFO 2020-12-24T15:23:18.050Z WebSocketResource.close()
INFO 2020-12-24T15:23:18.165Z provisioning socket closed. Code: 3000
INFO 2020-12-24T15:23:23.669Z Removing notification
ERROR 2020-12-24T15:23:23.670Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:23:25.253Z SQL channel job 34 (createOrUpdateItem) succeeded in 12ms
INFO 2020-12-24T15:23:25.253Z createAccount: Number is +[REDACTED]090, password has length: 22
INFO 2020-12-24T15:23:25.255Z PUT https://textsecure-service.whispersystems.org/v1/devices/981311
ERROR 2020-12-24T15:23:25.721Z PUT https://textsecure-service.whispersystems.org/v1/devices/981311 409 Error
ERROR 2020-12-24T15:23:25.721Z provisioning failed HTTPError: promiseAjax: error response; code: 409
Original stack:
Error
at Object.confirmCode ([REDACTED]/app.asar/ts/textsecure/WebAPI.js:729:36)
at AccountManager.createAccount ([REDACTED]/app.asar/ts/textsecure/AccountManager.js:316:44)
ERROR 2020-12-24T15:23:25.724Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 409
Original stack:
Error
INFO 2020-12-24T15:23:33.668Z Removing notification
ERROR 2020-12-24T15:23:33.669Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:24:59.080Z close event {"shouldQuit":false}
INFO 2020-12-24T15:24:59.081Z requestShutdown: Requesting close of mainWindow...
INFO 2020-12-24T15:24:59.085Z background/shutdown
INFO 2020-12-24T15:24:59.092Z requestShutdown: Response received
INFO 2020-12-24T15:24:59.093Z before-quit event {"readyForShutdown":true,"shouldQuit":false}
INFO 2020-12-24T15:24:59.093Z close event {"readyForShutdown":true,"shouldQuit":true}
INFO 2020-12-24T15:25:13.499Z app ready
INFO 2020-12-24T15:25:13.499Z starting version 1.38.2
INFO 2020-12-24T15:25:13.526Z updateSchema:
Current user_version: 21;
INFO 2020-12-24T15:25:13.538Z Initializing BrowserWindow config: {"show":true,"width":800,"height":610,"minWidth":680,"minHeight":550,"autoHideMenuBar":false,"backgroundColor":"#3a76f0","webPreferences":{"nodeIntegration":false,"nodeIntegrationInWorker":false,"contextIsolation":false,"preload":"[REDACTED]/app.asar/preload.js","nativeWindowOpen":true,"spellcheck":true,"backgroundThrottling":false},"icon":"[REDACTED]/app.asar/images/signal-logo-desktop-linux.png","x":305,"y":94}
INFO 2020-12-24T15:25:13.621Z spellcheck: user locale: en-US
INFO 2020-12-24T15:25:13.621Z spellcheck: available spellchecker languages: ["af","bg","ca","cs","cy","da","de","el","en-AU","en-CA","en-GB","en-US","es","es-419","es-AR","es-ES","es-MX","es-US","et","fa","fo","fr","he","hi","hr","hu","hy","id","it","ko","lt","lv","nb","nl","pl","pt-BR","pt-PT","ro","ru","sh","sk","sl","sq","sr","sv","ta","tg","tr","uk","vi"]
INFO 2020-12-24T15:25:13.621Z spellcheck: setting languages to: ["en-US"]
INFO 2020-12-24T15:25:13.653Z Begin ensuring permissions
INFO 2020-12-24T15:25:13.703Z Ensuring file permissions for 2 files
INFO 2020-12-24T15:25:13.707Z Finish ensuring permissions in 53ms
INFO 2020-12-24T15:25:14.196Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":307,"y":122}
INFO 2020-12-24T15:25:14.196Z config/set: Saving ephemeral config to disk
INFO 2020-12-24T15:25:15.038Z x-attr dependency did not load successfully
INFO 2020-12-24T15:25:15.087Z preload complete
INFO 2020-12-24T15:25:15.412Z pre-main prep time: 2 ms
INFO 2020-12-24T15:25:15.531Z background page reloaded
INFO 2020-12-24T15:25:15.531Z environment: production
INFO 2020-12-24T15:25:15.593Z SQL channel job 1 (getItemById) succeeded in 61ms
INFO 2020-12-24T15:25:15.593Z Storage fetch
INFO 2020-12-24T15:25:15.826Z SQL channel job 2 (getAllItems) succeeded in 232ms
INFO 2020-12-24T15:25:15.862Z SQL channel job 3 (createOrUpdateItem) succeeded in 35ms
INFO 2020-12-24T15:25:15.879Z SQL channel job 5 (createOrUpdateItem) succeeded in 17ms
INFO 2020-12-24T15:25:15.879Z Starting background data migration. Target version: 10
INFO 2020-12-24T15:25:15.884Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-24T15:25:15.894Z ConversationController: starting initial fetch
INFO 2020-12-24T15:25:15.901Z ConversationController: done with initial fetch
INFO 2020-12-24T15:25:15.903Z SignalProtocolStore: Finished caching sessions data
INFO 2020-12-24T15:25:15.903Z SignalProtocolStore: Finished caching identityKeys data
INFO 2020-12-24T15:25:15.904Z SignalProtocolStore: Finished caching preKeys data
INFO 2020-12-24T15:25:15.904Z SignalProtocolStore: Finished caching signedPreKeys data
INFO 2020-12-24T15:25:15.904Z checkForConflicts: starting...
INFO 2020-12-24T15:25:15.904Z checkForConflicts: complete!
INFO 2020-12-24T15:25:15.907Z Cleanup: starting...
INFO 2020-12-24T15:25:15.907Z Initializing network observer every 5000ms
INFO 2020-12-24T15:25:15.908Z Cleanup: Found 0 messages for cleanup
INFO 2020-12-24T15:25:15.908Z Cleanup: complete
INFO 2020-12-24T15:25:15.908Z listening for registration events
INFO 2020-12-24T15:25:15.914Z connect {"connectCount":0}
INFO 2020-12-24T15:25:15.914Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-24T15:25:15.917Z open inbox
INFO 2020-12-24T15:25:15.925Z SQL channel job 18 (getNextExpiringMessage) succeeded in 12ms
INFO 2020-12-24T15:25:15.925Z SQL channel job 19 (getNextTapToViewMessageToAgeOut) succeeded in 12ms
ERROR 2020-12-24T15:25:16.391Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-24T15:25:16.392Z connect: Error refreshing remote config: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:25:16.392Z Initializing socket and listening for messages
ERROR 2020-12-24T15:25:16.393Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
ERROR 2020-12-24T15:25:16.393Z Top-level unhandled promise rejection: TypeError: Cannot read property 'split' of undefined
INFO 2020-12-24T15:25:56.406Z Removing notification
ERROR 2020-12-24T15:25:56.407Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:26:06.108Z theme-setting changed to dark
INFO 2020-12-24T15:26:06.123Z SQL channel job 20 (createOrUpdateItem) succeeded in 15ms
INFO 2020-12-24T15:26:07.985Z theme-setting changed to system
INFO 2020-12-24T15:26:07.999Z SQL channel job 21 (createOrUpdateItem) succeeded in 14ms
INFO 2020-12-24T15:26:09.449Z theme-setting changed to light
INFO 2020-12-24T15:26:09.465Z SQL channel job 22 (createOrUpdateItem) succeeded in 14ms
INFO 2020-12-24T15:26:34.057Z Removing notification
ERROR 2020-12-24T15:26:34.058Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:26:37.311Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":311,"y":103}
INFO 2020-12-24T15:26:37.311Z config/set: Saving ephemeral config to disk
INFO 2020-12-24T15:28:42.785Z Removing notification
ERROR 2020-12-24T15:28:42.787Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:28:47.739Z before-quit event {"shouldQuit":false}
INFO 2020-12-24T15:28:47.739Z close event {"shouldQuit":true}
INFO 2020-12-24T15:28:47.740Z requestShutdown: Requesting close of mainWindow...
INFO 2020-12-24T15:28:47.742Z background/shutdown
INFO 2020-12-24T15:28:47.752Z requestShutdown: Response received
INFO 2020-12-24T15:28:47.753Z before-quit event {"readyForShutdown":true,"shouldQuit":true}
INFO 2020-12-24T15:28:47.753Z close event {"readyForShutdown":true,"shouldQuit":true}
INFO 2020-12-24T15:29:07.681Z app ready
INFO 2020-12-24T15:29:07.681Z starting version 1.38.2
INFO 2020-12-24T15:29:07.706Z updateSchema:
INFO 2020-12-24T15:29:07.717Z Initializing BrowserWindow config: {"show":true,"width":800,"height":610,"minWidth":680,"minHeight":550,"autoHideMenuBar":false,"backgroundColor":"#3a76f0","webPreferences":{"nodeIntegration":false,"nodeIntegrationInWorker":false,"contextIsolation":false,"preload":"[REDACTED]/app.asar/preload.js","nativeWindowOpen":true,"spellcheck":true,"backgroundThrottling":false},"icon":"[REDACTED]/app.asar/images/signal-logo-desktop-linux.png","x":311,"y":103}
INFO 2020-12-24T15:29:07.822Z spellcheck: user locale: en-US
INFO 2020-12-24T15:29:07.823Z spellcheck: available spellchecker languages: ["af","bg","ca","cs","cy","da","de","el","en-AU","en-CA","en-GB","en-US","es","es-419","es-AR","es-ES","es-MX","es-US","et","fa","fo","fr","he","hi","hr","hu","hy","id","it","ko","lt","lv","nb","nl","pl","pt-BR","pt-PT","ro","ru","sh","sk","sl","sq","sr","sv","ta","tg","tr","uk","vi"]
INFO 2020-12-24T15:29:07.824Z spellcheck: setting languages to: ["en-US"]
INFO 2020-12-24T15:29:07.868Z Begin ensuring permissions
INFO 2020-12-24T15:29:07.898Z Ensuring file permissions for 2 files
INFO 2020-12-24T15:29:07.902Z Finish ensuring permissions in 34ms
INFO 2020-12-24T15:29:08.387Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":313,"y":131}
INFO 2020-12-24T15:29:08.387Z config/set: Saving ephemeral config to disk
INFO 2020-12-24T15:29:09.233Z x-attr dependency did not load successfully
INFO 2020-12-24T15:29:09.292Z preload complete
INFO 2020-12-24T15:29:09.595Z pre-main prep time: 2 ms
INFO 2020-12-24T15:29:09.722Z background page reloaded
INFO 2020-12-24T15:29:09.722Z environment: production
INFO 2020-12-24T15:29:09.887Z SQL channel job 1 (getItemById) succeeded in 164ms
INFO 2020-12-24T15:29:09.887Z Storage fetch
INFO 2020-12-24T15:29:10.013Z SQL channel job 2 (getAllItems) succeeded in 125ms
INFO 2020-12-24T15:29:10.040Z SQL channel job 3 (createOrUpdateItem) succeeded in 26ms
INFO 2020-12-24T15:29:10.057Z SQL channel job 5 (createOrUpdateItem) succeeded in 15ms
INFO 2020-12-24T15:29:10.057Z Starting background data migration. Target version: 10
INFO 2020-12-24T15:29:10.061Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-24T15:29:10.070Z ConversationController: starting initial fetch
INFO 2020-12-24T15:29:10.077Z ConversationController: done with initial fetch
INFO 2020-12-24T15:29:10.079Z SignalProtocolStore: Finished caching sessions data
INFO 2020-12-24T15:29:10.079Z SignalProtocolStore: Finished caching identityKeys data
INFO 2020-12-24T15:29:10.079Z SignalProtocolStore: Finished caching preKeys data
INFO 2020-12-24T15:29:10.080Z SignalProtocolStore: Finished caching signedPreKeys data
INFO 2020-12-24T15:29:10.080Z checkForConflicts: starting...
INFO 2020-12-24T15:29:10.080Z checkForConflicts: complete!
INFO 2020-12-24T15:29:10.082Z Cleanup: starting...
INFO 2020-12-24T15:29:10.083Z Initializing network observer every 5000ms
INFO 2020-12-24T15:29:10.084Z Cleanup: Found 0 messages for cleanup
INFO 2020-12-24T15:29:10.084Z Cleanup: complete
INFO 2020-12-24T15:29:10.084Z listening for registration events
INFO 2020-12-24T15:29:10.091Z connect {"connectCount":0}
INFO 2020-12-24T15:29:10.091Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-24T15:29:10.093Z open inbox
INFO 2020-12-24T15:29:10.173Z SQL channel job 18 (getNextExpiringMessage) succeeded in 84ms
INFO 2020-12-24T15:29:10.174Z SQL channel job 19 (getNextTapToViewMessageToAgeOut) succeeded in 84ms
ERROR 2020-12-24T15:29:10.567Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-24T15:29:10.568Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-24T15:29:10.568Z connect: Error refreshing remote config: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:29:10.568Z Initializing socket and listening for messages
ERROR 2020-12-24T15:29:10.569Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
ERROR 2020-12-24T15:29:10.570Z Top-level unhandled promise rejection: TypeError: Cannot read property 'split' of undefined
INFO 2020-12-24T15:29:10.608Z Removing notification
ERROR 2020-12-24T15:29:10.610Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:29:29.638Z Removing notification
ERROR 2020-12-24T15:29:29.639Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:29:34.642Z Removing notification
ERROR 2020-12-24T15:29:34.642Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:29:44.642Z Removing notification
ERROR 2020-12-24T15:29:44.643Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:29:49.643Z Removing notification
ERROR 2020-12-24T15:29:49.643Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:30:08.413Z Removing notification
ERROR 2020-12-24T15:30:08.415Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T15:39:07.562Z updater/start: Updates disabled - not starting new version checks
INFO 2020-12-24T20:02:54.296Z Removing notification
INFO 2020-12-24T20:02:54.298Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-24T20:02:54.298Z Cycling agent for type -auth
ERROR 2020-12-24T20:02:54.800Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-24T20:02:54.801Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
at file://[REDACTED]/app.asar/ts/background.js:1153:46
at file://[REDACTED]/app.asar/ts/background.js:77:47
at Array.forEach (<anonymous>)
INFO 2020-12-24T20:03:04.299Z Removing notification
ERROR 2020-12-24T20:03:04.299Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T20:03:20.440Z Removing notification
ERROR 2020-12-24T20:03:20.441Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T20:03:30.440Z Removing notification
ERROR 2020-12-24T20:03:30.441Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T20:04:18.163Z Removing notification
ERROR 2020-12-24T20:04:18.164Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T20:04:38.057Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":true,"width":1366,"height":768,"x":0,"y":0}
INFO 2020-12-24T20:04:38.057Z config/set: Saving ephemeral config to disk
INFO 2020-12-24T20:04:40.916Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":313,"y":131}
INFO 2020-12-24T20:04:40.916Z config/set: Saving ephemeral config to disk
INFO 2020-12-24T20:04:47.308Z Removing notification
ERROR 2020-12-24T20:04:47.309Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T20:05:09.540Z Removing notification
ERROR 2020-12-24T20:05:09.541Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-24T20:05:17.792Z close event {"shouldQuit":false}
INFO 2020-12-24T20:05:17.792Z requestShutdown: Requesting close of mainWindow...
INFO 2020-12-24T20:05:17.796Z background/shutdown
INFO 2020-12-24T20:05:17.808Z requestShutdown: Response received
INFO 2020-12-24T20:05:17.810Z before-quit event {"readyForShutdown":true,"shouldQuit":false}
INFO 2020-12-24T20:05:17.811Z close event {"readyForShutdown":true,"shouldQuit":true}
INFO 2020-12-27T10:59:59.313Z app ready
INFO 2020-12-27T10:59:59.313Z starting version 1.38.2
INFO 2020-12-27T10:59:59.348Z updateSchema:
INFO 2020-12-27T10:59:59.362Z Initializing BrowserWindow config: {"show":true,"width":800,"height":610,"minWidth":680,"minHeight":550,"autoHideMenuBar":false,"backgroundColor":"#3a76f0","webPreferences":{"nodeIntegration":false,"nodeIntegrationInWorker":false,"contextIsolation":false,"preload":"[REDACTED]/app.asar/preload.js","nativeWindowOpen":true,"spellcheck":true,"backgroundThrottling":false},"icon":"[REDACTED]/app.asar/images/signal-logo-desktop-linux.png","x":313,"y":131}
INFO 2020-12-27T10:59:59.500Z spellcheck: user locale: en-US
INFO 2020-12-27T10:59:59.500Z spellcheck: available spellchecker languages: ["af","bg","ca","cs","cy","da","de","el","en-AU","en-CA","en-GB","en-US","es","es-419","es-AR","es-ES","es-MX","es-US","et","fa","fo","fr","he","hi","hr","hu","hy","id","it","ko","lt","lv","nb","nl","pl","pt-BR","pt-PT","ro","ru","sh","sk","sl","sq","sr","sv","ta","tg","tr","uk","vi"]
INFO 2020-12-27T10:59:59.501Z spellcheck: setting languages to: ["en-US"]
INFO 2020-12-27T10:59:59.587Z Begin ensuring permissions
INFO 2020-12-27T10:59:59.666Z Ensuring file permissions for 2 files
INFO 2020-12-27T10:59:59.671Z Finish ensuring permissions in 83ms
INFO 2020-12-27T11:00:00.123Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":315,"y":159}
INFO 2020-12-27T11:00:00.124Z config/set: Saving ephemeral config to disk
INFO 2020-12-27T11:00:01.962Z x-attr dependency did not load successfully
INFO 2020-12-27T11:00:02.032Z preload complete
INFO 2020-12-27T11:00:02.497Z pre-main prep time: 2 ms
INFO 2020-12-27T11:00:02.662Z background page reloaded
INFO 2020-12-27T11:00:02.662Z environment: production
INFO 2020-12-27T11:00:02.906Z SQL channel job 1 (getItemById) succeeded in 243ms
INFO 2020-12-27T11:00:02.906Z Storage fetch
INFO 2020-12-27T11:00:03.137Z SQL channel job 2 (getAllItems) succeeded in 231ms
INFO 2020-12-27T11:00:03.177Z SQL channel job 3 (createOrUpdateItem) succeeded in 39ms
INFO 2020-12-27T11:00:03.188Z SQL channel job 4 (createOrUpdateItem) succeeded in 11ms
INFO 2020-12-27T11:00:03.200Z SQL channel job 5 (createOrUpdateItem) succeeded in 23ms
INFO 2020-12-27T11:00:03.201Z Starting background data migration. Target version: 10
INFO 2020-12-27T11:00:03.210Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-27T11:00:03.223Z ConversationController: starting initial fetch
INFO 2020-12-27T11:00:03.232Z ConversationController: done with initial fetch
INFO 2020-12-27T11:00:03.233Z SignalProtocolStore: Finished caching identityKeys data
INFO 2020-12-27T11:00:03.233Z SignalProtocolStore: Finished caching sessions data
INFO 2020-12-27T11:00:03.238Z SignalProtocolStore: Finished caching preKeys data
INFO 2020-12-27T11:00:03.238Z SignalProtocolStore: Finished caching signedPreKeys data
INFO 2020-12-27T11:00:03.239Z checkForConflicts: starting...
INFO 2020-12-27T11:00:03.239Z checkForConflicts: complete!
INFO 2020-12-27T11:00:03.243Z Cleanup: starting...
INFO 2020-12-27T11:00:03.244Z Initializing network observer every 5000ms
INFO 2020-12-27T11:00:03.247Z Cleanup: Found 0 messages for cleanup
INFO 2020-12-27T11:00:03.247Z Cleanup: complete
INFO 2020-12-27T11:00:03.247Z listening for registration events
INFO 2020-12-27T11:00:03.257Z connect {"connectCount":0}
INFO 2020-12-27T11:00:03.259Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-27T11:00:03.261Z open inbox
INFO 2020-12-27T11:00:03.272Z SQL channel job 18 (getNextExpiringMessage) succeeded in 17ms
INFO 2020-12-27T11:00:03.272Z SQL channel job 19 (getNextTapToViewMessageToAgeOut) succeeded in 17ms
ERROR 2020-12-27T11:00:03.731Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-27T11:00:03.737Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
ERROR 2020-12-27T11:00:03.740Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-27T11:00:03.740Z connect: Error refreshing remote config: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-27T11:00:03.740Z Initializing socket and listening for messages
ERROR 2020-12-27T11:00:03.742Z Top-level unhandled promise rejection: TypeError: Cannot read property 'split' of undefined
INFO 2020-12-27T11:00:04.497Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":354,"y":1172}
INFO 2020-12-27T11:00:04.498Z config/set: Saving ephemeral config to disk
INFO 2020-12-27T11:01:06.096Z Removing notification
ERROR 2020-12-27T11:01:06.097Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-27T11:01:27.330Z Removing notification
ERROR 2020-12-27T11:01:27.351Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-27T11:09:59.108Z updater/start: Updates disabled - not starting new version checks
INFO 2020-12-27T11:10:05.136Z Removing notification
ERROR 2020-12-27T11:10:05.137Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-27T11:10:07.714Z before-quit event {"shouldQuit":false}
INFO 2020-12-27T11:10:07.715Z close event {"shouldQuit":true}
INFO 2020-12-27T11:10:07.716Z requestShutdown: Requesting close of mainWindow...
INFO 2020-12-27T11:10:07.717Z background/shutdown
INFO 2020-12-27T11:10:07.733Z requestShutdown: Response received
INFO 2020-12-27T11:10:07.734Z before-quit event {"readyForShutdown":true,"shouldQuit":true}
INFO 2020-12-27T11:10:07.734Z close event {"readyForShutdown":true,"shouldQuit":true}
INFO 2020-12-27T11:11:43.539Z app ready
INFO 2020-12-27T11:11:43.539Z starting version 1.38.2
INFO 2020-12-27T11:11:43.562Z updateSchema:
INFO 2020-12-27T11:11:43.573Z Initializing BrowserWindow config: {"show":true,"width":800,"height":610,"minWidth":680,"minHeight":550,"autoHideMenuBar":false,"backgroundColor":"#3a76f0","webPreferences":{"nodeIntegration":false,"nodeIntegrationInWorker":false,"contextIsolation":false,"preload":"[REDACTED]/app.asar/preload.js","nativeWindowOpen":true,"spellcheck":true,"backgroundThrottling":false},"icon":"[REDACTED]/app.asar/images/signal-logo-desktop-linux.png","x":354,"y":1172}
INFO 2020-12-27T11:11:43.748Z spellcheck: user locale: en-US
INFO 2020-12-27T11:11:43.748Z spellcheck: available spellchecker languages: ["af","bg","ca","cs","cy","da","de","el","en-AU","en-CA","en-GB","en-US","es","es-419","es-AR","es-ES","es-MX","es-US","et","fa","fo","fr","he","hi","hr","hu","hy","id","it","ko","lt","lv","nb","nl","pl","pt-BR","pt-PT","ro","ru","sh","sk","sl","sq","sr","sv","ta","tg","tr","uk","vi"]
INFO 2020-12-27T11:11:43.749Z spellcheck: setting languages to: ["en-US"]
INFO 2020-12-27T11:11:43.855Z Begin ensuring permissions
INFO 2020-12-27T11:11:43.924Z Ensuring file permissions for 2 files
INFO 2020-12-27T11:11:43.927Z Finish ensuring permissions in 72ms
INFO 2020-12-27T11:11:44.386Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":356,"y":1200}
INFO 2020-12-27T11:11:44.386Z config/set: Saving ephemeral config to disk
INFO 2020-12-27T11:11:45.857Z x-attr dependency did not load successfully
INFO 2020-12-27T11:11:45.921Z preload complete
INFO 2020-12-27T11:11:46.340Z pre-main prep time: 2 ms
INFO 2020-12-27T11:11:46.502Z background page reloaded
INFO 2020-12-27T11:11:46.502Z environment: production
INFO 2020-12-27T11:11:46.711Z SQL channel job 1 (getItemById) succeeded in 208ms
INFO 2020-12-27T11:11:46.711Z Storage fetch
INFO 2020-12-27T11:11:46.974Z SQL channel job 2 (getAllItems) succeeded in 262ms
INFO 2020-12-27T11:11:47.036Z SQL channel job 3 (createOrUpdateItem) succeeded in 59ms
INFO 2020-12-27T11:11:47.052Z SQL channel job 5 (createOrUpdateItem) succeeded in 16ms
INFO 2020-12-27T11:11:47.052Z Starting background data migration. Target version: 10
INFO 2020-12-27T11:11:47.057Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-27T11:11:47.071Z ConversationController: starting initial fetch
INFO 2020-12-27T11:11:47.077Z ConversationController: done with initial fetch
INFO 2020-12-27T11:11:47.078Z SignalProtocolStore: Finished caching sessions data
INFO 2020-12-27T11:11:47.079Z SignalProtocolStore: Finished caching identityKeys data
INFO 2020-12-27T11:11:47.079Z SignalProtocolStore: Finished caching preKeys data
INFO 2020-12-27T11:11:47.080Z SignalProtocolStore: Finished caching signedPreKeys data
INFO 2020-12-27T11:11:47.080Z checkForConflicts: starting...
INFO 2020-12-27T11:11:47.080Z checkForConflicts: complete!
INFO 2020-12-27T11:11:47.085Z Cleanup: starting...
INFO 2020-12-27T11:11:47.085Z Initializing network observer every 5000ms
INFO 2020-12-27T11:11:47.088Z Cleanup: Found 0 messages for cleanup
INFO 2020-12-27T11:11:47.088Z Cleanup: complete
INFO 2020-12-27T11:11:47.089Z listening for registration events
INFO 2020-12-27T11:11:47.100Z connect {"connectCount":0}
INFO 2020-12-27T11:11:47.102Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-27T11:11:47.105Z open inbox
INFO 2020-12-27T11:11:47.212Z SQL channel job 18 (getNextExpiringMessage) succeeded in 113ms
INFO 2020-12-27T11:11:47.212Z SQL channel job 19 (getNextTapToViewMessageToAgeOut) succeeded in 113ms
ERROR 2020-12-27T11:11:47.599Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-27T11:11:47.601Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-27T11:11:47.601Z connect: Error refreshing remote config: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-27T11:11:47.601Z Initializing socket and listening for messages
ERROR 2020-12-27T11:11:47.602Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
ERROR 2020-12-27T11:11:47.603Z Top-level unhandled promise rejection: TypeError: Cannot read property 'split' of undefined
INFO 2020-12-27T11:13:24.440Z before-quit event {"shouldQuit":false}
INFO 2020-12-27T11:13:24.441Z close event {"shouldQuit":true}
INFO 2020-12-27T11:13:24.443Z requestShutdown: Requesting close of mainWindow...
INFO 2020-12-27T11:13:24.446Z background/shutdown
INFO 2020-12-27T11:13:24.459Z requestShutdown: Response received
INFO 2020-12-27T11:13:24.460Z before-quit event {"readyForShutdown":true,"shouldQuit":true}
INFO 2020-12-27T11:13:24.460Z close event {"readyForShutdown":true,"shouldQuit":true}
INFO 2020-12-27T11:15:44.761Z app ready
INFO 2020-12-27T11:15:44.761Z starting version 1.38.2
INFO 2020-12-27T11:15:44.782Z updateSchema:
INFO 2020-12-27T11:15:44.791Z Initializing BrowserWindow config: {"show":true,"width":800,"height":610,"minWidth":680,"minHeight":550,"autoHideMenuBar":false,"backgroundColor":"#3a76f0","webPreferences":{"nodeIntegration":false,"nodeIntegrationInWorker":false,"contextIsolation":false,"preload":"[REDACTED]/app.asar/preload.js","nativeWindowOpen":true,"spellcheck":true,"backgroundThrottling":false},"icon":"[REDACTED]/app.asar/images/signal-logo-desktop-linux.png","x":356,"y":1200}
INFO 2020-12-27T11:15:44.886Z spellcheck: user locale: en-US
INFO 2020-12-27T11:15:44.886Z spellcheck: available spellchecker languages: ["af","bg","ca","cs","cy","da","de","el","en-AU","en-CA","en-GB","en-US","es","es-419","es-AR","es-ES","es-MX","es-US","et","fa","fo","fr","he","hi","hr","hu","hy","id","it","ko","lt","lv","nb","nl","pl","pt-BR","pt-PT","ro","ru","sh","sk","sl","sq","sr","sv","ta","tg","tr","uk","vi"]
INFO 2020-12-27T11:15:44.886Z spellcheck: setting languages to: ["en-US"]
INFO 2020-12-27T11:15:44.935Z Begin ensuring permissions
INFO 2020-12-27T11:15:44.967Z Ensuring file permissions for 2 files
INFO 2020-12-27T11:15:44.970Z Finish ensuring permissions in 35ms
INFO 2020-12-27T11:15:45.463Z Updating BrowserWindow config: {"maximized":false,"autoHideMenuBar":false,"fullscreen":false,"width":800,"height":610,"x":358,"y":1228}
INFO 2020-12-27T11:15:45.463Z config/set: Saving ephemeral config to disk
INFO 2020-12-27T11:15:46.291Z x-attr dependency did not load successfully
INFO 2020-12-27T11:15:46.340Z preload complete
INFO 2020-12-27T11:15:46.656Z pre-main prep time: 2 ms
INFO 2020-12-27T11:15:46.779Z background page reloaded
INFO 2020-12-27T11:15:46.779Z environment: production
INFO 2020-12-27T11:15:46.821Z SQL channel job 1 (getItemById) succeeded in 41ms
INFO 2020-12-27T11:15:46.821Z Storage fetch
INFO 2020-12-27T11:15:47.073Z SQL channel job 2 (getAllItems) succeeded in 252ms
INFO 2020-12-27T11:15:47.103Z SQL channel job 3 (createOrUpdateItem) succeeded in 29ms
INFO 2020-12-27T11:15:47.115Z SQL channel job 4 (createOrUpdateItem) succeeded in 12ms
INFO 2020-12-27T11:15:47.126Z SQL channel job 5 (createOrUpdateItem) succeeded in 23ms
INFO 2020-12-27T11:15:47.126Z Starting background data migration. Target version: 10
INFO 2020-12-27T11:15:47.131Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-27T11:15:47.141Z ConversationController: starting initial fetch
INFO 2020-12-27T11:15:47.147Z ConversationController: done with initial fetch
INFO 2020-12-27T11:15:47.149Z SignalProtocolStore: Finished caching identityKeys data
INFO 2020-12-27T11:15:47.149Z SignalProtocolStore: Finished caching sessions data
INFO 2020-12-27T11:15:47.150Z SignalProtocolStore: Finished caching preKeys data
INFO 2020-12-27T11:15:47.150Z SignalProtocolStore: Finished caching signedPreKeys data
INFO 2020-12-27T11:15:47.151Z checkForConflicts: starting...
INFO 2020-12-27T11:15:47.151Z checkForConflicts: complete!
INFO 2020-12-27T11:15:47.153Z Cleanup: starting...
INFO 2020-12-27T11:15:47.154Z Initializing network observer every 5000ms
INFO 2020-12-27T11:15:47.155Z Cleanup: Found 0 messages for cleanup
INFO 2020-12-27T11:15:47.155Z Cleanup: complete
INFO 2020-12-27T11:15:47.155Z listening for registration events
INFO 2020-12-27T11:15:47.160Z connect {"connectCount":0}
INFO 2020-12-27T11:15:47.161Z GET https://textsecure-service.whispersystems.org/v1/config
INFO 2020-12-27T11:15:47.163Z open inbox
INFO 2020-12-27T11:15:47.171Z SQL channel job 18 (getNextExpiringMessage) succeeded in 12ms
INFO 2020-12-27T11:15:47.171Z SQL channel job 19 (getNextTapToViewMessageToAgeOut) succeeded in 11ms
ERROR 2020-12-27T11:15:47.650Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-27T11:15:47.653Z GET https://textsecure-service.whispersystems.org/v1/config 401 Error
ERROR 2020-12-27T11:15:47.653Z connect: Error refreshing remote config: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-27T11:15:47.654Z Initializing socket and listening for messages
ERROR 2020-12-27T11:15:47.656Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
ERROR 2020-12-27T11:15:47.657Z Top-level unhandled promise rejection: TypeError: Cannot read property 'split' of undefined
INFO 2020-12-27T11:25:44.617Z updater/start: Updates disabled - not starting new version checks
INFO 2020-12-27T11:30:17.401Z Removing notification
ERROR 2020-12-27T11:30:17.410Z Top-level unhandled promise rejection: HTTPError: promiseAjax: error response; code: 401
Original stack:
Error
INFO 2020-12-27T11:30:32.745Z Loaded this list of log files from logPath: log.log, log.log.0
Can anybody point me to where to look for cure with this?
